Question about Brother CS6000i Computerized Sewing Machine
Service manual I was having problems with my feed dogs, so I took apart my Brother CS6000i to clean out all the fuzz from inside, which was a lot b/c I've been working with a lot of flannel lately. Put it back together, somehow I now have two screws leftover, and my needle keeps hitting the throat plate and breaking, but only when I put on a presser foot (any foot--runs fine on multiple stitches w/o one on, weirdly). I think that b/c the screws are missing, something might be out of alignment. Need to see if anyone has a schematic or repair manual that tells me which screws go where upon reassembly, or has another explanation for why this might be happening. Thanks.
    New Friend:
  • 17 Answers
Https://www.manualslib.com/manual/451089/Brother-Cs-6000i.html
Posted on Apr 05, 2017
  • 46 Answers
SOURCE: needle position
perhaps the needle is not in straight or is bent.
Posted on Oct 24, 2008
SOURCE: I took my maching apart to clean the lint out and
most likely the bobbin case is not aligned correctly .Insert the bobbin case so that the projection on the boobin case aligns with the spring.
Posted on Mar 06, 2009
  • 46 Answers
SOURCE: I have a Brother CE4000. Bobbin carriage will not spin
It is a good idea to clean as you did. However, you must put the needle plate back on the machine first, then the bobbin case is inserted(more on that) then the "L" shaped gray cover. Make sure the b-case is laying level on the surface of the hook and the little bump at about 6 o'clock on the case is touching the spring at about 6 o'clock in the machine. Test a sample.
Posted on Jul 25, 2009
  • 1116 Answers
SOURCE: Presser foot problem
Turn the handwheel so the needle is at the highest position and then turn the power off and then back on.
If this does not help, you will need to take the machine in for service.
Posted on Feb 27, 2010
SOURCE: Brother CS6000i feed dogs issue :(.
sounds like something may have broke or come loose,, I'd take the machine to someone else to have it checked to see what the poping sound was
Posted on Mar 10, 2012
Brother CS6000i with setting 00 for straight line stitch is making a left curve stitches instead going straight.
***Your feed dog under the pressure foot seems to be pulling on one side a little harder which indicates wear. It is likely to solve the problem by replacing the feed dog.
***Before you do this try to lower the pressure on the pressure foot. If the material you are sewing is thick it will have an effect on the pull of the feed dogs. The material you are sewing that you sent appears to be jeans material. It looks like it is thick and somewhat slippery.
Oct 05, 2015 | Brother Sewing Machines
Feed Dog Instructions on how to use or trouble shoot
Not sure if this model has a Feed Dog switch. May be located in area covered by storage portion of sewing bed. May be located on back side of freearm area will be indicated by multiple triangles near the switch.
Cheers,
Kelly
San Diego, CA
Embroidery Services
May 11, 2014 | Brother CS6000i Computerized Sewing...
How do I remove needle plate?
you may have to buy some small screw drivers, either at walmart
or harbor freight,, they're called stubby's,, or off set screw drivers
that's what I use.
here's a link for a free manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_LB_6770_LB6770%20PRW_LB_6770THRD_EN_1446.PDF
Sep 17, 2012 | Brother LB6770 PRW Computerized Sewing...
I dropped the feed dogs and they won't come back up.
Ignore all the other comments, they are wrong.
The feed dogs are driven by the feed driver mechanism, turn the hand-wheel forward and the feed dogs will come up. (Providing you have the feed dog switch to the up position).
Aug 28, 2012 | Brother PC-420
Mar 09, 2012 | Brother CS6000i Computerized Sewing...
I cleaned my machine, but after putting the plate back on, the feed dogs don't pull the fabric through now.
check the feed dogs to see if their up, you can see & feel them with your finger under the needle plate.
if the feed dogs are not up then somewhere in the cleaning the knob or lever got moved, go back thru what you did to find the feed dog knob,,it's always good to know where it at
Sep 07, 2011 | Brother CS6000i Computerized Sewing...
Feed dogs won't raise when I switch the switch in back. How can I take off the back to see what's wrong?
Befoe you try to take it apart, the machine needs to make one or two revolutions before the feed will come up. try that and see if it works.
Jun 01, 2010 | Brother CS6000i Computerized Sewing...
Feed dog & auto threader problems.
Remove the needle plate and clean the lint from between the teeth of feeddogs, also around and inside bobbin case.
The switch for the feeddogs is to raise (normal sewing) or lower (free motion) and if there is no difference, the accumulated lint will have made a felt pad between the teeth forcing the feeddogs to stay down and present with the problem you describe.
When things go a little "weird", the common instinct is OIL EVERYTHING............DON'T DO IT !!! ....this is rarely the solution on its own account, and can make the servicing a great deal longer as the excess must be removed........little oil regularly, not a bucketful every 5 years is a better approach.
Apr 23, 2008 | Brother LS-1217 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
98 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
