Question about Hobart C-100 10 Quart Mixer
Hobart c-10mixer speed control shaft is loose
Tried to shift speed while motor was running and now the shifter shaft is loose and motor is stuck in one speed. How do I fix this problem. The mixer is otherwise in great condition Thanks!
bigg t
  • 640 Answers
SOURCE: I am trying to fix the dial on my hobart slicer any ideas
This is the deal jason,get a rubber mallet,mineral oil and a mapp torch.If you look at the guage plate this is the part that the meat/cheese goes on you will see 2 rods that connect it.Heat the rods up and put on mineral oil.Hit the guage plate down while turning the knob left then hit it up and knob to the right ,keep doing this and apply plenty of oil .It will be good as new!
Posted on Aug 07, 2008
  • 49 Answers
SOURCE: Hobart C-100 mixer HELP!!!!
This is common there is a key on the shifter shaft and when you removed it the key came out and is floating in the grease in the tranny ready to destory the gears. That are no longer available at Hobart. if you want the shifter /switch plate off, remove the pin in shifter and the handle thats all. Hobart has a special puller I have two of them but you can use a H type puller to get to the pull threaded holes Mixer should be upside down on head to repair trans.
Posted on Sep 30, 2008
ricardok45
  • 135 Answers
SOURCE: HOBART A-200 MIXER- FIRST GEAR NOT WORKING
Hi, your mixer was manufactured in 1947. Hobart does not make public their service manuals. It sounds like the diving key is not engaging first gear with the spinning shaft. This is the ticking sound you hear/feel. This could be because of a broken spring in the mechanism that moves this key in and out, or the key itself has become so worn that it will no longer engage the first gear. The unit needs to be opened up to remove all old grease and oil, including the planetary. The condition of the grease in your description of the planetary, is a good indicator of the condition of the grease in the trans. Your unit probably needs an overhaul due to it's advanced age and grease state. Unplug the unit. You can gently remove the two circular metal dust covers underneath the top cover. With a good flashlight you can view the overall quality of the grease and the level of it. In an ideal world the grease should fill the entire cavity and no oil should be visible. Replacement grease should be Shell Darina EP-2 or Chevron ALC EP-2. You'll need 4-14 OZ. tubes of either type to do the job. The Spec. # for your unit is 3943 Look for drawing # PL-985 Once the cover is off the trans., it's relatively easy to get to the diving key once you remove first gear (the large round gear on top). Remove what you need in sequence, and replace in sequence. If you have a digital camera, take lots of dissasembly pics. When you are done, test in all gears by turning the motor cooling fins with your fingers in the normal direction of the motor rotation. Do not plug the unit back in until you've tested all speeds manually. Good luck! ricardok45
Posted on Mar 01, 2009
SOURCE: Hobart N-50 mixer clangs on 1st and 2nd speed
CE is the marking that shows its european conformant.  I think the difference is mostly in terms of the no volt interlock switch.  This means the KA style N50 bowl won't work with the CE models - too low.
Posted on Mar 17, 2009
ricardok45
  • 135 Answers
SOURCE: Need oil/grease for Hobart 20 qt. mixer
Hi. Your A200 is in need of service. The grease's lifespan has expired. There are two ways of doing this. First, the expensive way. Call for a Hobart Tech to come and service the mixer. This will take about 4-5hrs to service at a rate around $100.00usd per hour, plus the cost of parts. He/she will need to change all seals, remove old grease and oil, check all bearings and gears for excessive wear and replace as necessary, this includes the planetary gear.
Now for the affordable solution. Unplug the mixer, remove the top cover. Gently use a small screwdriver to pry off the two circular metal dust caps found on the transmission housing, use a good flashlight to determine, through these openings, the quality, quantity and condition of the grease inside the transmission case. If there's a lot of oil you can remove much of it a bit at a time by using a wire coat hanger to which you can attach bits of cloth to absorb as much oil as you can. Once oil is removed, add new grease through these same holes until full (Chevron FM ALC EP-2, food grade lube). Run the mixer for a couple of minutes to distribute the new grease. Fill to the top once again and replace dust covers. Remove planetary, clean, inspect change seal and re-grease.
