Question about Wacom Bamboo Pen Black (CTL460)
USB wire detached from the tablet board
I don't know the layout, the colors are red white green and black, don't know what order to solder them in.
  • Silver Mirai
    Silver Mirai Feb 09, 2014
    I've figured it out, it turns out it's the standard USB layout, red white green black in that order.
I would like to know the order in which the colored wires are soldered to the circuit board?
Impossible to answer this question with so little detail. In general you follow the coding on the board, which should show what wire goes where, but that assumes the wires are not in any way energized with power at the time.
Jun 18, 2015 | Cars & Trucks
Maytag neptune dryer
Hey white to white, black to black red to the multi colored pole, and the green one is the ground wire,, . I done that before,, lol,, good luck ,, thanks
Oct 05, 2008 | Maytag Neptune MDE6700A Electric Dryer
I disconnected the pump and need to know where the red black aND WHITE wires go
Hi, this is John the Hayward tech. You say the wire colors are Red, Black and White. Does not seem that the wires colors were correct from the start. Not knowing your voltage let me clarify some things. Normally if you have 115volts coming into the pump you wire colors should be Red or Black to L1 White to L2 and a green ground to the green ground screw. If you have 230volts coming into the pump the two hot leads are normally red and black with a green ground. The red and black wires go to L1 and L2 does not matter red or black. The green goes to the green ground screw.
Sep 03, 2014 | Pool & Spa
Had to change tower looking for the layout to connect the front usb wiring to the board , need to know which wires go on the board
motherboard usually red-white-green-black
Standard USB Cable Wiring Color Code
5V / Red
D+ / Green
D - / White
Ground / Black
hope this helps
Mar 31, 2011 | Intel Motherboard
Wires came loose of control unit from circuit board do you know what order they should be soldered back green white and yellow wires are still connected but I don't know where/which terminal to...
maybe we can help each other out with the questioni have my white black and red still connected but the purple blue yellow green and brown cables are un soldered if u look at the transmitter with the buttons on the bottom and the screen at the top the wires should be on your right there should be nine spots strating from the bottom to upward skip 1 next one should be white then skip one next should be red then next one is black and then thats all i have hope we can help each other
May 15, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Wire colors on source unit are incorrect need to know the order of color for a clarion drb4375. or a sample picture of colors from factory top and bottom.
Hello! TOP...RIGHT TO LEFT...Grey/Black...Grey...
Purple/Black...Purple/Blue (antenna)...Red (acc)
BOTTOM RIGHT TO LEFT...White/Black...White...
Green/Black...Green...Black (ground)...Yellow (constant 12)...Four blank...[Grey...White...Purple...Green]... speakers...
Guru.............Saailer
Apr 07, 2010 | Car Audio & Video
Wires came loose of control unit from circuit board do you know what order they should be soldered back Green, white and yellow wires are still connected but I don't know where/which terminal to...
Rotate the iTrip AutoPilot FM Transmitter controller so that its buttons are facing up and its data cable is on the left side. The data cable wires attach to a row of contact points along the left side of the circuit board as follows (from top to bottom):
1 = Purple
2 = White
3 = Blue
4 = Red
5 = Black
6 = Brown
7 = Green
8 = Yellow
9 = <unused>
Mar 27, 2010 | Griffin Technology Griffin iTrip AutoPilot...
Avanti EWC-12 circuit board replacement (correction)
the green an yellow wire is a ground. Look for an area on the board with a ground symbol earth.gif. Can you not match the location from the old board???
Either way the black and red are your positive and negative power, while the third is the ground. The wire probably are located in close proximity to each other.
Let me know if this helps
Jer
Jan 16, 2010 | Avanti EWC-12 Wine Cooler
What is the colours for the wiring system for subaru legacy 94 for the amount of 14 wire's
http://www.the12volt.com/installbay/stereodetail/1981.html
above is link to wiring for 94 legacy , yet another source has a different layout , make sure the colors match your vehicle , 2 sources provided .
yellow/red = hot in on - fuse 17 -15amp
green = interior lights
blue/red = hot all times , fuse 25 - 10 amp
black = ground
yellow/blue = interior lights
black/green = power ant.
red/yellow = right fr neg
brown/white = left fr neg
white/red = left rear neg
blue/yellow = right rear neg
white/black = right fr pos
green - left fr pos
red/black = left rear pos
red/white = right rear pos
Jan 01, 2009 | Car Audio & Video
The usb cable are de-attached from the bord of my webcam
+Data
Green
-data
White
VCC
Red
GND
Black
BLACK BLUE BROWN are used as Ground
Apr 15, 2008 | Xirlink Promax Webcam
Open Questions:
See all Wacom Bamboo Pen Black (CTL460) Questions
Wacom Bamboo Pen  Black (CTL460) Logo
44 people viewed this question
Top Wacom Computers & Internet Experts
toddmat
Level 1 Expert
jasbo
jasbo
Ed Mac
Are you a Wacom Computer and Internet Expert? Answer questions, earn points and help others
