Question about Emerson Pool & Spa
Blows 20amp fuse - Emerson Pool & Spa
    New Friend:
  • 34 Answers
If pump is multi-speed (HI-Flow...LO-Recirculate) then try both positions before it blows. If it blows instantaneously on reset then bad wiring components or seized bearing in pump should be investigated. Moisture kills electrics. Sadly, spa dealers will charge both arms and a leg to send over a technician to repair/replace the faulty part(s).
Posted on Apr 02, 2015
  • Emerson Master
  • 1,631 Answers
Bad motor, shorted wires to ground, or ???
No sound on radio but it shows channels. 20amp fuse blown and new on blows when inserted
I assume you already replaced the 100amp fuse. I would say thanks a lot to the person who helped you jump your car and, don't let them touch it again. If the 20amp keeps blowing, you have a short to ground on that circuit, possibly the radio itself. Good luck.
Oct 07, 2015 | Cars & Trucks
20amp eng1fuse
Fuses will burn if the load is too high or there is a short to ground on the circuit.
You will need to use a meter, to find the issue... If you do not have the tools or rhe knowledge, take to an auto electrician... DO NOT over fuse.
.... Philip
Apr 18, 2014 | 2000 Chevrolet Express Cargo
Chevy express 1500 20amp eng 1fuse keeps blowing ?why
what does it drive - search for some shortcut/ burnt device, wear on cable insulation through 20 amps do not blow without reason. Maybe badly connected engine mass connection - check battery connections to start with
Apr 18, 2014 | Cars & Trucks
2004 Mercury Mountaineer Radio Fuse Keeps Blowing
That circuit F-2,may be shared with the cigarette lighter and it may be causing this,disconnect lighter wire and see if fuse still blows.
May 29, 2013 | Mercury Mountaineer Cars & Trucks
1987 Chevy silverado gauge / idle fuse keeps blowing
The 20amp ga/idle fuse powers a hot fuel module which powers the oil pressure switch, the fuel pump relay, and the fuel gauge in the tank.
Any of the four components including the fuel pump can blow the fuse.
Jul 23, 2012 | Chevrolet Cars & Trucks
Fuel pump fuse keeps blowing on my 95 Crown Vic
Using a smaller fuse should make the problem happen more often.
A mechanic would unplug the pump harness at the tank and check the circuit for high resistance or a short to ground.
If nothing is found in the harness, I would suspect the pump in the tank.
Jul 19, 2012 | Ford Crown Victoria Cars & Trucks
I need a diagram for the under hood fuse box. More importantly the specific 20 amp fuse labeled F21. What is it for. I have a 1998 jeep wrangler 4.0 4wd.
Are you sure that this is for 20AMP, according with the repair manual, the position 20 in the Power Distribution Center if for Power Motor ABS Pump, and is 10AMP.
Verify it..
Mar 17, 2010 | 1998 Jeep Wrangler
Blows fuse when tring maintain pressure ? Its a craftsmen pro series 150 psi 25gal on 20amp outlet with 10g wire to its own 20amp circuit breaker?
check amp requirement on compressor info plate might need 30 amp outlet also if you have it plugged into long thin extension cord it will not turn fast enough cant get current it needs causing too much draw blowing fuse try plugging directly to outlet
Dec 26, 2009 | Air Tools & Compressors
Large 20amp fuse keeps blowing
Change the fuse for the correct size AMP.
More details about Power Center Distribution, check the Section 8W Wiring Diagrams
Good luck.
Aug 19, 2009 | 1996 Jeep Grand Cherokee
Fuse keeps blowing.
couple questions -
what else is on the circuit,
and what current does the oven need
there are whirlpool over-range models with
1200watts of microwave,
1500watts of convection power, a
60watt bulb and a
375watt fan
over 15amps -20amp circuit needed
if you inadvertantly replaced a higher current fuse with a 15amp fuse, it will blow every time.
the install guide http://www.whirlpool.com/assets/pdfs/product/ZINSTALL/8206589.pdf reccommends 20amp
not a solution, something to check,
Oct 14, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Pool & Spa Logo
78 people viewed this question
Top Emerson Pool & Spa Experts
Jay Finke
Jay Finke
Mike
Mike Squire
Are you an Emerson Pool and Spa Expert? Answer questions, earn points and help others
