Question about Kyocera Copystar CS-2560 Black and White Copier
Touch screen cs-2560
Touch screen out of calibration 1993 method not working
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
While calibrating the touch screen on my ricoh mpc 305sp I think I double taped on a wrong position on the screen and now touch screen isn't working properly. I know it still works as works in 1993 test...
I think you'll have to run a factory reset.
However, I cannot find any way of carrying this out. You'll need to contact Ricoh or their dealers, I'm afraid.
Feb 18, 2015 | Ricoh Office Equipment & Supplies
Where is pc settings/ calabrate located in lenovo c260
From page 21 of the user manual, "The monitor is touch-sensitive thanks to its touch-sensitive screen. A touch screen is an input device just like a mouse or a keyboard, and the user's fingers transmit position information via the touch screen to the computer. With this technology, you only need to touch the pictures or words on the computer display lightly with your finger, and the computer will react. Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Control Panel, select "Hardware and Sound". 2. In "Hardware and Sound" window, select "Tablet PC Settings". 3. In "Tablet PC Settings" dialogue, click "Calibrate" button. User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor. 16 User Guide 31506537 C260 UG V1.0 (Win8.1)(EN)(R).indb 16 2013-12-6 11:54:06
Nov 30, 2014 | Lenovo C260 Touch 19.5 Pent 4GB 500GB
Touch screen
After clearing the memory,or if the touch panel detection function is not working correctly,follow this procedure to calibrate the touch screen.Press the yellow reset key ,press 1993 and press red stop key 5 times to open the self diagnostics menu.On the touch screen press Touch Screen Adjust.Use a pointed tool to press the upper left mark.Press the lower right mark after it appears.Touch a few spots on the touch pannel to confirm that the marker appears exactly where the screen is touched.When you are finished press OK on the scree,touch Exit on the screen to close the self diagnostic menu and save the calibration settings.
Dec 30, 2013 | Ricoh Office Equipment & Supplies
The touch screen is unresponsive.
Hello!
Try calibrate the touch panel to see if it work.
- Press yellow key
- On the key pad press 1993.
- Press 5 times red key (stay pressing a bit longer on the fifth time)
Then you will see an option to calibrate your touch screen. You will need to press the point.
If this doent work you will need to change the touch panel.
Hope this helps. Good luck
Jul 21, 2011 | Gestetner DSm725 Color Copier
Kyocera km-2560 c6400 zero cross signal error
To reset this error hit 10871087 this will put the unit in Maint. Mode. Then press 906 then press start.Execute will appear on the screen press it. Either the machine will turn off by itself or it will say on the screen to turn the unit off then on using the power switch on the side of the unit. If the code comes back after all this either the fixing unit or the power supply are bad.
Hope this helps.
Jun 27, 2011 | Kyocera Copystar CS-2560 Black and White...
How to reset maintenance time kyocera copier cs-2560 ,
Enter "10871087" using
the numeric keys.
enter U251 Checking/clearing the maintenance count
reset it to 0
# to enter i think
Oct 09, 2010 | Kyocera Copystar CS-2560 Black and White...
Cect phone a8+ freezing
If you are talking about the touch screen not being responsive at all under normal conditions, read on.
First try calibrating it. There are 2 ways to get to the calibration screen. Please use the stylus to calibrate!
The fastest way is to be on the slide-lock screen & hold the side volume button in the Up position until
"Press volume down key to check" comes up onscreen. This may or may not work on all firmware versions
on the current i9, but works on most. Make sure to hold the button firmly in the Up position. You will first
see the normal volume speaker icon show onscreen and the volume rise, but just keep holding it Up, and
eventually you should see the pop-up box noted earlier. The moment you see that pop up onscreen,
immediately press the side volume button in the down position. A white calibration screen should now
show & you can calibrate the touch screen using the stylus. Try to tap as close to the center of the little
pulsating icons as possible, as this will more accurately calibrate your touch screen. If the calibration
screen didn't come up using that method, then you can get to it from the Main menu screen.
Select "Settings", then select "Pen calibration", & follow the previous instruction.
Apr 09, 2009 | Dual Electronics CECT P168 Cellular Phone
Kyocera Copystar CS-2560 Black and White Copier Logo
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
CheckitRight
CheckitRight
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
