Question about MSI 745 Ultra (MS-6561-010) Motherboard
Motherboard power connections
I need adiagram of how to connect the various power connection to the MS745 ULTRA motherboard.  Can you help?
    Scholar:
  • 119 Answers
From my extensive experience trial and error can sometimes be the best solution here, never had any shorts with this solutution. plug the power supply onto the mboard then with a screw driver touch together two pins at a time on themboard following a the pins on the panel horizontally, when you touch together the right two pins your mboard will power-up then insert the on-off plug on those two pins 99.9% of the time they are plugged facing inwards (the writing on the plug faces towards the major part of the mboard) after that you can insert the led plugs by the same consept of trial and error. You must plug your harddriver to your board to find the hdd led because then it will flicker when found the power led will remain on constantly. with the resert button the 99.9% of the time the pins are directly below, above or adjacent to the power-on pins. when it comes to the usb pins check- . . . . .
they are in this order above if the spare pin is on the right. starting from left to right, starting with the top row insert - red - white - green - black. the same works for the bottom row.
regards
Casta T.
Posted on Jan 31, 2008
Factory reset of leappad ultra
Download and install Leapfrog connect. If it doesn't download, there's an offline download option available. After installing it, connect your leappad ultra with the usb cable to the pc. power it on. it should get connected. If it doesn't maybe your anti virus software is blocking it. If this happens, go to your antivirus software settings and under firewall rules, select allow for leapfrog connect .exe. Then it should detect your leappad ultra. Go to left hand top corner , select My Products. Then select your leappad ultra. Then goto Settings on the right top corner and in the pop up, select Reset. It will take around 15 - 20 mins to reset it. All data will be erased.
Sep 12, 2013 | Toys
What is the P7 connection for?
The P7 connection ( connectors ) are used for Input. It has various purpose and is totally user's choise of how they want to use the connection for.
More details about the P7 connection is given in below link
P7 Connection
More details about your Motherboard are below
MSI 745 Motherboard
* Please rate this solution with Thumbs up and comment to help us improve providing support
Dec 06, 2010 | MSI 745 Ultra (MS-6561-010) Motherboard
I am working on a KT3 Ultra CE MS-6380E ver.1 mother board. The original problem was that nothing run after I pushed the power switch. I thought the Power Supply went out so I replaced the power supply but...
Sounds like the board or processor has failed. You will have checked all the power connectors to the board? Usual fix is a new board, rather than trying to find which component on the board has failed.
manual
MSI MS 6380LE User Manual
specs
MSI KT3 Ultra2 Specs
MSI website details on the board
KT3 Ultra Ultra ARU Motherboard The world leader in motherboard design MSI...
Seems to be a problem board
Questions Answers for kt3 ultra ce ms 6380e
Jul 12, 2017 | AMD MicroStar KT3 Ultra Socket A ATX...
I transfered my motherboard and other parts into a new box and now it wont turn on??
First ensure that all your connections are correct, then you check for the power cord to see if it is properly connected and if on the inside it is connected to the mother board.
Ensure that all ribbons are properly connected and not damaged in any way, also see to it that the power cord is plugged to a power supply that can carry the system.
Take care
Jul 06, 2010 | ASUS A8N-E Socket 939/nForce4...
How do I power a SATA DVD drive? I have an Ultra 350 ATX supply. Tom.
There are actually adapters for SATA powered devices as long as you have the required SATA data cable connection to your motherboard.
Click here to see an example of this item from ebay.
All you would have to do is plug in the adapter into any free connection on your existing power supply and then plug in the SATA data cable both into your drive and the motherboard. There are actually SATA data cable adapters if you don't have that either, but i'll just stick to answering your question! (:
ASpecialty4You.com
Dec 21, 2009 | Ultra (9PA3501609) 350-Watt Power Supply
I would like to know how to troubleshoot a brand new Ultra LS600 power supply. I would like to go beyond hearing "it's dead" since I am getting power to the motherboard (via indicator light)m but the PSU...
You can start the PSU manually with a paper clip.
Remove the 20 pin connector from the motherboard, leave the four pin power connectors attached to your various drives (this will provide a load on the power supply when it start up (provided it is not faulty).
Look at the 20 pin connector with the connector facing you.and the locking clip to your left.
The fourth pin from the bottom LH corner should be a green colour wire and the next two wires (5th & 6th pin) should be black and next to the locking clip.
Straighten a paper clip and insert it into the 4th pin and into the 5th or 6th pin (ie connect these wires together). These wires connect to the front panel switch to turn on your computer. You are testing the power supply only and since it is not connected to the motherboard the computer won't start.
Now connect the power unit to the mains and switch on the mains, if the power supply is OK the PSU fan should spin up and your hard disk should also spin up. If nothing happens the the PSU is faulty.
You can test the +5volts and +12volts supply on a 4 pin power connector with a multimeter. The red wire is +5volts and the yellow wire is +12volts and the black wires are negative (ground). The voltage readings should be within 5% of these voltages.
There are other voltages to be checked +3volts, -5volts, & -12volts. but these are not as critical.
Dec 05, 2008 | Ultra Products Ultra LS600 Lifetime Series...
ACORP 6bx/via/zx81connectors
http://images.google.co.uk/images?gbv=2&hl=en&q=where+does+hdd+led+and+pw+led+wires+go+on+gigabyte+motherboard&btnG=Search+images
click on this link and it will take you to some images of various motherboards and where the leads go.
I hope this helps
Nov 02, 2008 | Intel Motherboard
Need manual for Soyo SY-KT333 DRAGON Ultra Platinum Edition Motherboard. Mainly for power connections.
Hello:
Get the information from the maker of this board.
you can download it all for free.
thanks,
Sep 01, 2008 | Soyo SY-KT333 DRAGON Ultra Platinum...
Need to connect Mercury PVM900M motherboard cables
my name is Allan kaitila from Tanzania
I bought a motherboard Mercury PVM900M,but i dont know how to conect it.
So may I have its Diagram that shows
The following wires and send it to me through allanafricanboy@yahoo.com
1. SYS_FAN
2. CPU_FAN
3. ATX_12V1
4. POWER SW
5. RESET SW
6. H.D.D LED
7. POWER LED
8 MIC
9. L-RET
10. L-OUT
11. R-RET
12. R-OUT
13. G
14. USB1
15. G
16. USB2
17. G
18. SPEAKER
Feb 25, 2008 | Mercury P4VM800M7 Motherboard
P4SDR-VM SiS650/GL Motherboard
i need SIS650/GL Mother Board Circuit Diagrams Can u proviedmeplease
Oct 17, 2007 | Intel Motherboard
MSI 745 Ultra (MS-6561-010) Motherboard Logo
103 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
