Question about LG DLG7188 Gas Dryer
Admiral dryer How do I convert from LP to NG
Who did the conversion to lp? Do you have the old part from the conversion still? If not you can order a kit to put it back to stock which is ng. Not hard for a guy that's handy but time consuming. 2-2.5hrs.
Posted on Feb 08, 2014
2 Suggested Answers
MNTECH
  • 1543 Answers
SOURCE: LG Dryer DLG7188RM LP conversion back to NG
Disconnect power. Open dryer door and remove 2 phillips screws near lint filter. Remove three phillips screws at very back of dryer top which go through an L shaped part into the back of the dryer. (the L shaped part remains attached to the dryer top) Push the dryer top back about 2 inches and lift off. Remove one screw at each top front corner holding front control panel on to dryer. Remove control panel by carefully releasing plastic tabs which are holding front control panel onto metal support. (Watch out for sharp edges !) You can unplug all electrical plugs, or just swing it up on top of the dryer. (careful not to scratch the plastic control panel) Remove the four phillip screws now assessable at the top of the dryer's front panel / door panel. Tilt forward, unplug door switch and drum light, and lift front panel off . Now set the panel aside. At this point, you may be able to continue with the conversion, but it is easier to do and see if you remove the drum.
To remove drum, Unplug the sensor wire at the bottom of the drum support and remove four phillips screws (going into sides of dryer) holding front drum support and lift up and remove front drum support. Reach in under the drum to unhook the belt. Take drum out.
Take two phillip screws out of flame spreader and push flame spreader back off brass orifice into the burner cone a bit to remove it. Unscrew brass orifice and replace with the Natural Gas orifice. Turn the brass slot headed regulator blocker screw on the front top of the gas valve all the way up. Reassemble.
Sounds complicated but it's not real bad.
A FixYa rating is expected with this much help. Thanks.
Posted on Nov 20, 2008
Parts gl38lkec
call me. converting a barbecue is simple; the kind of job a tech will get while still in training. The LP hole is smaller than the NG becuse of mass and air-mixture in NG so the orifices have to be plugged and re-drilled or replaced with new LP orifices.
Nov 07, 2013 | Sunbeam Grill Series 550
I just purchased a used weber genesis 3000 grill that was converted from LP to NG. At least it has a NG hose and fitting. I connected it to my NG line but it barely lites. It seems to me that only the hose...
you have to change the orfices as well on this not just the line the burners you can use try national energy they are on line they do spares or calgary bbq centre they should have what you need.
Sep 24, 2011 | Grilling
Convert ng dryer to lp, model MGDC400VW or hockup for the lpg tank to my ng dryer.
You can get a conversion kit for that very inexpensively...
Check here
heatman101
Dec 10, 2010 | Maytag Dryers
I have an LP Amana Dryer that I want to convert to natural gas. Do I need to take the dryer apart from the inside?
oh yea need to change orfices and possibly regulator cap rotation... if no ng kits available might need to order orginal valve as all appliances usually come factory with ng...... yes u must acess the internal components so u might need to remove panels and drum to get bettter acess
Apr 10, 2010 | Amana NDG7800AW Gas Dryer
Converting cooktop regulator from NG to LP
LP is higher in pressure than NG, so regulator spring pressure has to be greater.
Aug 06, 2009 | GE Cooktops
Ng to lp gas conversion how do I do this?
The basic difference is gas pressure , which means changing gas jets. You had better call a service man.
Apr 25, 2009 | Dryers
How to convert from lp to ng
Yes,
I converted a Sam's Club Members Mark grille last year and just did some research on the internet and found a numbered drill size chart that gave me the correct drill size to use on each burner(side,main and rear)for the proper BTU supply for the size or BTU rating for your burner. I drilled them, All has worked well! I know Ducane will tell you not to do that, but I think it is a legal issue. If you have a problem, they don't to get a letter from your lawyer.
May 01, 2008 | Ducane 30400042 (LP)
Open Questions:
LG DLG7188 Gas Dryer Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
