Question about Xerox WorkCentre XD100 All-In-One Laser Printer
J2 Error Showing J2 error and I have no manual as I purchased it second-hand. What is it trying to tell me?
  • 208 Answers
You need a new drum..
Posted on Nov 28, 2007
  • 33 Answers
Check for a paper jam in the machine and in the paper tray, if no paper is found take out toner cartridge shake it slightly and reinstall. Also turn machine off & unplug. Let me know if you need more help.
Posted on Oct 27, 2007
Frigidaire Affinity washer (LAFW3511KW0) with an E41 error. I have unplugged to reset (no change), checked the stricker (fine), removed outer seal and disconnected and reattached (I also received an E41...
Install the door lock/switch assembly with the door switch harness disconnected but "jumped". Jump a wire between the wire harness terminals and if the error code (E41) stops appearing when the machine is started, the door lock/switch assembly is indeed faulty and needs to be replaced.
Check the continuity of the door switch harness connecting the switch and terminal J2 of of the control board if the error code (E41) still appears every time the machine is started after putting a jumper wire between the door switch harness terminals.
Make sure the connectors are clean and snugly connected to both. Replace the wire harness if you are skeptical about its condition. Disconnecting the door switch wire harness (J2) from the control board and putting a jumper wire between the leads of terminal J2 on the control board will directly confirm the condition of the wire harness and the board itself. The wire harness is the problem and must be replaced if the error code E41 stops appearing. On the other hand, consider replacing the control board if the error code still flashes even when the leads of terminal J2 on the board is shorted ("jumped").
Aug 21, 2011 | Frigidaire Affinity ATF7000E Front Load...
Err22 showing.How can I start?My machine is Precor 956 model.
The speed sensor is a hall effect sensor that emits a pulse when a flywheel lobe passes between
its transmitter and receiver. The speed control circuit processes the pulse train emitted by the
speed sensor. The speed sensor signal is a real time representation of the operating speed of
the treadmill. The speed control circuit compares the real time speed (speed sensor output) with
the speed that it expects the treadmill to be operating at and acts accordingly to control treadmill
speed or initiate an error code sequence, if necessary. Typically, if a problem exists with the
speed sensor the drive motor will operate (perhaps only briefly) before a speed related error
occurs (errors 20-26).
1. Set the treadmill circuit breaker in the “on” position. Using a DC voltmeter, measure
the voltage between terminal 3 of J2 (green wire) and terminal 4 of J2 (black wire) on
the lower PCA. Slowly, rotate the drive motor flywheel. The voltage should read
approximately 5 Vdc when a flywheel lobe is between the speed sensor “legs” and
approximately 0.25 Vdc when a flywheel lobe is not between the speed sensor “legs”
2. If the voltages in step 1 are correct, go to step 5. If the voltage in step 1 is 0 Vdc or
significantly low when a flywheel lobe is between the speed sensor “legs, continue with step
3. Measure the voltage between terminal 1 of J2 (red wire) and terminal 4 of J2 (black wire) on
the lower PCA. The voltage should read approximately 5 Vdc.
Sensor C954, C956 Treadmill
Page 1-24 Page 24
4. If the voltage is missing or significantly low, disconnect the speed sensor plug from the lower
PCA. Measure the voltage between pins 1 & 4 of the J2 plug on the lower PCA. If the
voltage is approximately 5 Vdc, replace the speed sensor. If the voltage is missing or
significantly low, replace the lower PCA.
5. At this point the speed sensor output is good, but a speed error occurs. There are two
potential causes for this condition. They are upper PCA or lower PCA. There are no good
means of troubleshooting these components other than substituting known good
components. Replace only one component at a time. If the component that you replaced
does not correct the problem, replace the original component. Try substituting the lower
PCA first then the upper PCA, if necessary.
tips extracted from the technical manual Precor956
Jul 14, 2010 | Precor C956i Treadmills with HR /...
J2, toner low, but powder in toner cartg. Remove
All this means is that your toner is getting low and advising you before it is out completly the it needs replacing.
Dec 15, 2009 | Xerox WorkCentre XD100 All-In-One Laser...
I have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Nov 11, 2009 | Heating & Cooling
Drum Cartridge XE Series P8 part number 13R553 Printer code J2
With "J2" flashing, press:
1. "CLEAR" button
2. "AUTO" button, then again
3. "CLEAR" button
4. "AUTO" button
Do it fairly quickly. If it's done quickly enough the display goes off. When it does:
5. enter "2" and "4" (see "24" on display)
6. Press "START/COPY"
7. Press "7"
8. Press "START/COPY"
If display doesn't go off repeat steps 1 to 4 but faster, until display is off.
Nov 07, 2008 | Office Equipment & Supplies
Printer Stopped
J2 is the drum cartridge, or some people call it print cartridge has reached the end of its life.
J1 is the toner cartridge, J2 is the drum.
Jul 17, 2008 | Xerox WorkCentre XD125F All-In-One Laser...
J2 means the drum cartridge needs replaced.
Its next to the toner.
Jul 14, 2008 | Xerox WorkCentre XL2120 Laser Printer
J2 Error ? Xerox Pro 215
J2 means your drum needs to be replaced. The life of the drum is expired.
Mar 13, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
Minolta CF2001 error code C3720
original glass cooling fan motor turning at abnormal timing
Jan 25, 2008 | Minolta CF2001 Copier
Error message
The manual for the BJ-30 can be found here: On page 97 (105 of 183) it indicates your error message. Unfortunately, it does not give a way to resolve the issue other than bringing the device in for repair. I then came across this page which is a bit more descriptive with the error codes. F12 is aPrintHead Temperature Error. It suggests trying to install a NEW print head. if the problem continues, the printer will require service.
Oct 17, 2006 | Canon LaserBase MF5650 All-In-One Printer
Xerox WorkCentre XD100 All-In-One Laser Printer Logo
193 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
