Question about HP Color LaserJet CM6040f MFP Q3939A Printer
Reset roller kit - HP Color LaserJet CM6040f MFP Q3939A Printer
How to reset roller kit warning on hp laserjet
Hi the HP Laserjet CM6040 how to reset the document feed roller go to administration then go to reset menu then in reset menu scroll down until you see the new document feed roller select either yes or no. Hope this helps
Jun 10, 2014 | Premier Hp - ROLLER KIT CLJ MFP CP6015...
How do I replace PF kit1 Brother MFC-8460n
The paper feed kit is the pick up rollers and the transfer rollers. You can thake those out clean them and replace them, but unless you are actually having paper feed issues usually just clean the paper tray feed rollers with alcohol and reset the paper feed kit counter if needed.
May 21, 2014 | Brother MFC-8460N All-In-One Printer
How to clear the error replace maintenance kit
In service mode:
SP7804
7804 1 Paper
7804 2 Transfer Roller
7804 3 Paper Feed Roller
7804 4 Fusing Unit
Take note:
SP5930 001 Meter Click Charge
[0: No] default
This setting is for machines where the operator is responsible for replacing the Maintenance Kit.
(PM counter resets automatically after the user replaces the fusing unit.)
[1: Yes]
This setting is for machines where the service technician has responsibility for servicing the machine.
The service technician must reset the PM counter after completing machine maintenance.
Mar 19, 2013 | Ricoh MAINTENANCE KIT TYPE 6330N...
P4015n maintenance kit replacement
This maintenance kit consists of a fuser, pick up rollers, transfer rollers. On this model you can also reset the maintenance count by entering the service mode and sometimes by scrolling down to the config menu until you see resets.
Mar 04, 2013 | HP LaserJet P4015N Printer
80 scheduled maintenance will not print
There is a maintenance kit you need to get and install. Then you'll have to go into maintenance mode and reset the maintenance count. I don't remember the button sequence, but if there is a printere repair shop in your city, most likely one of their techs will tell you how to reset the count. But you really should install the kit first. It consists of feed rollers, charge and transfer rollers, and fuser. It's not difficult to install and the kit can be purchased with a refurbished fuser from many vendors at reasonable prices.
Mar 05, 2011 | Lexmark Optra T614 Laser Printer
I am trying to buy a pf kit 1 for my brother MFC 8670 DM. Where can I purchase this?
Just clean the pick up rollers with water + a dash of meths and a drop of detergent, de-fluff the paper separation shoe and rollers on the paper trays. Reset the PF Kit 1 counter (PF = paper feed) and carry on.
Aug 16, 2010 | Brother Office Equipment & Supplies
Lexmark T642
There is a great video that shows step by step how to install the fuser, transfer roller, charge roller, pick up tires and then reset the 80 Scheduled maintenance message
Apr 03, 2009 | Lexmark T642 Laser Printer
RESET INSTRUCTONS FOR XEROX 8560 MAINTENANCE KIT
The maint kit resets the counter when it is installed. You may have gotten a bad maint kit or the black plasstic part that the roller slides into is bad. That is where the connection is to reset the counter.
Harry
Mar 18, 2009 | Xerox Phaser 8560MFP Laser Printer
The printer is showing ready maintenance on the screen
The printer keeps track of how many pages you have printer and will notify you when you need to install a maintenance kit and perform a maintenance reset. You can order a kit here and there is a video on how to install and perform the reset.
http://www.fastprinters.com/dell-fusers-maintenance-kits.asp#W5300
Mar 17, 2009 | Dell W5300N Laser Printer
Maint kit install and page count
Pretty easy, the maintenance kit consists of a transfer roller (black roller that sits underneath toner cartridge), charge roller (sits above toner cartridge), fuser (rear of printer behind two plastic covers), and paper feed rollers. The maintenance kit should have details with diagrams.
To reset
To reset the Maintenance counter, turn off the printer.
Press and hold both Select & Return while powering on the printer.
Hold until display reads 'Performing Self Test" then let go of the buttons.
If the printer displays "80 Maintenance Due" Press the Go Key.
Press the right Menu Key and scroll to Reset Maintenance Counter.
Press the Select Key. Press the Select Key again to reset the counter.
When the reset operation is complete, press the right Menu key to exit Configuration Menu and press Select.
Printer will save the settings, IPL and come back to Ready.
Oct 30, 2008 | IBM 4528-n01 Printer
HP Color LaserJet CM6040f MFP Q3939A Printer Logo
16 people viewed this question
Seeker5211
Seeker5211
