Cars & Trucks Logo
Matthew Jordan Posted on Feb 08, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Anti Theft Alarm
I have a 2000 Chevy Blazer, recently after two successive snow storms I started my Blazer and the anti theft light blinks and the alarm sounds for three cycles then quits. Is there a way to disable the audible as it is very embarrassing starting your vehicle and the alarm is sounding and everyone looks at you.
Bill Boyd
Level 3:
Top Expert:
  • Chevrolet Master 53,816 Answers
  • Posted on Feb 08, 2014
Bill Boyd
Chevrolet Master
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11948358
Points
172802
If you disable your alarm system because of embarrassment ( a poor excuse for too lazy to fix) imagine your inconvenience when someone steals the vehicle because you didn't hear it go . IT may be a simple thing such as resetting the CPU with a code reader or going to a good auto electrician or chevy service centre to have it fixed
  • Matthew Jordan
    Matthew Jordan Feb 08, 2014
    My apologies if I made it sound that it was just laziness that prevented me from getting it fixed. I was more looking for a temporary solution until I came up with cash because everything I had read before I posted was pricey fixes.
  • Bill Boyd Feb 09, 2014
    It is always best to ask around and get advice from accredited auto electricians and to run the fault codes first . You can get an idea of prices as you ask and mostly it will be exactly for the fix.
3 Related Answers
Anonymous
  • 3 Answers
  • Posted on Feb 05, 2009
SOURCE: 2001 ford taurus wont start and anti-theft light is blinking
Either you may be using a key that you had copied from the original or your chip went bad in your original key. Most of cars now a days have the key censor in the key so if it is the incorrect key it will not start your car or if it does not read that chip it will not start
Anonymous
  • 783 Answers
  • Posted on Feb 16, 2009
SOURCE: 2000 ford windstar anti theft light flashing vehicle won't start
This means that your key is not being recogonized.Ethier the chip in the key is bad or the patts transciever at the lock cylinder. Do you have a spare key? If not you will have to get 2 new keyss cut and programmed.
Anonymous
  • Posted on Aug 17, 2009
SOURCE: 1999 VW JETTA anti-theft alarm keeps going off & car won't start
pop the truck and the alarm will disable
Chevy Blazer. I have no spark and no fuel on my Blazer. I have been told it is because the anti theft light is on?
Question edited for clarity.
Yes Samantha, that could be exactly the case. If the anti-theft light is on and activated, you get no no spark or fuel so no start.
https://www.google.com/search?q=chevy+blazer+security+reset
2ooo chevy impala no crank anti-thieft problem
Turn the key on and leave it on until the theft light blinks or goes off.It should start then.This could take 10 to 20 minutes.
99 explorer alarm disables. Motor dies
Anti-theft system can keep vehicle from starting , Alarm is for vehicle content theft , open door without key alarm sounds (horns) ! PATS - passive anti theft system PATS enables and disables the engine from starting ,it will not cause the engine to die ! You have some other kind of problem ! If the vehicle engine doesn't turn over an red light on top of dash flashes fast ,then you have anti-theft system problem !
PATS differs from the perimeter anti-theft system in that PATS enables and disables the engine from starting. If equipped, the perimeter anti-theft system protects the perimeter of the vehicle (doors, hood and trunk) and sounds an alarm.
Why wont my alarm reset in my 1998 chevy blazer the security system is killing the fuel and i cant get it to run it starts and dies imeaditly
I don't think the anti-theft is the problem.
On GM vehicles, the anti-theft system will not allow the engine to crank, or get fuel or spark. If it cranks, you have a different problem.
2answers
Anti theft wont let me start car
The problem may not be with anti-theft but with a bad fuel pump,cam/crank sensor etc. Also, you may try unlocking the drivers door with the key. On most cars that is the standard method for disabling the security system.
Reset anti theft system 2007 Chevy Malibu
Here are two methods to reset the anti-theft system on 2007 Chevy Malibu:
1st method
1. Put the ignition in on position, let it breathe for 10 minutes, and remove it when the anti-theft system light stops blinking.
2. Crank up the engine; it should now start
2nd method
• While outside the car, press and hold the lock and unlock button together
• Let go when the car honks and the lights flash
• Put the key in the ignition and rotate to the ON position, and leave there for 30 seconds
• Switch on the car, and the anti-theft system would have reset
2000chevy blazer changed battery then anti theft light came on blinking and won't start
u have triped the anti-theft reset as follows(try to start leave key on fo 11 min. and it should start)
5helpful
07 ford focus anti theft light flashes all the time
If the security or anti-theft light is flashing when you attempt to start your car, and the engine does not crank or does not start, you have an anti-theft problem. The system may not be recognizing your key's key-less entry signal, or there may be a fault in the anti-theft module or wiring.
There is a reset procedure to stop this anti-theft light flashing.many a times this helps The reset procedure is as follows:-- Reset the alarm by locking and unlocking the drivers side door.Do this a couple of times and then check it will reset the factory security system . If the reset procedure does not helps then its time to get the anti-theft system checked.There is a short circuit in the anti-theft system wiring. For more detailed help on this anti-theft light blinking issues please click on the link below http://www.aa1car.com/library/troubleshoot_antitheft_system.htm
Thanks. you can rate this solution and show your appreciation.
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
