Question about Hawking Computers & Internet
Wpa psk xp
Should I set up as wpa or wpa-psk
adib
  • 450 Answers
SOURCE: WPA-PSK and AES
on my ipaq hx4700 , i'm only able to use wpa-psk tkip, no aes option. not sure if any difference on 5550.
Posted on Sep 14, 2005
De Guyver
  • 123 Answers
SOURCE: enable WPA-PSK
Step 1 Log into the web-based configuration by opening up a web browser and typing in the IP address of the router (192.168.0.1). Step 2 The default username is admin (all lower case) and the password is blank (nothing). Click OK. Step 3 Click on the Home tab and then click Wireless on the left hand side. Step 4 Select WPA-PSK using the radio buttons. Step 5 Enter a key (passphrase). The key is an alpha-numeric password between 8 and 63 characters long. The password can include symbols (!?*&_) and spaces. Make sure you enter this key exactly the same on all other wireless clients. Step 6 Click on the Apply button then click on the Continue button to save your settings. Note: If you are configuring your router from a wireless adapter, you will lose connectivity as soon as you click Apply. You must enable WPA-PSK on your adapter and enter the same exact passphrase as you entered on your router.
Posted on Feb 16, 2006
SOURCE: itouch wi-fi connection problem
Try this one : http://wiredforgadgets.com/?p=743. It worked for me.
Posted on Apr 18, 2008
dhruv765
  • 53 Answers
SOURCE: Laptop cannot connect to router with WPA-PSK security
What I believe here is you are not typing in the pass-phrase(wireless password) correctly.
Go to 192.168.1.1 log on to the router ,in wireless section you will find the pass phrase,, create a new one and then try to connect.
Posted on Jun 09, 2008
Joed911
  • 4338 Answers
SOURCE: Need security option
The security code is set in the wireless section of the router. You need to access the router's setup page and go to wireless. Under security you will see the encryption key which you need for your adapter.
The setup page is at 192.168.0.1. Put that in your browser.
It will open to the router's setup page.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is admin, and the password is password. Click the Ok button to log in to your router. Then go to wireless tab, then security.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
Belkin model no.f5D8236-4v2 need security key
  • Open a web browser on the computer. In the address bar of the web browser, type http://192.168.2.1 and hit "Enter."
  • login using login details..
  1. Click on "Security" in the left-hand column under the "Wireless" heading.
  • Use the drop-down menu and select "WPA/WPA2-Personal (PSK)."
Select either "WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2" as your Authentication; doing this will set the Encryption Technique automatically.
  • Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length.
  • Click the "Apply Changes" button to save the settings.
  • You've now set up WPA/WPA2 security on your network.
For reference,follow this blog-----Belkin N F5D8236-4 Wireless Router
Sep 03, 2012 | Belkin Wireless Surf Router (F7D2301)
Need to lock my connection
moz-screenshot.png Protecting your network with WPA/WPA2 security
Setup steps:
1. Connect the computer to one of the four LAN ports on the router.
2. Open a web browser on the computer.
3. In the address bar of the web browser, type http://192.168.2.1
4. Click Login in the upper right-hand corner of the page. The router does not ship with a password, so just click Submit.
5. Click on Security in the left-hand column under the Wireless heading.
6. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
7. Select either WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication; doing this will set the Encryption Technique automatically.
8. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
a. Unchecking the Obscure PSK box will allow you to see the security key that has been typed.
9. Click the "Apply Changes" button to save the settings.
Any/all wireless computers that connect to this network will be required to have this Pre-Shared Key (password).
Apr 07, 2011 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Does the gateway 2701HG-b support WPA-PSK security the label says WEP I need WPA
Yes, the gateway 2701HG-b supports WPA-PSK. Refer to user's guide here:
http://www.2wire.com/pages/pdfs/2701HG_user_guide.pdf Pages 25 to 28 will clearly show you how to set up WPA-PSK. Hope this helps.
