Question about Razor GoGo Pogo Stick
My pogo stick wont bounce good it is very stiff do you half to unloose something or what
I tried unloosing it i dont know its just very stiff and i just dont know how to make it unloose
Zumu pogo stick won't bounce
My pogo stick Will not jump it seems like it is stuck
Dec 25, 2013 | Pogo Toys
What is an air pogo stick?
An air jumppogo stick allows you to jump much higher, using technology that gives you a muchbigger bounce in the air rather than on the pavement. They look really cool butcost around $150 so it's not cheap!
Aug 01, 2012 | Sport & Outdoor - Others
How many calories will I burn using a pogo stick?
On averageyou will burn around 600 calories an hour with pogo sticking, but it's hard to imaginebouncing for that long, so calculate it at about 200 calories for every 20minutes.
How do I use my new pogo stick?
When you getstarted on your new pogo stick, make sure you are wearing shoes. Place the pogostick on a hard flat surface like concrete (jumping on grass etc is really hardand likely to cause you to fall). Hold your pogo stick completely straight andpull up on it while you put your feet on either side of the stick. Now you can start bouncing!
Pogo moon stick doesnt bounce. How do u get it to bounce
I bought it too it didn't work either but I'm only fifty pounds so, my grandma tried and she is 135 pounds and it worked so, GAIN MORE WEIGHT!
Jun 17, 2012 | Pogo Moon Stick
What makes corner of paper crumple
You might have something in the paper path , or a part came simi unloose inside.
1. check paper path for debris (may have to open the unit up)
2. Check for simi loose parts as well.
Thanks for using fixya please do rate befor you leave, Thanks
Aug 31, 2010 | Canon PC-940 Black and White Copier
How to lower front suspension on a yamaha yzf 600r
unloose nuts(but just a little bit) on front forks and low it down, but leave wheel and everything on to see how far can you go,that front mask dont come together with front fender when you brake....
Apr 09, 2009 | 1997 Yamaha YZF 600 R thunder cat
Machine keeps sewing after foot pedal is off
there is something stuck in the pedal causing the electric circuit to connect, perhaps some thread or a pin.
unplug it from the machine and see if you can unloose it from under the panel.
Jan 24, 2009 | Sewing Machines
Cannot get old dvd/cd burner out in order to replace
Did you try to take it our forwards? if im not wrong that one goes out in the front, Dont forget to take away all the screws. there are at least 4 of them and you need to unloose them from both sides.
Good luck to you
Dec 21, 2008 | HP Computers & Internet
1997 mountaineer won't start, just clicks.
Check the starter wires to see if they came unloose. If not check to make sure the battery cables are tight without corrosion.
Jul 27, 2008 | 1997 Mercury Mountaineer
Razor GoGo Pogo Stick Logo
814 people viewed this question
Top Razor Sport & Outdoor - Others Experts
Tony
WTF Chuck.....
WTF Chuck.....
Charles T Nevin
Charles T Nevin
Are you a Razor Sport and Outdoor - Other Expert? Answer questions, earn points and help others
