Question about Tomtom Tom GO 520, 520T, 720, 720T, 730, 920,...
I cannot get the Factory reset button to light up
I am trying to get the factory reset button to light up so I can literally do a factory reset on my Tom tom 720. Not sure why particular feature will not respond
E61N
  • 515 Answers
SOURCE: Changing the written language on a tom tom go 720
Hi there..
Tip 1:
BACKUP! Please do this via explorer on your pc.
Make sure you have your explorer set to show all files,
hidden and system.
Back to your language problem, go to:
http://www.tomtom.com/support/index.php?Language=1&query=language&FID=4532
Follow instructions.
(Please remember to rate)
Posted on Apr 12, 2008
E61N
  • 515 Answers
SOURCE: tom tom go 720 product code
The Go720 do not use a product code, if the map are version 7xx
If the map you are trying to install is version 6xx, then you need to activate.
For references and How Ho, visit:
http://www.tomtom.com/support/index.php?Language=4&query=productcode&FID=2150
Posted on Apr 17, 2008
SOURCE: Tom Tom 910 Green light but does not come on.
There is a reset switch but you need to use an opened out paper clip to press the switch which is located next to the connections underneath the unit. The switch is tiny, about the size of the end of an opened out paper clip. Switch the unit of, just press the reset button once and then reconnect/switch on, and the tom tom will revert to its starting routine. It worked for mine.
Posted on Sep 04, 2008
  • 19 Answers
SOURCE: my GO 720 tom tom won't start
You need to press and hold the power button down until you see the screen come on.
Posted on Jan 03, 2009
franksguitar
SOURCE: How do I reset to factory settings
I have a Tom Tom One US/Canada Version with CE designation on the unit. The on button stays on and will not turn off and nothing on the screen at all. I even did reset even pressing the resrt sequence fr 15 sconds and on button and the unit is fully charged and is not working. Is this thing shot?
Posted on May 28, 2009
My computer will not connect to my wndr3800 router but my computer will connect to my neighbors router
The first thing that you need to do is to reset the router. The reason why you need to reset the router because that will help you to fix the problem and to know the main problem/issue.
Steps
To perform a factory reset:
  1. On the back of your router, locate the Restore Factory Settings or Reset button.
  2. Using a paper clip or similar object, press and hold the Restore Factory Settings or Reset button for about seven seconds.
  3. Release the Restore Factory Settings or Reset button and wait for your router to reboot.
    After your router is finished with the factory reset, the Power light stops blinking and lights solid green.
    Note: The Power light on newer router models lights solid white.
    The factory default settings are restored.
  4. or you can visit youtube for the video https://www.youtube.com/watch?v=nUOcjDy02ts.
Note: Once you reset the router it will be back to factory default settings and you need to setup the internet connection settings on to your router
Once your done with the hard reset try connect your computer and if your computer will have the same issue connecting to the router it only means that the problem is on your computer / try to connect other device first before you reset the router
Feb 05, 2017 | Computers & Internet
The light doesn't work and I read nightly. Can it be fixed?
Try a factory reset: To factory reset the glo: hold the power button ON for 15-20 seconds to make sure it is off. Press and HOLD the light button while turning on the Glo. That should put you into a factory reset if that will solve the problem (no guarantees but it has worked for others in the past).
Mar 31, 2015 | KOBO, INC Kobo Glo
Reset factory settings on hp deskjet 1050
Reset the Printer to Factory Default Settings Restore factory settings Restoring the factory-set defaults returns most of the settings to the factory defaults. It will not reset the page count, tray size, or language. To restore the product to the factory-default settings, follow these steps.
  1. Turn the product off. Disconnect the power cable from the product for 30 seconds and then reconnect.
  2. Turn the product on while you press and hold the Resume c02469297.gif button for 10-20 seconds. The Attention c02469293.gif light turns on.
  3. Release the Resume c02469297.gif button. The Attention c02469293.gif and Ready c02469296.gif lights cycle while the product restores factory defaults.
Reset HP 1050 DeskJet Series Cartridge
Jun 07, 2012 | HP Office Equipment & Supplies
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
How to format HTC WILDFIRE A33333
Factory reset is not a step to be taken lightly. It will permanently delete all your data and customized settings, and will also remove any applications you've downloaded and installed. Be sure to back up any data and files you want to keep before you do a factory reset
Performing a factory reset via settings:
The most convenient way to do a factory reset is via the phone settings.
From the Home screen, press MENU, then tap Settings.
