Yamaha tt 230
When record reaches the end instead of stopping the needle jumps back to the middle of the record? Thanks
3 Suggested Answers
Grubhead
  • 5190 Answers
SOURCE: My records stop prematurely. the record stops
The only logical cause is a weak belt, as the arm reaches the center of the platter, the load on the belt becomes to great and it slips around the motor pole. I would replace the belt! Then see if it works.
Posted on Jun 20, 2010
  • 122 Answers
SOURCE: Needle keeps jumping back 4 bars on records
CHECK ANTI SKATING SETTING SHOULD BE SAME AS STYLUS FORCE ABOUT 3.ADJUST TONEARM HEIGHT SO IT IS PARALLEL TO RECORD WHEN PLAYING.HAS THE DECK HAD NEW PHONO CABLE FITTED RECENTLY IF SO THIS WILL BE THE CAUSE GET IT DONE PROPERLY.
Posted on Nov 21, 2010
DOSE ANYONE HAVE A MANUAL FOR A YAMAHA 230 DIRT BIKE H VHFH
Hi, Michelle the vast majority of service, parts fiche, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, for these rare occasions I shall look on eBay and find the cheapest one available. Most of the manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. If there is no $ sign after the manual link it is free to download for viewing or printing. To download your manual please click on the blue links below. Good luck and have a wonderful day
Yamaha ttr230 Service Manual
OEM parts for Yamaha
Yamaha TT R230 Owner Manual
Yamaha TT 230 2007
https://en.wikipedia.org/wiki/Yamaha_TTR230
Aug 30, 2017 | 2006 Yamaha TT-R 230
I have a Yamaha turntable TT-230 that I've just hooked up into a Yamaha RX-V630 receiver but the volume is very low. Will a preamp (of any sort) help solve this?
Yes - you need a RIAA preamp which equalises and amplifies the signal as it had to be encoded for the vinyl recording.
RIAA equalization
They can be cheap to very expensive, Here are a couple from ebay:
riaa preamp
Aug 06, 2016 | Yamaha Audio Players & Recorders
My TTR 230 runs at idle but right off idle runs rough and shuts off If I hold starter button down revs fine what's up with that
Hi, Anonymous and the usual suspects are:
1. Idle circuit and transfer ports clogged.
2. Air fuel mixture adjustment too lean.
3. Pilot jet clogged.
4. Faulty accelerator pump.
5. Float level too low.
6. Float bowl contaminated old fuel, water, dirt, rust, etc.
7. Float bowl vent or overflow tube clogged.
8. Fuel flow to carburetor restricted.
9. Intake manifold leak.
10. The gas cap is not venting properly or fuel tank venting system blocked.
11. Vacuum line from intake manifold to petcock broken, cracked, or not attached, carburetor vent line plugged.
12. Needle and seat stuck closed in the float bowl.
13. Multi carburetors not in sync
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
230 will not run without choke rough idle please help TTR
Dirt Rider Magazine
http://www.manualesdemecanica.com/images/files/discussion/644/6831c10187c2269620ce242953e4cbbe.pdf
http://mybikemanuals.com/yamaha/yamaha-tt-owners-manuals
May 27, 2014 | 2006 Yamaha TT-R 230
2007 Yamaha TTR 230 will not start cold
Hi, Anonymous if your bike has been sitting for some time you may need to submerge the carburetor parts (no rubber) in some "CARB DIP" that you can purchase at any automotive parts store otherwise the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
13. Faulty auto choke or wiring connection.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
How to fix my TTR 230
Bike won start normally 2005 Yamaha TT R125
https://www.partsfish.com/page/oem-parts-for-yamaha
Nov 29, 2017 | 2007 Yamaha TTR 230
Ttr 230 does not start cold
Hi, Johanvn and the usual suspects are:
4. Float needle and seat sticking.
6. Carburetor bowl vent line clogged/blocked/pinched.
7. Idle adjusting screw set too low.
8. Air/fuel mixture screw set too lean.
9. Idle port, transfer ports, slow air jet clogged.
10. Slow fuel jet clogged.
11. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the links below. Good luck and have a nice day.
How to fix my TTR 230 TTR
2006 Yamaha TT R230 cold start issues
Dec 11, 2012 | 2008 Yamaha TTR230
I need a free service repair manual for 2006 yamaha ttr230
Hi, Anonymous the vast majority of service, parts, and owners manuals on the internet are "FREE" to download and all service manuals contain wiring diagrams in the back pages. The rest usually charge a modest fee around $10 sometimes more and there is a handful of obscure, rare, obsolete, and very old models that are no longer or never were available, then there is eBay where you may be able to find what you need at a very high price because of its age and rarity. Most of the "FREE" manuals will cover your exact make, model, and year otherwise one will be provided that comes as close as possible to your bike and will have most of the same info that an exact manual would have. To download your manual please click on the blue links below. Good luck and have a wonderful day.
Yamaha TT 230 2007
Yamaha TTR230 CycleChaos
Jun 05, 2012 | 2006 Yamaha TT-R 230
Yamaha TT-R 230 adjust timing chain
Hi, Wtromp169 for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Yamaha, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
TTR230 Timing Issue and timing marks
How to adjust Timing Timing Chain Tension and Valves
Dec 29, 2010 | Yamaha TT-R 225 Motorcycles
Ttr 230 high RPM's looses power sputters / new
lOSE OFF POWER ON TOP END,IS A GOOD INDICATION OF NOT ENOUGH FUEL..TRY AQ BIGGER MAIN JET
Jul 19, 2009 | 2004 Yamaha TT-R 225
65 people viewed this question
 Grubhead
Grubhead
