Question about Dell UltraSharp 2001FP 20.1" LCD Monitor
Dell 1901FP monitor
Shows Dell Shap Monitor screen the goes black. The power button goes from green to amber. Acts like the is no signal from VGA or DVI.
  • 3 more comments
  • mootser13 Nov 14, 2007
    Mine stays on for about 10 min then shuts off.
    Would you be willing to part with yours ?
  • Anonymous Mar 04, 2008
    Same issue, Think it more the Capacitor than anything. But which one and how to test it.
  • Anonymous Apr 22, 2008
    Powers on, shows dell message, then goes black, also happens when changing input mode, shows D-Sub, Composite, buzzes and goes black.
  • fryday1 Jan 26, 2009
    power light only goes from green to amber when connected to the computer.
It is probably either a CCFL back light issue inside the LCD or a set of capacitors on the inverter/power supply board.
Would you be willing to part with it ?
Posted on Nov 14, 2007
Dell monitor starts well goes on a green light shows then it blacks out and the light on the front turns to amber(yelow)
The lamp goes "orange" when no "signal" is detected.
Check that the "video" cable is tightly-connected to both
the computer and the monitor.
Try the monitor on a different computer.
Try a borrowed monitor on your computer.
Try a different video-card inside your computer.
Mar 09, 2014 | Computers & Internet
Monitor does not activate when computer is turned on - it goes blank - when you press a button on the front of the monitor it states that the computer is in in sleep mode press any key to activate - the...
May be the problem comes from the Cpu.
Try to see if the cable from the monitor is firmly connected to the cpu.
One thing more may be the vga card is having problem.
Try to test the screen with another Cpu. Or the cpu with another monitor.
The amber mode is normal as the screen is not receiving signal from the cpu.
At times the memory chip also report this problem (no display or sleep mode)
Do hear any beep sound or any other Errors??
OK try this
Cheers Uttam
Jun 12, 2010 | Dell E176FP 17" LCD Monitor
The monitor shows a black screen but the green
Yes, there is internal main AC fuse, which should be OK because you can see the indicator light, you need to open it up and check for caps with bulging tops first, post back what you see so we can guide you further, see example of failed monitors due to bad caps:
Mar 07, 2010 | Acer AL1714CB (Black) 17" LCD Monitor
Sometimes No Video
Your Vga Driver is corruoted, if you have a Vga card separate reload the driver, if not reload the mother board driver. If the problem still appears, format the PC.
That is the best case. The other possibilty is mother board failure.
Good luck
Feb 21, 2010 | Dell Inspiron 546 MT Desktop Computer
1905FP Monitor Powers up, briefly shows logo, blacks out.
Look inside for bad caps with bulgng tops, worst case will be shorted out transistors in the backlight inverter circuits or bad lamps. Check to see if you do have he 12vdc for the inveter circuits. See example of failed monitors with bad caps here:
Jan 12, 2010 | Dell UltraSharp 1905FP 19" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Corporate Computer
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
Dell E228WFP two months out of warranty -monitor on and off
if your purchase just the monitor on 2/28/200, normally dell gives 3 years warranty for the monitor If purchased Separately.
OK.. try doing this call Dell.. 18004563355.. JUST give them the serial number of the monitor ONLY they'll check it out then if your lucky they'll send you a replacement.
Apr 23, 2009 | Dell E228WFP LCD Monitor
Monitor sleeps after one second
Try connecting the wires properly. try changing the VGA cable. i had the same problem my screen goes black some times and pink i changed the VGA cable it was absolutely fine!!!
What is VGA cable
VGA Cables Adapters Converters and Devices C2G
visit a computer mechanic for further trobleshooting
Mar 17, 2017 | AcerView F51 15 in. Flat Panel LCD Monitor
Dell UltraSharp 2001FP 20.1" LCD Monitor Logo
332 people viewed this question
Alun Cox