Mar 27, 2011 | 2wire (2701HG-B) Wireless Router
Cant get the ps3 to connect to router with password that i set up...computer does just fine
change the wireless security settings options in router Security Options None
WEP WPA-PSK [TKIP] WPA2-PSK [AES] WPA-PSK [TKIP] + WPA2-PSK [AES]try this link it might help http://manuals.playstation.net/document/en/ps3/current/settings/connectwireless.html
Dec 29, 2010 | Computers & Internet
The wepkey
The WEP key is assigned by the network admininstrator.If you are the one just log in in the router set up page and assign the WEP or WPA key.
a. Un checking the Obscure PSK box will allow you to see the security key that has been typed.
Dec 18, 2010 | Belkin Wireless Pre-N (F5D8230-4) Router...
I cannot get into my router. It was set up by a Telephone tech installing the DSL line. I don't know the password and need to secure access. How do I do this?
Setup steps:
Sep 26, 2010 | NetGear Computers & Internet
Want to secure my network
go to address http://192.168.2.1
  1. click login in top right corner of the page, and then submit
  2. Click on Security in the left-hand column under the Wireless heading.
  3. Use the drop-down menu and select "WPA/WPA2-Personal (PSK)".
  4. Selecteither WPA-PSK, WPA2-PSK, or WPA-PSK+WPA-PSK2 as your Authentication;doing this will set the Encryption Technique automatically.
  5. Enter a word or group of characters in the password (PSK) box. The Pre-Shared Key must be 8 to 63 characters in length. Note: The PSK (Pre-Shared Key) is case-sensitive ("A" is different than "a").
  6. Click the "Apply Changes" button to save the settings.
Jan 03, 2010 | Belkin (F5D9230-4) Wireless Router...
When I attempt to log onto my network I receive this message. ''Windows was unable to find a certificate to log you onto the network (network name)'' This is followed by ''Validating Identity'' which when...
This is caused by setting the encryption to WPA-RADIUS instead of WPA-PSK on the client radio. Both the router and the client are
trying to find a RADIUS server with which to authenticate your system.Switch the encryption to WPA-PSK (pre-shared key) on both ends and it will work.
Oct 11, 2009 | Toshiba Satellite 2400-S251 Notebook
How to make a secure connection.So far i have an open connection. My router is Belkin_G_Plus Mimo
Open the router page 192.168.1.1 >> type this in the internet explorer address bar.
1. the Home Page is displayed. Click Wireless from the left menu
8. Changing the Wireless Security Settings
Your Router is equipped with the latest security standard called Wi-Fi Protected Access 2 (WPA2). It also supports the legacy security standard called Wired Equivalent Privacy (WEP). By default, wireless security is disabled. To enable security, you will need to determine which standard you want to use.
To access the security settings, click Security.
The Router features WPA2, which is the second generation of the WPA-based 802.11i standard. It offers a higher level of wireless security by combining advanced network authentication and stronger Advanced Encryption Standard (AES) encryption methods.
2. You can configure wireless security/encrytion settings here. Select WPA-PSK (no server) from Security Mode drop-down menu. The new page will display on next screen
3.Setting WPA Security
Note: To use WPA security, your wireless network cards must be equipped with software that supports WPA. At the time this User Manual was published, a security patch from Microsoft is available for free download. This patch works only with Windows XP.
Your Router supports WPA-PSK (no server). WPA-PSK uses what is known as a pre-shared key as the security key. A pre-shared key is basically a password that is between eight and 39 characters long. It can be a combination of letters, numbers, or characters. Each client uses the same key to access the network. Typically this is the mode that will be used in a home environment.
Setting WPA-PSK
1. From the Security Mode drop-down menu, select WPA-PSK (no server).
2. For Encryption Technique, select TKIP or AES. This setting will have to be identical on the clients that you set up.
3. Enter your pre-shared key. This can be from eight to 39 characters and can be letters, numbers, or symbols. This same key must be used on all of the clients that you set up.
Jun 11, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
Computers & Internet Logo
65 people viewed this question
Top Hawking Computers & Internet Experts
WTF Chuck.....
WTF Chuck.....
Mike
Are you a Hawking Computer and Internet Expert? Answer questions, earn points and help others
