Question about Janod Chic Maxi Cooker Wooden Kitchen Toy Playset for Kids
The oven door has fallen off and we need a replacement silver bracket to refix the door back together
The silver bracket has been lost
    New Friend:
  • 3 Answers
Maybe pencil sketch the other bracket or picture of it. Might be able to get another at hardware store. Menards, even a farm store might carry them. Usually little parts can be used for a chicken coop or rabbit pen. Might have luck lookin for your small bracket part.
Posted on Mar 08, 2015
Re assembling the door....
As a general rule of thumb, oven door glass assemblies are not intended to be removed for "cleaning" or some such procedure. Go to www.repairclinic.com and enter RBS275PDB8. You will be presented with a list of common replacement parts and may be able to view a generic Whirlpool oven disassembly video which may help.
Aug 15, 2016 | Whirlpool RBS275PD Electric Single Oven
Oven Door Glass -Seal has disintegrated. Is there a glue to re-affix the interior glass panel or do I need a new door?
You can usually refix the glass panel back into the oven door with the correct adhesive. It needs to be the correct heat resistant adhesive.Try http://ovendoorglue.com
Jan 13, 2012 | Cars & Trucks
The oven door has disengaged at the hinge I cannot get back into the slot on the stove westinghouse
Hi You cant do this without taking the door off the oven this is a 2 person job when it has disengaged There is a wire clip on the bottom of the K type hinge that hooks on to the top of the hinge if you can get them to hook together you can then remove the door You need to do this to both hinges lay it flat get the 2 hinges hooked together put the door back in the oven and release the hook the hook also looks like a flat u shaped bracket it depends on which westinghouse stove you are talking about as to where it is located mostly it is very close to the oven itself Regards Geoff Stove Recyclers
May 28, 2011 | Ovens
Wall oven, the front of the door has fallen off - glued on by the looks. So now instead of handle and window I now have one glass panel. I need to re glue it I presume. What glue would I use.
I am afraid that yours is a common problem. The front glass normally has some small brackets glued to the inside face, which then locate into the door frame.
This is the correct Heat Resistant Adhesive
Feb 11, 2011 | Fisher and Paykel AeroTech - OS302M...
Took apart glass oven door on a whirlpool. Where
Hello, bd_lft_up.gif bd_top_bg.gif bd_rt_top.gif bd_lft_bg.gif OVEN DOOR bd_rt_bg.gif bd_wpl_oven_door1.gif bd_wpl_oven_door2.gif clear.gif bd_lft_btm.gif bd_btm_bg.gif bd_rt_btm.gif Oven Door
#1 -- Oven door liner
#2 -- Oven inner glass
#3 -- Oven door hinge
#4 -- Retainer, glass
#5 -- Bracket, handle
#6 -- Door glass seal, top
#7 -- Door glass seal, side
#8 -- Oven outer door glass
#9 -- Door handle
#10
Read more: http://www.appliancepartspros.com/bd_whirpool_oven_parts.aspx#ixzz0pj5Z78oi
http://www.appliancepartspros.com .
Hope this helps.
Thanks
May 30, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
HI AKZ161/1X OUTER MAIN OVEN DOOR PANEL HAS COME AWAY FROM THE INNER PANEL, CAN I REFIX WITH ADHESIVE?
You need to refix it with a special high temp glue.
You can find it on E-Bay.
Type in the search box---OVEN DOOR GLASS GLUE.
There you will find what you are looking for.
Apr 05, 2010 | Whirlpool AKZ159IX Oven
The inner glass door on my zanussi oven has come
You should be able to repair your existing door. Have a look around the perimeter of the door to see if there are any screws, particularly near the handle. You are looking to take the front fascia off the door, so that you can access the inside. Most doors have the front fascia held on by small brackets glued to the back of the glass that clip on to a fixing on the internal door. The top of the fascia is normally held in place by the handle. Once you have the front of the door off you can retrieve the piece of glass that has fallen out. You will almost certainly find that the glass has come away from the adhesive that was used to hold it in place. You will need to clean up the glass and the metal door and re-stick the glass using a high temperature oven door glue
Jan 31, 2010 | Zanussi ZBF360X Electric Single Oven
Belling 351 MK2AN Oven Door bracket back plate fallen inside!!
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
Nov 07, 2009 | Belling Ovens
My oven door does not close tight
These hinges are now obsolete and you cannot get them anywhere. The poblem with this type of hinge is not with weak springs or anything like that, it is with the pivot pin in the door hinge. Follow these instructions and it will not cost you anything for the repair.
It is best to remove the oven from the housing. Remove both sides of the oven panels, you have to remove the top first, then the sides (remove about 20 screws all together). Support the bottom oven door first by tying a bit of string between the bottom and top oven door hand rails. This will stop the door falling down when you remove the springs. unhook the springs and the door will just slide out. (Use a loop of string attached to the back end of the spring to pull it from its holes.)
Dismantle the door by removing the screws. You will probably find that the the hinge pivot pins have come away from the U shaped hinge bracket. The secret is to make sure that these are fixed firm back into the bracket. What I did was to nip the U hinge bracket in a vice, (or use pliers) so that the pin will now protude slightly each side of the bracket. This allows more surface bearing area so the pin will not pull itself out of the hinge. To further make sure, I glued the ends of the pin with epoxy resin.
Then reassemble.
My door now feels like a new one even though it is 15 years old.
Sep 16, 2009 | Stoves 720EF Electric Double Oven
I have a hotpoint wm63, the door hinge broke, which i have replaced, but the nuts to fix the door back on have fallen inside the machine, i guess i eed to get inside to refix the door, but how do i do...
It is not nuts but an internal bracket. You can access it from underneath by stretching your arm inside once you have found the bracket. REMEMBER TO POWER OFF BEFORE PUTTING YOUR ARM IN!
Aug 06, 2008 | Washing Machines
Janod Chic Maxi Cooker Wooden Kitchen Toy Playset for Kids Logo
596 people viewed this question
Top Janod Clothing Accessories Experts
Da Doc
ray gallant
Bill Boyd
Are you a Janod Clothing Accessory Expert? Answer questions, earn points and help others
