Question about Denon Audio Players & Recorders
Denon avr 8302 blew a fuse now wont turn on - Denon Audio Players & Recorders
5 Suggested Answers
  • 6 Answers
SOURCE: denon avr 5800
I can help you solve this problem. However you must describe to me which fuse you have replaced. Is it the fuse on the power line or is it a fuse in the speaker line (which I highly doubt). usually this type of amplifier uses two technologies. One is transistors the second is integrated chips. This is in regard to the output stages. I assumed you speaker cables shorted each other while the volume was set at a high level with music playing. Anyway if you are willing I am able to help.
Posted on Sep 01, 2007
SOURCE: My Denon AVR-887 Keeps turning itself off
My AVR-887 IS SHUTTING OFF ALSO AFTER ABOUT 30 SECONDS.
Posted on Dec 04, 2008
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Posted on Mar 02, 2009
SOURCE: Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Posted on Dec 28, 2009
Why wont power come back on the unit all the fuses are good
Never use a staple on a power wire.
Remove the staple and check for damage within the sound bar.
Feb 27, 2017 | Denon Audio Players & Recorders
Denon AVR-1908 won't power on
Are you getting a standby light at all? Is it flashing? Do you here a click when you plug the unit in? If the answer is no to all of these then you blew a fuse. If you do have soome sort of standby light, then your set is in protect mode. More than likely for a blown channel. If no lights, but you ar egetting a click, you could have a bad transformer. Use a DVM and see if it is open or not. Good luck
Aug 23, 2012 | Denon AVR-1908
Denon AVR-4806CI won't turn on.
you must check first the fuse in the power supply which getting blown.if the fuse blown with darkened black color that was mean there are other component parts in the power supply or in the board which get bad. if you know how to test component, check shorted bridge type diode as will as regulator ic and FET transistor in the power supply board.
Aug 16, 2012 | Denon AVR-4806 Receiver
Where is the fuse in a denon AVR-887
It has to have one---follow the power cord inside the unit--if fuse is good consider taking it to a shop for an estimate.
Jun 17, 2012 | Denon AVR-887
Heard a "pop" and my
Maybe. Clearly something blew up. Diagnostic time costs money. Then there are parts and labor.
You can get a new one on ebay ending tomorrow for as little as $140 delivered.
http://cgi.ebay.com/Denon-AVR-2105-stereo-receiver-/220774248046?pt=Receivers_Tuners&hash=item33672bae6e
Apr 25, 2011 | Denon AVR-2105 Receiver
Denon AVR 1601 with no sound output
Sounds like Audio ouput ic's. They're located on the inside of the unit on the big heatsink. get the part number(s) of them and call you local electronics store for parts.
Jan 29, 2010 | Denon AVR-1601 Receiver
Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Jun 28, 2009 | Denon AVR-2106 Receiver
Shuts off then red light indicator flashes, disconnected all speakers but still wont work
Hi, this is a power board issue. remove the cover and make sure that this unit doesn't have blow fuse. if the fuse is fine, you will then need to replace the integrated power/ main board.
May 21, 2009 | Denon AVR-1803 Receiver
No display; No power
Your unit has a hard short in it. This is usually a power supply problem. Most likely the rectifier has failed. This should be a relatively simple and inexpensive repair. Figure on $10 for parts plus the local labor rate.
Dan
Jul 16, 2008 | Denon AVR-1804 Receiver
47 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
