Question about ASUS CROSSHAIR Motherboard
My asus crosshair just quit, now it wont boot and there are solid blue lights lit on the board
    Renaissance:
    An user who is expert in 3 categories / brands.
  • ASUS Master
  • 2,226 Answers
Check power suply out
Posted on May 22, 2014
3 Suggested Answers
CPU solution
  • 164 Answers
SOURCE: my system with asus p5n73-am mother board shows BSOD
if nothing else is affected and everything runs fine after this then i would be careful on what you install because this could become a serious issue this happens because the computer notices an error on startup then either fixes itself or ignores the problem write back if the problem worsens
Posted on Dec 28, 2009
SOURCE: Hi,
Make sure that the switch to turn on mb LED is off and if want to turn it on go into bios and set it. If it is active thru switch and not thru MB it will not allow you to turn on PC cause it is in maintenance mode.
Posted on Jan 10, 2010
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I CANNOT LOAD WIN7 I cannot get my system to boot from a CD disk (Win 7 Ultimate) I set the BIOS to boot from a CD device - the priority is set for CD first. All other values are default. In...
try to reset bios if does't work try using a usb dvd drive (external dvd drive) remember you do not will be able to read a dvd CD(WINDOWS 7 CD) using a cd burner.
you will need a dvd drive.
Feb 07, 2011 | ASUS Computers & Internet
I have an Asus 790GX G65 and when I boot
What that means, is that it cannot find a device that has an operating system on it i.e. a boot track.
Mar 30, 2010 | ASUS Crosshair III Formula AM3 AMD 790FX...
CPU overvolted and burn using 8pin eps12v cable on crosshair
no i dnt think so some time due to manufacturing defects this happens the new one wont burn unless and untill u over volt it.
Jan 31, 2010 | ASUS CROSSHAIR Motherboard
Hi, Just got asus crosshair, blue led lights on the board are on but the power button on the board does nothing?
Dec 05, 2009 | ASUS CROSSHAIR Motherboard
How should i plug the system panel connector correctly
Open your manual to page 1-30. Follow the illustration shown. "F_Panel". What is missing from the manual is the wire colors coming from your case. These colors do vary from case to case. If your lucky the case's wires to the MB will include a two pin jumper and they will be marked as such. (HD_LED, RESET, ECT). Most Asus MB's provide you with a F_Panel stand off. Like the picture provided;
If you notice in the pic above you'll find a solid white wire color. This wire is to be connected to the - negative side of the F_Panel MB or jumper block. Other wire colors such as solid blue, light blue, light green and red are commonly connected as positive +. The four pin internal speaker uses black as its - negative and usually red for positive.
Link to Asus for your board;
http://www.asus.com/product.aspx?P_ID=k3h0ZFVu9Lo1dUvk&content=download
Hope you find this helpful!
Mike
Nov 17, 2009 | ASUS P5PE-VM Motherboard
Post
hi i also have a crosshair mobo and it will not post or start up if the internal blue led's are on switch them off on the back and i'm sure it will start
Aug 24, 2008 | ASUS CROSSHAIR Motherboard
ASUS Crosshair won't boot
some motherboard have 2 power supply plugs 1 for board 1 for cpu check and see if yours is like this 1 is a wide one with about 15/20 pins in the other is asmall square one with 4 pins
Jul 25, 2008 | ASUS CROSSHAIR Motherboard
Computer won't boot up
Make sure that your power switch is connected to the correct pins on the motherboard. The LED you see lit may be the stand-by power indicator saying it has power and is waiting for the signal from the power switch.
May 06, 2008 | ASUS CROSSHAIR Motherboard
ASUS CROSSHAIR Motherboard Logo
59 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
