Question about Ovens
Looking for replacement fans for unox model XA030
Problem mains power tripped no heat from oven. Replaced fan element still no heat coming through element thermostat light shows temp. Gill element works. Does the the delongei have any fuse attached to fan...
You need to check the thermostat it's usually the problem with most ovens.it's the prob that runs down in the oven with a solid copper looking wire Google it it will tell you how to test it.
Feb 27, 2015 | Ovens
My fan in my lower oven squeeks on start up can that be cleaned or does it need to be replaced
I appreciate your post, friend!
Based off the information you have provided the fan inside the lower half of your Electrolux oven is squeaking and you would like to know how to fix it. Typically, if your fan can be cleaned of any grease or dirt and in order to clean it you would need to access it. To provide you better information I would need to have your model number. You can locate your serial tag (which lists your model number) on the frame of your oven. With that information I can check to see how to access your fan. I look forward to helping you further. -Matt
Feb 23, 2015 | Electrolux Ovens
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Unox oven
i have an unox commerical oven the lights everything works but when i press start the oven the rcd trips and all electricty goes off ???
Jul 03, 2014 | Ovens
Cadco oven wont start ...give error code pre and por
It looks like the controller board is shot. Get on the web with Cadco and request a complete parts list for the controller circuits. Meanwhile, pull the cover off the stove controls and blow in clean, dry compressed air over the circuit boards. Chances are you have a short or two in the circuitry!
Dec 15, 2012 | Cadco Ovens
How do i replace bottom element in blanco oven model bso632
Hi Ron.
Unfortunately I do not have the schematics for this specific model. The fan assisted oven has a top grill element and an element in the fan housing. The fan housing is located inside the oven cavity at the back and protected by a cover held by 4 screws. Here a video showing how to replace the fan assisted element. If there is also a lower element at the bottom of the cavity, this can be reached removing the panel at the bottom of the oven. Here a video showing replacement of the bottom element.
Dec 19, 2011 | Ovens
Fan oven not getting hot
If the fan is working you have power , I wouldmake the sure the power is off or trip the braker then with some type of light look at the lower element for damage it could have a blister type damage or could be broken off , if you see the damage to the element then of couse it needs to be replace , cheep and easy fix , if you need help to locate a part just get back to me with all the info on this oven, make , model, serial number anything else you can find
Dec 07, 2011 | Ovens
Fan works but oven doesn't heat
Check at the terminals and look for burned wiring
Sep 24, 2009 | Ovens
Dacor model W305 blew an element. Replaced it. Won't work.
The fan and element rely on a supply from the thermostat, so perhaps when the element blew, it damaged the thermostat, another possibility is that there is a fuse of some sort in the oven that has blown as a result of the element blowing.
It is highly unlikely that the fan and element are faulty, you will have to look further.
Plz rate this solution.
Thanks, and merry xmas.
Dec 20, 2008 | Ovens
Cadco unox Mod XAF193
You can order the XC605 "air reduction kit" from the manufacturer catalogue.
Oct 16, 2008 | Cadco Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
