Question about LG Washing Machines
De error but the machine have not door switch
    New Friend:
  • 66 Answers
If its front loader door swich is there,,but toploader no door swich but with main pcb having sensor,,locking with door lid with megnet,,,
Posted on Feb 17, 2014
2 Suggested Answers
  • 6277 Answers
SOURCE: My washing machine LG WFT
You're correct- 'de' does stand for Door Error. There is likely to be a problem with either the lid/door solenoid/lock or the 'lid/door closed' sensor. Both are behind where the door's latch goes requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Posted on Jul 19, 2011
My lg washing machine just make a beeep sound then show a error de
de error mean door error. For fixing this you can try to reset using the instruction from lg site (http://www.lg.com/us/support/product-help/CT00000305-20150140270078-others).
If not work, maybe de switch is bad or the door is not closing properly.
Jun 10, 2017 | LG Washing Machines
Bosche front loader de error message help
dE is a door error, check switch, door alignment and wiring harness
May 28, 2014 | LG WM-2277HW Front Load Washer
What is the error D3
I think that should be a "DE" error code. On LG machines the DE error code is for a "Door Open Error".
Check the condition of the door lock, door hook and switch as this will give the error code above, the switch can be checked with a multimeter for condition. You might need to replace the door hook or the internally mounted switch.
May 25, 2014 | LG WM-2077C Front Load Washer
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
I have a LG topload intellowash WF-T7516LS as soon as i switch on the machine the water fills in and then it just shows dE pls help
dE stands for Door open Error. Your door is not closed properly or the door switch is not activated. Try to press the door firmly. If the error does not go then you will have to check the door latch, notch ( a protruding part which goes inside to latch & activate door switch) & the door switch for any damage. For Top load machines the notch is near the hinges & inside the machine.
Sep 22, 2011 | LG WM-2277HW Front Load Washer
When i put the waashing machine on it comes up dE can you tell me what it means please
Hi.
Small d and E means door error. Big DE is drain error.
Hi.
To start be sure that it is small dE , like this:
If it is a big D, then it is drain error, like the one below:
Washers have a door lock with micro-switch or a door lock motor, depending on the model.
If there is a door switch, this can be tested either reading Ohms or jumping its contacts. When the switch has three contacts instead of two the third contact is an 'heater' (impedance). With door closed the two (or tree) door switch contacts must show continuity, which means that if you read impedance using a multimeter the impedance will not be Ohm infinity (circuit open).
If there is a door motor and no switch the motor is tested reading Ohms and verifying that they correspond to the value in specifications.
If it is door error check the connector to the switch or the
(usually VIOLET(VL) 2 PIN on LG) connector to the power board. Disconnect power first and read impedance to check if there is contact.
Regards.
Ginko
Aug 08, 2011 | LG Washing Machines
What to do with error code DE
The De code is a door switch error.
The door switch is broken or a wire to the door switch is loose or broke.
The door switch may need to be replaced.
In rare cases the main computer is at fault.
Jan 15, 2010 | LG WD-1280FHD Front Load Washer
LG Tromm washer constant DE door error problem
A DE Error Code is indicative of a “Door Error”. This indicates that the washing machine door is not shutting, locking or opening. This means that there is something faulty with the door switch and locking mechanism . You should get this replaced or you may have water where you do not want it. biigg53566
Dec 03, 2008 | LG WM-2277HW Front Load Washer
Code de
de is 'door error'. I just fixed this with a new door catch/switch (called a door overlock). Theres a bi-metal strip in there that makes the contacts as well as keeping the door locked closed when its working and it looks like this was the culprit as I was able to open the door even when the machine was filling. The de was intermittant, if you continued to open and close the door it would start eventually - if it does this try changing the switch, cost about £30.
Feb 21, 2008 | LG WM-2277HW Front Load Washer
Error code de
DE is a error code for your door switch. The door is not locking properly. You need to get a new door latch mechanism.
Sgt 48
Mar 29, 2007 | LG WD-1280FHD Front Load Washer
Washing Machines Logo
109 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
