Question about OKI C3400n Laser Printer
Yellow toner cartridge won't lock into place - OKI C3400n Laser Printer
Yellow won't print
First try to replace the yellow toner cartridge. After that, try re-seating the cartridge (take out the cartridge and place it back in carefully making sure it is seated correctly). If this does not resolve the issue, clean the print heads and connections on the cartridge. This can be done by removing the cartridge and swabbing the connections with a Q-tip dipped in rubbing alcohol. Also, while the cartridge is removed, swab the connections to the cartridge that are inside the printer where the cartridge is seated.
May 09, 2011 | Lexmark Pro901 All-In-One Inkjet Printer
HOW TO REMOVE TONER CARTRIDGE TO REPLACE WITH NEW ONE
1. Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
2. Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
3. Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
4. Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
5. Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
6. Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
7. Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Feb 09, 2011 | Brother HL-2040 Laser Printer
I wish to replace the black toner cartridge in the Dell 3010cn. How do I gain access to it. There is easy access to the cyan cartridge at the moment
if you want to replace black one only you should follow these steps Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier does not rotate).
1. After confirming the Insert Yellow Toner(Y) message, open the front door.
2. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
NOTE: You need to remove the protective cover only the first time that you install the toner.
NOTE: Dispose of the protective cover after you remove it.
NOTE: The protective cover is attached to each toner cartridge mount.
3. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
4. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
5. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
6. Close the front door.
NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly.
7. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
8. Repeat steps 1 through 7 when inserting the remaining cartridges.
plz do rate the solution if got help
Nov 25, 2010 | Dell 3010cn Laser Printer
My Ricoh CL7000 keeps asking to replace the yellow toner, which I have done and it goes through the motions of loading the toner then the error message comes back again - asking to replace the yellow...
The toner cartridges for the CL7000 have microchips embedded in them, so the machine knows if it's not a new cartridge. Was the cartridge you put in brand new? (And was it a genuine Ricoh cartridge?)
On those printers, the toner is pumped into a developer system and mixed with the developer before making the image. In the developer unit, the density is checked, so if it's not seeing the right mix there, one of three common problems could be causing this.
The more likely solution is to replace the yellow developer unit, which comes as a whole unit and just slides right in. That will reset your density levels and should correct the "load toner" error.
There is a spring and cushion mechanism that the toner cartridge sits on -- this mechanism can easily be popped out of place and cause problems loading the toner. Take out the yellow toner as well as one of the other colors, and see if the little black circular piece is sitting the same way for both colors. If not, just pop it back into place, using the second color as a guide.
The other likely possibility is that the yellow toner supply tube is clogged, but that doesn't happen very often. To test if it's clogged, take out the yellow toner cartridge and the yellow developer unit and turn the copier off. Use a vacuum to provide suction at one end of the tube (the toner end will be easier) and put your finger on the other end (the developer end) and see if you feel the vacuum's suction. If not, there is probably a clog somewhere in the line.
If there is no clog and you can feel the suction, you may have a bad toner supply motor.
As a side note, if you find the problem and fix it, you might still have to put a new yellow toner cartridge in to get the machine running because it will think the cartridge you already tried is empty.
Hope that helps!
Jun 11, 2010 | Ricoh Aficio 1035 Copier
Get code 004 332 restart printer. have removed the four toner cartridges and replaced the drum cartridge and the same code appears
Hello,reseat and clean the four toner cartridges, verify the orange plastic covers have been removed, and verify the cartridges are fully locked into place, .This is the procedure:
1. Press the Menu button and press the down arrow until Replace Toner appears, and then press the "ENTER" button.
2. Press the down arrow to choose the appropriate color toner cartridge and press the "ENTER" button.
Note:If the Menu button is inaccessible, begin replacing the toner cartridges with step number 3.
3. Open the front cover.
4. Lift the handle of the appropriate colored toner cartridge and remove the toner cartridge.
5. Gently rock the toner cartridge from side to side.
Note:Rock the toner cartridge over newspaper as there may be some toner leakage.
6. Gently wipe the exterior of the toner cartridge with a dry cloth.
7. Verify the mag roller has been removed.
Note:Grasp the orange strap, peel the tape away from you, and then, with the tape free, pull the blue strap toward you.
8. To reinstall the toner cartridge, align the arrows on the cartridge with the corresponding arrows on the printer, guide the cartridge in until it snaps into place, and then push down the right lever to lock the cartridge in place.
Note:Ensure each cartridge lever is fully pressed down into the locked postion.
9. Close the front cover.
10. Repeat steps 1 through 8 until all toner cartridges have been reseated.
Good luck
Feb 05, 2010 | Dell 3100cn Laser Printer
How do you remove toner cartridge from a Dell 3010cn color laser printer correctly.appears to be stuck trying to remove
This is how to Install or replace the Toner Cartridge.
Cheers!!
Apr 21, 2009 | Dell 3010cn Laser Printer
Removing toner cartridge
When the toners go in, they are locked down using the colored part of the cartridge. This holds them in place for printing. However, sometimes even when unlocked they can be very difficult to remove.
After you are sure it is unlocked, do your best to wiggle the cartridge until it start to feel like it is coming loose, and you should be able to pull it out. Do not under any circumstances force it out, just take some time to loosten it up.
Oct 23, 2008 | Dell 3000cn Laser Printer
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Insert Yellow toner
There is a cheap under the toner... it is probably corrupted... with a screw driver you should take it out and replace it with the old cartdrige toner.
Nov 08, 2007 | Dell 5100cn Laser Printer
OKI C3400n Laser Printer Logo
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
