Question about Bose QC15 Headphones
Volume not working
Cannot control volume using the up and down switch on the device. Trying to use with my Note 10.1 1012 edition tablet
My google tablet model u-7305 isn`t working
If you need to reset your tablet:
  1. Turn your tablet off
  2. Hold the volume down key
  3. Turn your tablet on
  4. Press the volume up key
  5. Using the volume down key, highlight Wipe data/factory reset
  6. Press the power key to select Wipe data/factory reset
  7. Press the volume ups key
The reset will now be complete.
Note: Resetting your tablet will clear all the data stored on it. Data that's stored on your SIM won't be affected.
Jul 13, 2015 | Google Computers & Internet
How to an lock my tablet forgot passwort
Someone else asked the same question. I copied and pasted the answer to save it for myself. (This is _not_ my answer. I am quoting the technician who gave it, including her name).
Note: This ''should'' work regardless of manufacturer. It is an ''Andriod'' thing.
Andoid cell phone reset
Here are the steps to perform a hard reset in your device:
1. Switch off the device.
2. Now press and hold Volume Down + Volume Up + Power button, and release them, when you see menu of Bootloader Mode.
3. Then select option "Recovery" from the menu, using Volume Down, then press Volume Up.
4. When you see Android with triangle, then press together Volume Up + Volume Down.
5. After that select option "wipe data / factory reset" using Volume buttons to browse option, and Power button to confirm operation.
6. Choose option "Yes -- delete all user data" and accept with Power button.
7. Press Power button to select option "reboot system now".
Best Regards,
Katy
Motorola Support
May 18, 2015 | Irulu iulu 10.1 inch Andoid 4.0 Touchcreen...
Can you do a screenshot on the Trio Stealth G2 9.7 Tablet?
This should work on any Android 4.0 and newer tablet.
To take a screenshot on your device, press the Volume Down and Power keys at the same time.
The screen will flash, you'll hear a sound, and you'll see a framed image appear and fade into the notification bar. The "Saving screenshot" notification will appear.
May 10, 2015 | Mach Speed Trio Stealth G2 Tablet -...
Can my son's forgotten password on his Zeiki tablet be manually overriden?
You have to reset your tab its at the back of your tablet .or you may go nearest service provider to unlock it.if is not working go to unlock account enter your user name then choose pattern enter your new pattern and then enter it again for confirmation..or u shut down the device then hold the power button hold again the volume up and the power button together.you see the recovery mode scroll down the with volume down button press the factory settings using the power button..then press the power button again to reboot make sure your battery is fully charge.
Apr 25, 2015 | Tablets & eReaders
My daughters home page on her irulu 7 inch tablets is typing by its self. How do I stop it so she can enter her password
Hard Reset the tablet by holding the power on off whilst holding the volume down button until machine switches off, then restart.on some machines it may be volume up instead, others it will be the home button and power button.this should reset tablet to default settings.If it continues to play up then it is likely the touch digitizer is faulty.if you are trying to use a USB keyboard disconnect it before doing any of the above then once tablet is running reconnect the device.it could be the USB keyboard that has a key stuck down due to spilt drink or food.hope this gives you some pointers.
Jan 24, 2015 | Irulu 7" 4gb Mid Google Android 2.3...
My 7" zeki tblet model TBDG773B comes on and shows android and nothing else will.
You can try a factory restore, but if that doesn't work you will need to buy a new tablet. These cheap tablets are throw-aways unfortunately. Note that a factory restore will erase any files you have on the device.
Factory Restore on Android devices:
- Turn off the device
- Hold Volume Down and also press the Power button until a menu comes up
- Use the Volume Up and Down buttons to select Factory Reset (or Restore)
- Press Power to select
Oct 28, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Device worked the first few times I used it, then lost volume and would not increase past first dot.
Please be sure to double check that the volume for BLUETOOTH on the device (phone, tablet, etc.) is also turned up. Please note that the volume buttons on the speaker may not always control the bluetooth volume via the device.
If you continue to have trouble feel free to contact the manufacturer at support1@digixmedia.com or going to http://www.contelusa.net
Jan 29, 2014 | Digix BT-100 Portable Bluetooth Wireless...
Sccreen says all systems, ie, keyborad,google etc have stopped
Most tablets available nowadays are Android-based ones. And most of them can be "factory reset" to leave them as brand new.
First, understand that if you continue, all the information you already added to your tablet will be erased. If you have any info you need to retrieve, please, do not go on and try something different, OK?
All right... Let's go on... The best way to know how to factory reset (or "hard reset", as it is also called) your device is to check in the Internet if there is already a description of the whole process. Assuming that you have a Samsung Galaxy Note 8 tablet, search in Google for "how to factory reset a Samsung Galaxy Note 8 tablet?" Follow the instructions and you will have your tablet running as if it had just been taken out of its box!
If you cannot find the instructions for your specific device, you could, then, try to check if it can enter recovery mode. First, completely switch off your tablet. Then, press at the same time and maintain pressed the "Power" button and the "Volume Up" button and wait for the device to power on, when you can release the keys. An "Android System Recovery" page should appear. If that is the case, you can navigate through the options using "Volume Up" and "Volume Down" keys. Go to the "wipe data/factory reset" option and activate it, pressing the "Power" button. Your tablet should reset (it will take a while).
If you didn't enter the reset page with those keys, repeat the process, this time pressing "Power" and "Volume Down" keys (different tablets have different combinations of keys to enter recovery mode.)
Hope you may find this information helpful!.
Dec 05, 2017 | Mach Speed Trio Stealth G2 Tablet -...
Help how do hard reset my proscan tablet plt7035 i for got my pattern to unlock it
1. Power the Tablet off.
2. Press and hold the Volume Down button of the device, then press and hold the Power button.
3. Continue to hold both buttons until a bootloader screen appears.
4. Wait for the prompt that says to "Press <VOL_UP>" then press the Volume Up button to start the process.
5. Navigate to Erase content.
All info on tablet will be deleted but not the info in the SD card
The tablet will complete the hard reset process and reboot into a factory default state.
Oct 19, 2013 | Proscan Recertified - PLT7035 4GB NAND...
Bose QC15 Headphones Logo
55 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
