One piece agitator wraps cloths
My machine has a one piece agitator and it started wrapping cloths when filled full level of water and cloths, But when filled half level of water with fewer cloths it works ok. I opened the agitator and splines inside looks ok. Even with half level of water with heavy cloths like towels etc it sometimes starts wrapping. I beleieve it doesn't take heavy loads. What could be wrong in the machine? Please advice.
    New Friend:
  • 14 Answers
When loading the machine, load towels, sheets or jeans with an accordion fold instead of putting the laundry in a circle around the agitator. It helps to put the clothes in at the twelve o'clock position, then six o'clock, then nine o'clock and then three o'clock. Repeat this sequence until the washer is full.
The laundry can circulate much better and get cleaner too.
Posted on Apr 14, 2014
4 Suggested Answers
shaggyrat
  • 1224 Answers
SOURCE: Series 70 prob: Recently started wrapping clothes around agitator
some fabrics are known to do that you have on wrong cycle setting there should be a setting for delicates and clothing and blankets and things when loaded to close to agitator will attract each other together so its wise when loading machine load in a circle leveled out till desired fullness away from agitator they shouldnt attract as much
Posted on May 07, 2008
  • 20 Answers
SOURCE: Clothes are wrapping tightly around agitator and slows it down.
is the agitator broken are they getting caught on an edge? are you using enough water? the machine is suposed to agitate even tho the lid may be open, it will not spin.use soap...
Posted on Feb 13, 2009
SOURCE: Washer won't agitate, drain or spin
LID SWITCH BAD HOW DO I GET TO IT ON LSE7806ACE STACKED WASHER..??
Posted on Aug 04, 2011
Washer not agitating properly.
Try looking under it as I've had that problem and found it was build up of dust
Jul 11, 2015 | Kenmore Washing Machines
How can I remove clothing wrapped around bottom of agitator?
Try to pull out with pliers or Vice gip. May need to unwind around the agitator.
Jul 27, 2014 | GE GTWN3000MWS Washer
Clothes wrapped around the agitator at end of cycle
Can you describe the problem more better? Does it still agitate properly? Have you checked the balance of the tub? I believe you have a bent agitator shaft.
Mar 13, 2014 | Frigidaire FWSB7800DS Top Load Washer
Clothes wrap around washing machine agitator causing it not to spin
clothes wrap around agitator. making clunking noise only while agitator is working
Feb 19, 2011 | Washing Machines
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
My Maytag Ensignia washer is not spinning well. It bangs side to side with even the smallest loads. It seems like something is loose. Is this something I can fix myself or do I need a repair mans help....
Try leveling the washer... If the washer is level, then don't wrap the clothes around the agitator...drop the clothes straight in, on top of each other evenly around the agitator. The Ensignia washer has a Dual action agitator... That means the clothes roll over them selves, instead of moving side to side, as with a traditional agitator. wrapping the clothes around the agitator will cause the load to be un balanced and then cause the "banging" noise... this should take care of the problem...
Jul 31, 2009 | Maytag Ensignia MAV4758AWW Top Load Washer
Feb 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Clothes wrap around agitator and stops the washer
GE spacemaker washing machine . cloths wrap around the agitator . how can i solve this problem .
May 22, 2008 | Washing Machines
Nov 19, 2006 | Kenmore 24902 Top Load Washer
Washing Machines Logo
203 people viewed this question
Top Washing Machines Experts
