Question about Sharp R-520KS Microwave Oven
Door will not lock closed
The door will not stay closed. The hooks are not broken and move up and down freely. Any help would be greatly appreciated.
4 Suggested Answers
MicrowaveSvc
  • 9047 Answers
SOURCE: sharp microwave R1940
The latch head (the assembly with the hook-like parts sticking out) also has a spring which secures it to the inner door panel. The inner door panel or latch head has a broken spring mount. To repair this, the door panels will have to be separated. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find a helpful exploded view diagram of this model at http://www3.sears.com You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Apr 13, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Apr 18, 2008
  • 3 Answers
SOURCE: Door won't stay closed
I just had this issue happen to me last week.. fortunately I was standing in my kitchen when it happened... I heard a snap and then a piece fall down the inside of either the door or the front key panel.. I'm assuming this controlled the door locking/oven turning on safety mechanism. The inside light wont go off and it won't turn on to cook.. I am trying to figure out if it's worth paying to fix or just replace the whole unit!? Anyone know if this is fixable by oneself rather than spend a bunch of money on a service technician??
Posted on Mar 03, 2011
Why does the microwave have the turntable keep moving/light stay on/keep vibrating whenever the door is closed?
< - contact me directly for free advice.
Remind me of your exact symptoms and the full model number from the tag in the cooking cavity or elsewhere on the oven.
May 10, 2014 | Sharp R-530ES Microwave Oven
Samsung microwave #SMH1611B door won't close
If it has the "double hook" type latch on the door,see if the hooks slide up and down.They should be spring loaded,if not,the spring attachment point inside the door may have broken off(my Sharp Carousel did this).I pryed the plastic door trim loose,and reattached the spring by using one of the slots inside to hold a metal wire clip(modified with needle-nose pliers) to hook the spring onto.Your door's design may be a little different,but a similar solution will probably be apparent after you get in there.
Dec 18, 2012 | Microwave Ovens
How do you remove the door panels on a samsung SMH9187ST? I am replacing / repairing the door latch.
Hi Jerry, it sounds like I have the same problem as you. Have you been able to fix yours?
Sep 08, 2012 | Samsung SMH9187ST Microwave Oven
Door on Sharp R-K520S won't stay closed.
check the hooks and door release button and repair or replace, when this is broken, the switch is not close the microwave will not START.
SEE the diagram
God bless you
Jul 14, 2012 | Microwave Ovens
SAMSUNG MICROWAVE, MODEL SMH9187ST, WHEN NOT IN USE, WE HEARD A SMALL NOISE (CLICK) AND THE DOOR OPENED. THE DOOR WIL NOT LATCH AND STAY CLOSED. I CHECKED THE TWO FUSES, THEY ARE GOOD. WITH THE...
Hi dschema,
You have a door switch issue. There are three behind the panel. If you can lift and hold the door and it starts one of them is bad for sure. You would be better off replacing all three or have a repair man replace them because a microwave can hold 3000v even unplugged.
Hope it helps.
Thank you for using FixYa.
Aug 20, 2011 | Samsung SMH9187ST Microwave Oven
GE JVM1660 spacemaker XL microwave
If you gently push up on the door latch heads (hook-like devices sticking out of the door) there should be spring tension. If they just flop right up, the spring is off inside.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
We have critical safety & disassembly info at our site.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
Apr 25, 2010 | GE JVM1660 Microwave Oven
How to install latch and spring in microwave door
You need to know where the 'catches' are inside the choke cover on the door to remove it carefully without breaking anything or marring the cover. You might get inside and find that the post for mounting the return spring has broken and that is part of the outer door panel.
Sep 11, 2009 | Sharp R-1610 Microwave Oven
Microwave door will not close. the latches that hold it in place will has locked up and one had fell down cause i tried to move it to open it what can i do please help my wife is going crazy on me
You have to separate the door panels (as shown in the attached photo) and then you'll see the inner door parts.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Aug 30, 2009 | Roper Microwave Ovens
Door doesn't lock closed and cooking unable to proceed
The spring is off inside.
Normally the problem is not the spring itself, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
Normally you have to separate the door panels as shown in the attached photo to get to the innards.
Dec 24, 2008 | Panasonic NN-T990SA Microwave Oven
Door will not stay closed, panel reads "Refer to operating instructions before use"
If you gently push up on the door latches (hook-like devices on the door) there should be spring tension. If they just flop right up, the spring is off inside.
Normally the problem is a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
We have critical safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
Jul 05, 2008 | Panasonic Microwave Ovens
Sharp R-520KS Microwave Oven Logo
62 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Ed Mac
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
