Question about Amana Washing Machines
Motor hums but will not start - Amana Washing Machines
    Prodigy:
    An expert who has answered 500 questions.
  • Amana Expert
  • 517 Answers
Change the motor start cap it sounds like a brush less motor
Posted on Feb 08, 2014
My Frigidaire fex831fs4 washer motor hums but wont start.i took belt off.still hums no start even when timer is not set to run.if I close lid motor hums then kicks out then it trys again.thanks 4 help
I appreciate your post, Mike!
Based off what you have described your Frigidaire washer motor will hum and not start. In order to test each component you would need to have the proper electrical equipment. I would recommend contacting a professional technician for proper repairs. They will have the necessary equipment needed to complete your repair. Hopefully this is helpful. -Matt
Aug 31, 2015 | Frigidaire Dryers
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Hum when you hit start button rr lexus@yahoo.com
If you are pressing the start button and getting only humming, that is a motor. What is happening, the motor is trying to start, but the motor has been damaged in some way, so it can't start. All you get is the motor humming. If you post a model number, I can tell you the part number of the motor and an average price :) Having a motor changed by a local service man should generally cost around $200.
May 29, 2010 | Dryers
When statrting the dryer it doesn't start but hums
Sounds like a bad motor to me. If you hold down the start button and hums while its pressed its the motor. Depending on how old it is should determine your decision of whether or not to have it fixed. Hope this helps...
Nov 28, 2009 | Coffee Makers & Espresso Machines
My blower motor will not start. it hums and gets very hot. i can spin the wheel with no resistance gmp075-4
Assuming you are spinning it when the motor is humming, if the motor runs after spinning it it could be the run capacitor (replace) or open/broken start winding in motor(need new motor). Humming should indicate the motor is getting proper voltage. If motor does not try to run by spinning then open run winding in motor (replace motor).
Aug 30, 2009 | Heating & Cooling
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
Dishwasher starts to fill then just hums
Sounds like a motor problem. Behind the chopper is an access to the impeller, try turning the impeller or the chopper blade and see if the motor will rotate. If it doesn't, then something is stuck preventing the motor from running.
Mar 07, 2009 | Dishwashers
Washing Machines Logo
23 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