OPTION (mechanically challenging) You can do a more thorough job by removing the trans. cover completely, removing the 3 gear shafts inspect all bearings and gears, change seals on mainshaft and planetary. Remove old grease and oil, clean gearshafts and gears. Parts drawings are available from www.hobartservice.com It's free to register and then locate your parts drawings. Be sure that you have the correct files for your Model #, ML# if there is one and Spec.#, all found on the info plate.
When disassembling, take a digital photo of every step and lay the removed components on a piece of cardboard in the removed sequence. These practices will become valuable during re-assembly.
If this solution has assisted you, please rate it. ricardok45
Posted on Mar 20, 2009
Hobart D300 is stuck in speed 3, any ideas?
Best guess is that the gear for 3rd speed is seized together with it's brass bushing and the center, large transmission shaft. I don't recall which gear is for 3rd, but the transmission has two gears (2nd and 3rd speed) which have brass bushings in them. The brass bushing should spin freely on the center shaft (when in final position - sometimes they pull off the shaft tough, but spin freely when in final position, my opinion is that this is OK), and the gear should spin freely of the brass bushing.
My guess is that the 3rd speed gear, being seized to the center shaft, cannot freely idle on the center shaft, which would result in being stuck in 3rd gear.
Mar 17, 2012 | Hobart D300 Stand Mixer
I have a hobart a-200 mixer. I rebuilt the transmission and got it up and running but the shifter when put into 1st gear still runs at 2nd gear speed. When I put the mixer under a load it slows down like...
Provided you have assembled the machine correctly you have probably tightened the planetary nuts too tight. Loosen both planetary nuts. Should be an acorn nut and a thin nut. Push the planetary all the way up on the shaft and run the thin nut up until it is snug. Back the thin nut off about 1/4 turn. Hold the thin nut and tighten the acorn nut against the thin nut. The planetary must have a small amount of up and down play in it or it will cause the problem you describe.
May 20, 2010 | Hobart A200 Stand Mixer
MY Hobart Hl200 is working with only 2 speeds when it used to work with 4 speeds.
hello! the speed select switch is defective...It is located behind the timer control board...Part # is...00-874831
Guru.............saailer
I’m happy to help further over the phone at https://www.6ya.com/expert/david_6df67de3b14de867
Mar 16, 2010 | Hobart HL200C Mixer
Hobart D340 mixer will not hit 3rd gear
Check that the gear on the shaft that the clutch gear engages with does nort have a sheared key.
Feb 12, 2010 | Hobart D340-6007 Mixer
I have a Hobart A-200 that shifts gears by itself, and sometimes doesn't shift properly with shift lever. Speeds are not always the same as shift lever indicates.
first tighten the top main shaft nut all the way, then back off 1/4 turn ,then go to the planetary nut remove acorn nut, the 1/8 wide nut tighten all the way then back off 1/4 turn reassemble mixer try oper. of speeds. let me know how you make out please
Oct 23, 2009 | Hobart Food Mixers
Jun 03, 2008 | Hobart N50 Stand Mixer
Motor runs but beaters won't turn and gears will not engage or change speed
Most likely there is a broken shaft, seized bearing, or a stripped gear.
The service tech will unassemble everything and replace the necessary warn or broken parts. He will re-assemble everything, check for proper gear lash and bushing clearances, and re-pack new grease.
Jerry G.
Apr 30, 2008 | Hobart A200 Stand Mixer
Apr 02, 2008 | Hobart A200 Stand Mixer
Planetary shaft for h600 is bent
Thats the center shaft and if it moves back and forth the lower bearing is bad or the shaft has cracked.You need to remove all 3 shaft assemblys. if you already removed the gears on the center shaft then you need to remove the shifting yoke---turn power off to machine then take the screws off the trim plate where you shift speeds,you might see a switch that sits up on the shifter cam,remove the screws and put switch aside,take the 4 allen screws off and pull on the shifter(it will come out).If you didnt already drain the oil do it before you mess with the shifter.after the shifter is out grab the upper left gear assy. and the gear assy. below it,rock both gear assy. and pull up,they will both come out(you might need some force)once out remove the remaining gears on the center shaft and remove the shifting yokes.you then need to remove the planetary (lower part of mixer)if not already done,then pull the shaft out from the bottom.any questions let me know.
Nov 19, 2007 | Hobart D300 Stand Mixer
Hobart C-100 10 Quart Mixer Logo
77 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
