Question about Redcat Racing Volcano S30 Truck 110 Scale Nitro
How to install the redcat racing hop up kit on a volcano s30
Need to know how to install the front end of a volcano s30 hop up kit
My car starts easy first time and runs for 5 minutes then die and wont start up.
May be a simple thing sounds like fuel , check that your fuel filler cap breathe hole is not blocked , try running the vehicle without cap on a short distance to see if removing cap Cures problem. If not I would suspect fuel pump is on the fritz or maybe in line fuel filter needs repalcing
Jun 28, 2014 | Redcat Racing Volcano S30 1/10 Nitro Ready...
My volcanos30 starts easy runs for mintue then dies.then i cant get it started for about 20 minutes
Sounds heat related check seals around engine and see if any perished, sounds like as the engine is getting hot it's losing compression due to expansion,
Red light blinking
either that or it may be getting interference from another radio source like a cordless phone or old celphone..or bluetooth..any radio waves closeby will affect this..
Feb 02, 2014 | Redcat Racing Volcano Epx
The volcano breakes do not work 100% WHEN RUNNING FULL SPEED AND I PULL THE BREAK, THE Tires do not stop like the shockwave. i bought new pads, tweack the screws,,,, nothing...maybe it is normal ?
I just got my Volcano S30 Friday, breaks worked great for 1 run not full speed, second run low speed no breaks at all, adjusted the linkage as requested by red at racing breaks worked good for 1 run then same thing no breaks, manually checked the breaks by hand the pad stops like it should except the wheels keep turning and the drive shaft as well.
May 27, 2011 | Redcat Racing Volcano S30 1/10 Nitro Ready...
Engine will not stay running after i pull the glow plug ignitor off?? whats wrong? bad glow plug?
you could try a different plug, or keeping the igniter on for a bit longer, If you can find a way of getting the fuel mix checked that may help too.
Apr 27, 2011 | Redcat Racing Earthquake 3.5 1/8 Redcat...
My Volcano EPX Pro was purchased rtr. With a fully charged battery, if I punch the throttle wide open, instead of a smooth, quick take off, I get a herky, jerky start. After a couple of seconds its...
So I have the same problem with mine, and it's fairly new. It looks like its a combination of two things. One the ESC isn't working properly and needs to be replaced (hopefully the company I bought my truck from will replace, I still haven't heard back from them), and two the gearing seems to be abnormal, the team at my local hobby store recommended a small gear on the motor (the stock is 17 and the buy at the store seemed to think that it was huge) so if you get a small one (15 pinion I think is the terminology) it puts less stress on the motor. The top speed will be reduced apparently but the gearing problem is resolved. Other things they suggested where replacing the metal main diff gear with a plastic one, or lighter material one as well; hope that helps; if the company doesn't replace my esc I am strongly considering buying a new motor/esc combo from the hobby store and hopefully sort out both problems with one purchase.
Nov 15, 2010 | Electric Eyeware Redcat Racing Volcano EPX...
Redcat Racing Volcano S30 Truck 110 Scale Nitro Logo
Top Redcat Racing Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Redcat Racing Toy Expert? Answer questions, earn points and help others