Scroll down the screen, and then tap Privacy > Factory data reset.
On the Factory data reset screen, tap Reset phone, and then tap Erase everything.
Performing a factory reset using phone buttons:
If you cannot turn on your phone or access the phone settings, you can still perform a factory reset by using the buttons on the phone.
With the phone turned off, press and hold the VOLUME DOWN button, and then briefly press the POWER button.
Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
Press VOLUME DOWN to select CLEAR STORAGE, and then press POWER.Press VOLUME UP to start the factory reset.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response.
Thanks, Joe
Feb 25, 2011 | HTC Computers & Internet
How do I reset my Linksys WRT400N Router to factory defaults
Reset There are two ways to reset the Router's
factory defaults. Either press and hold the Reset
Button for approximately five seconds, or restore
the defaults from Administration > Factory
Defaults in the Router's web-based utility.
There should be a small hole with a red circle around it on the back of the router next to the power plug hole. Use a pin or straighten paper clip to push the tiny button.
Jan 11, 2011 | Linksys WRT400N Router
Hp rx4540.How to access the Boot loader mode?? .My ipaq just displays the hp logo on start up and then just freezes.Ive tried soft and hard reset.Help please
A factory reset erases all user-installed settings, programs, and data, and restores your HP iPAQ to factory settings.
CAUTION All user-installed settings, programs, and data are erased from memory with a factory reset.
To perform a factory reset and return your HP iPAQ to factory settings:
  1. Press and hold the OK and Rotate Screen buttons.
  2. While holding these buttons, use the stylus to lightly press the Reset button on the HP iPAQ until the device restarts.
  3. When the HP iPAQ restarts, release all of the buttons, and then remove the stylus from the Reset button.
The HP iPAQ will now restart and power on.
If you have done the above and still no go. Then your main drive has probably failed.
Link below is a repair how to video
http://www.wonderhowto.com/how-to-repair-hp-ipaq-rx4200-rx4240-rx4500-rx4540-243534/view/
Mar 11, 2010 | HP iPAQ rx4240 Pocket PC
Changed ink, cleaned cartridge area, turned printer on and off, still have an error code 1203. what is my next step?
Hi there can only try and I hope it will do the job for you.
Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Or try
Reset Factory Defaults on the Dell™ 962 Printer
To reset factory defaults on the printer, perform the following steps:
  1. Press the Mode button several times until the Copy LED is lit.
  2. Press the Menu button until Set Defaults is displayed, then press the Select button.
  3. Press the right arrow button until Restore Factory Defaults is displayed, then press the Select button. The printer will ask for the date, time and language.
  4. Enter the time, date and language, the press the Select button.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 15, 2010 | Dell 962 Photo All-In-One InkJet Printer
Password
To remove all the settings of the used modem router, most modem has a reset button and need a paper clip end to press it. If you want to reset the modem to factory default, most likely you:
  1. having power on the modem, press and hold the reset button for at least 10 seconds (or until lights on front starts blinking)
  2. this is most common practise in programming the modem chips.
If that doesn't do, try:
  1. unplug power cord of the modem
  2. press and hold the reset button
  3. plug in the power cord
  4. wait for about 5 seconds then release reset button
If still not able to reset it to factory default, ring the manufacturer's Tech support and get them to help you "reset the modem to factory default".
Apr 11, 2009 | Actiontec GT704WG Wireless Router...
How to Factory reset Firebox X20e edge
To set the Firebox X Edge e-Series to the factory default settings:
  1. Disconnect the power supply.
  2. Hold down the Reset button on the back of the Edge.
  3. Continue to hold down the Reset button, and connect the power supply.
  4. Hold down the Reset button. When the yellow Attn light stays lit, the Edge was successfully restored to the factory default settings.
    This process can take 45 seconds or more.
  5. Release the Reset button.
Do not try to connect to the Edge at this time. Before you can connect to the Edge, you must start it one more time. If you do not, when you try to connect to the Edge a web page appears with this message: Your WatchGuard Firebox X Edge is running from a backup copy of firmware. You could also see this message if the Reset button is stuck in the depressed position. If you continue to see this page, check the Reset button, and start the Edge again.
  2. Connect the power supply again.
    The Power Indicator lights and your Edge is reset.
Sep 02, 2008 | Computers & Internet
Tomtom Tom GO 520, 520T, 720, 720T, 730, 920,... Logo
Top Tomtom GPS Experts
Martin Murray
Will Halftowaite
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
