Question about Rainbow Rexair D2, D3C Canister Vacuum Cleaner Floor Brush Bristles Canister Vac Cleaner Floor Brush Bristles
How to take out the motor on a D2 Rainbow
I want to take out motor
Need to wire motor for oreck xl upright
Your new motor should be very similar to the old motor. Compare the two motors to see if you can determine where each wire on the old motor should go on the new motor. If you are not sure it may save you money to have it wired by a qualified repair person. If you hook it up wrong it may damage the new motor and/or other electric components of your vacuum.
Mar 03, 2014 | Vacuums
Dyson dc17 No suction
i have the same problem and none of these solutions help. they are all for if suction works but brush doesn't. that isn't what she is saying. brush motor works fine. It's the Suction motor that never kicks on. Mine is doing it now and I would love a fix for it. Resetting suction motor. Not brush....
Jan 02, 2012 | Dyson DC17 Animal Bagless Upright Cyclonic...
I have a older m&s system central vac model av625 one motor quit the brushes are gone are parts available
You will need a new motor, not brushes, as the worn motor will tear through new brushes. Search online for the M&S motor replacement and you will see helpful sites that will provide the replacement motor. Replacing the motor is not difficult. Consider replacing both motors as the second motor will go out in the near future.
Jan 10, 2011 | M&S Systems Bagless Central Vacuum
Hoover S3765-040 vacuum cleaner. At high motor speed, starts to smell something burning. Opened the motor assembly; removed the motor from its housing; powered it; and see major sparking where the bushings...
You are correct, the motor is done. Look at your local vac store for a quality vacuum made by Sebo or Miele. Replacing motors in chinese made vacs is a waste of money as the whole product was made to last only a couple of years
May 31, 2017 | Hoover S3765-040 WindTunnel Bagless...
Motor will not run appears to be switch or motor
It is quite easy to check this out only if you can just have a multimeter with you.,
Take the panel of the vacuum removed too access the switch and the motor. use the meter to test for continuity of the wire to the switch and then to the motor if there is switching action on the main switch, the the power must come to the motor. however if the motor is not showing a reading , check if it is the brush type motor, if so clean the brush and commutator .or else the motor may need a replacement.
Aug 28, 2010 | Electrolux Vacuums
Replacement motor wiring-not exactly like the old one
yes but make sure the motors are exactly the same.check the voltage on both of them and see if they are both ac motors and not dc motors.if the new motor is dc it won't work.i have a hoover savvy that has a dc motor that i want to replace with a ac motor
Apr 28, 2009 | Vacuums
Nutone central vacuum shuts off after a few minutes running then will restart after motor cools down I cheked motor and vent ports blown out all clean
Sounds like you have an overtemp switch that is tripping and shutting your motor off. Many motors use what they call a 'snap switch" ( looks like a small disk with two wires on it ) to sense motor temp and if that trips, then it will temporarily disable power to the motor until it cools down enough to allow power to be reapplied. If you are sure everything is clean and your motor can rotate freely ( if there is a restriction that limits motor rotation, more current is drawn to drive the motor thru that restriction ..which in turn will cause excessive heat build up and the temp switch to trip) ... Hope that helps!
Aug 13, 2008 | Vacuums
Motor
Filter ?Queen Majestic Canister Vacuum – Motor
Motor?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
If your Filter Queen Motor is out or not working, the customer can replace the motor if they are mechanically minded and mark the wires as they remove the old motor with the new motor or you can have it serviced by your local vacuum dealer in your area, you can pickup the motor @ a local vacuum cleaner dealer in you area by checking the yellow pages or to contact the Filter Queen factory listed below. It requires a new motor and a new gasket; the biggest problem would be the wiring of the new motor. The factory information is listed below:
http://www.filterqueen.com Filter Queen Canisters Vacuums
Health-Mor World Headquarters
13325 Darice Parkway, Unit A
Strongsville, Ohio 44149
1-440-846-7800 or email @ custserv@filterqueen.com
Apr 18, 2008 | Filter Queen Majestic Canister Vacuum
Looking for Replacement Motor for Bosch Ultra 1450W Canister Vacuum
If you are finding BB's. then the bearings are bad. You could pull the motor and take it to a place that rebuilds motors to see about replacing the bearings. If it is a Lamb or amtec motor, there is a number stamped on it, you can match up another motor with that number. Go to a place that sells Vacuum repair parts and they maybe able to get you a new motor.
Dec 24, 2007 | Vacuums
Rainbow Rexair D2, D3C Canister Vacuum Cleaner Floor Brush Bristles Canister Vac Cleaner Floor Brush Bristles Logo
65 people viewed this question
Top Rainbow Vacuums Experts
Joseph Hoffmann
JoeVacs
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
