Question about ION Audio iTTUSB Turntable
Mac recording software
I need drivers for this turntable to work with my mac what do i do
Ringing when recording into mac
This sound like it could be somekind of feedback hum, or earthing problem. Check all the connections.
Mar 14, 2014 | Numark ttUSB Turntable
How to record from decks to mac air?
get a USB interface sound card, then come out of the mixers REC OUT or BOOTH, in to the USB's LINE IN or MIC.
Then you'll need some recording software installed.
Mar 03, 2013 | Technics SL-1210 Turntable
How to best record to computer
For the software I would recomend Magix Audio Cleaning Lab. You should find several different versions on Amazon.
Jan 29, 2013 | Stanton STR8-80 Turntable
Does any driver or software exist to use the RR-US430 Panasonic recorder directly with Macintosh through the usb cable?
It appears that the RR-US430 only has driver software that is designed to work under Windows Vista. There is no specific Mac software available on the Mac, are there any claims that the device will work directly connected to a Mac.
If you have an Intel Mac, and use Bootcamp, Parallels or VMWare Fusion, you could try installing Vista using one of those methods, then running the driver software from here to see if your RR-US-430 is recognized while running Vista on your Mac.
It's a longshot, but pretty much the only option you have if you really want to try using the recorder on a Mac.
Good Luck!
Feb 13, 2010 | Computers & Internet
I recorded my first vinyl into i-tunes with a mac and the sound
Hi, when you say horrible, what do you mean?
Is it distorted?
is it too thin and bright?
Is it dull sounding?
Have you got it connected correctly?
What software are you using?
Let me know.
Regards - Anthony
Feb 07, 2010 | ION Audio Vinyl Recording Turntable
Is there a mac os x driver available anywhere for the sony ps-lx300usb turntable?
You do not need a driver for mac... just plug the usb cable into your mac... go to sound settings in system preferences and set USB to default audio input device... then install audicity... it is free and open source... play your record and hit record in audicity. done.
Feb 06, 2010 | Sony PS-LX300USB Turntable
EZ Audio Converter,no sound in iTunes
Presuming you're on a Mac:
System Preferences -> Sound -> Input
Select "USB Audio CODEC"
Repeat all your recording you've done thus far. Worked here.
Dec 14, 2009 | Numark PT01 Turntable
Need drivers for my ION Audio USB Turntable
Hello
USB audio turntable can be found on this site: Driver Update. have a nice day
Jun 22, 2009 | ION Audio iTTUSB Turntable
Need driver for windows to have the Crosley CR249 turntable work correctly.
Insert the enclosed software cd into your computer.
Follow the instructions on the computer screen to install the software. If the software does not load automatically, browse the cd and open the Read Me folder for further instructions.
Connect the small end of the USB to the USB jack on the back of the unit.
Connect the other end to a USB port on your computer.
On your computer open the Record Recording software.
For instructions on operating the Record Recording software, browse the software cd and open the Read Me folder.
I got that from the manual. You don't need a separate USB driver for it, mate, but you DEFINITELY need the cd...
Hoping you have the cd,
Chris (ziraffa)
Dec 28, 2008 | Crosley CR249TA Turntable
Appears to be installed properly but doesn't record
What computer, and are you using the ion software, or 3rd party software to record?
Keep me posted.
Dec 09, 2007 | ION Audio iTTUSB Turntable
ION Audio iTTUSB Turntable Logo
42 people viewed this question
Top ION Audio Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Joseph Hoffmann
Are you an ION Audio Audio Player and Recorder Expert? Answer questions, earn points and help others
