My washer will not spin or agitate, but will fill & drain
I have a GE Super Plus 3.2 Cu. Ft. Capacity Washer (Model # WBSE3120BWW) It will fill & drain, but will not spin or agitate. It makes aloud grinding noise when it should be spinning/agitating. We ran 3 loads just fine. The last load seems like it ran fine part way through the cycle. We heard a loud grinding noise coming from the washer and when we went to check it out, we saw that it had drained, was draining, and was making a loud noise. It was not agitating or spinning. We think it was on the spin cycle as the clothes were wrung out. We turned it off, unplugged it, and restarted it on a rinse cycle. It filled up, but then made the noise again and did not spin. What is wrong? Is it the pump? Clutch? Belt? We are hoping this is an easy fix.
  • 3,103 Answers
With it empty need to look at the bottom of the unit and see if the pulley and belt setup is bad.. my sisters un it broke the pulley and hers is newer..seems they dont make them to last anymore..
Posted on Feb 08, 2014
  • Bobbie Bell
    Bobbie Bell Feb 08, 2014
    Thanks, I will have my hubby look into that. He thought it might be just a belt too. We're hoping it's that simple.
  • Bobbie Bell
    Thanks for the info about the agitator too. We will also be looking into that. It sounds easy enough to fix if this is it.
    Problem Solver:
  • 14 Answers
Two great sites that have great troubleshooting info, but also 'how to' videos to do the repairs.
repairclinic.com and partselect.com
Posted on Mar 21, 2014
3 Suggested Answers
robocop
  • 90 Answers
SOURCE: Whirpool lsq9244eqo fills and drains but does not spin or agitate
It sounds like the agitator gripping teeth are worn out. To check this, take the agitator cap off with a strong knife or flat-head screw driver, pull the cap off and check the plastice teeth and four plastic hooks that grab the teeth. If they are worn out, then you will have to replace the agitator. To replace it, you will see a nut that is between the circlular teeth. Unscrew the nut and pull the agitator up hard.
Posted on Jan 19, 2009
dididsaythat
  • 291 Answers
SOURCE: Washer agitates, but makes horrible grinding noise. Spins okay.
thanks for posting problem solve :0)
Posted on Sep 03, 2007
GE Super Plus 3.2 Cu. Ft. Capacity Washer WBSE3120BWW
Go to partselect.com or repairclinic.com. Put in your model number the select symptoms or repair help according to site you are on.
Feb 08, 2014 | GE 3.2 cu. ft. Washer
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
Whirlpool heavy duty super capacity plus washer will not agitate or spin. I replaced the agitator dogs but still have the same problem, is this a transmission issue?
Your model may have a flexible (break able) drive component between the motor and the transmission. Check that, it is a pretty easy replacement.
Jan 22, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
It takes more than 3 hours to complete a cycle
Hello there:
When the cycle doesn't advance, or it takes a very long time to complete a cycle.
!st, check the timer to see if it is working properly
if not replace it '
next make sure that you are getting cold water and it is getting adequate pressure.:
here is how to check the timer .
if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Ok?
Hope this is very helpful for you
Best regards Michael
May 21, 2010 | GE 3.2 Cu. Ft. 8-Cycle Super Capacity...
Washer will not agitate but fills/drains/spins
Could be related to pressure switch which measures the amount of water in tub. Does it fill and then just sit there?
Nov 13, 2009 | GE 3.2 Cu. Ft. 6-Cycle Super Capacity...
Kenmore Washer 90 Series Super Capacity will not agitate or spin.
http://appliancejunk.com/forums/index.php?topic=3437.0
Yes, you have a direct drive coupling problem. Use this video to replace your part.
EZPZ.
Aug 13, 2009 | Kenmore Washing Machines
GE Washer Knocking During Spin Cycle
remove the agitator and inspect the main shaft on the gear box.and check the belt underneath.if the shaft is bend you will need a new gearbox. hope this helps.
Feb 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Kenmore 90 plus series: heavy duty super capacity won't agitate
this is the site to find out how to fix your washer.
you have a broken drive coupling.
it probably wont agitate or spin, but will fill and drain.
you need to remove 2 screws from the control panel, hinge it back and then remove the 2 brass colored clips that hold the cabinet to the base. once you do then pull the entire cabinet forwards to a 45 degree angle and pull it off the base.
then pull the 2 clips off pump and then 2 more on the motor. that will allow you to get to the drive coupling. you will find it to be broken.
replace it with part number 285753a for about 15-20 bucks.
Jan 31, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washing Machines Logo
341 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
