Question about Dryers
Maytag commercial dryer
Can't get it off of blinking 196 then 255 when I open the service door and want to change the price per load
dinomb
  • 16 Answers
SOURCE: Maytag Electric Dryer Stopped Working
Check spring tab behind door switch-if it's bent/out of adjustment, circuit will act like door is always open.
To confirm this, open door, set dryer to active setting, and hold in door switch; if it comes on, then it's either the spring tab, or the switch is malfunctioning
Posted on Mar 30, 2008
  • 58 Answers
SOURCE: maytag performa dryer takes a long time to dry clothes on auto
What you have is a obstructed dryer vent. If you remove the vent hose from the unit you will see moisture inside it. This is why your unit isn't drying. If the heater has no air flow the overload is tripped. Check your vent for any blockage most of the problem is at the outside end of your vent. there's a flap or chicken wire you may find the obstruction there. Or you can use a leaf blower connect it to the inside vent, cover the outside vent with pantyhose. ( so you don't get lint allover your yard ) and you can clear your like that way. Good luck hope this helps
Posted on Jan 10, 2009
WRMtech
  • 70 Answers
SOURCE: during the drying cycle, the dryer door opens
Chances are the little plastic latch keep is broken. Look at the door and locate a peice that will press into the front area where the clothes go in.
Once you see it, check the keeper and see if it is broken. The door should not just pop open.
Posted on Feb 26, 2009
Illeagle
  • 525 Answers
SOURCE: I have a maytag neptune dryer. When I open the
Issue:
I have a maytag neptune dryer. When I open the door it doesn't turn on . What could be the problem?
Solution:
This is normal! The dryer has a door switch that will prevent it from operating with the door in the open position. This is a safety feature and cannot be overidden.
Posted on Aug 17, 2009
hunter19_46m
  • 7482 Answers
SOURCE: how to open up dryer to change belt
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to replace your drum belt and if you have a front loading machine.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Also remove the screws from the lint filter.
Be real careful not to knock any of the wires off of the timer switch. Then remove the top of the dryer.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
I will include these two websites for parts and further help:
http://www.partselect.com/
http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good luck,
I hope this helps
Please do not forget to rate me
Thank you
Posted on May 30, 2010
Testimonial: "Hunter Thanks for the help. It was fairly easy to change the belt, only problem was trying to figure out the route as the old belt broke and fell off. We seem to have done it correct.The dryer is works great.Thanks"
How do I change the price setting on a matag model md630pc2aw
YOU TAKE OUT THE BLANK THAT IS WHERE A COIN SHOULD GO AND THEN YOU PUT IN A QUARTER SLOT PLUG,GO TO SEARS FOR BLANKS.
May 30, 2014 | Maytag MDG16PD Gas Commercial Dryer
Error code d5 maytag
indicate problems with the door lock assembly communicating with the control board. Essentially, the control board does not beleive the door is closed and/or locked, so it shuts down the machine.
Here is the service manual which will tell you how to do some testing of the door lock, but in the end you may need both a control board and a door lock assembly. The good news, they are easy to change out, the bad news, they are expensive parts so you want to be as sure as possible before you buy and install.
http://www.servicematters.com/maytag...s/16026126.pdf
Mar 29, 2012 | Maytag MLG15PD Gas Commercial Dryer
Having problems changing the time per quarter on my maytag commercial dryer
you need to change the wheel on the side to make the time longer or shorter.You can get these wheels and an appliance parts store
Sep 19, 2011 | Maytag MDE16CS Electric Dryer
Dear sir, We want to buy 02 nos of whirlpool make 8.5 kg washer 02 nos and one nos of dryer. We need the same for our factry on contineous operation so we want the best...
Hi and welcome to FixYa, I am Kelly.
I understand you want a whirlpool washer. What are you washing? It does make a difference on what would be recommended. The other question is does it have to be a front load machine or is a top loading washer ok?
Right off the top of my head for an 8.5 kg washer I would recommend the top loading MAT Series by Maytag (owned by Whirpool) These manual timer machines can take a beating and over loading only causes belt wear that is inexpensive and easy to replace. The only drawback is that the top loading machines use more water per cycle than a front loading machine. My thought is this... water is cheap... smaller front loading commercial machines used in continuous manner end up costing you more in repairs than you would pay for the water.
Product info: http://www.maytagcommerciallaundry.com/on_premiseslaundry/top_load_washers/commercial_energy_advantage__8482__top_load_washer_mat15mnaww.pro?scr=category
Once you see the linked pages select "on premises lanudry"
What I will tell you about commercial laundry machines is this. Keep the controls simple such as the MAT series. Maintenance parts are available on line and your down time will be minimal. The Maytags have the best warranty also.
As for the dryer Gas or electric? I am going to assume electric since you said "Factory"
For this I would recommend the MDE17 series Dryers, The dryers are 4 roller drum type dryers so the weight is carried equally front and rear of the drum so that the drum seals have a very long life.
I have been a Maytag repairman since 1970 and started in a family owned business. These recommendations are from years of experience. You may pay more up front on the initial purchase but over the years the continued in service time and minimal maintenance required make these units extremely cost effective. If I were to start my own business with 8.5 Kg per cycle washing requirements The MAT Washers and MDE Dryers Maytags are exactly what I would use.
Remember Maytag was purchased by Whirlpool years ago.
All Maytag parts can be obtained through Whirlpool.
I do wish you the best, Thanks for choosing FixYa,
Kelly
Dec 12, 2010 | Whirlpool Washing Machines
Can you change the door direction on a Maytag
Unfortunately, you can only change front loading dryer door directions on some models. Washing machines do not allow this. If the units are stacked i may be easier to switch loads, otherwise the dryer door may be able to have the door swing direction changed but without the Dryer model # I couldn't say for sure.
Dec 29, 2009 | Maytag EPIC MFW9700S Front Load Washer
Does not dry my clothes well and only had it 28 days
check your filter[clean if dirty]-check & seeif your vent is plugged-check to see if the vent doors outside the house open when dryer is on -[also maybe proppeler might have become stuck or loose, it sounds like a plugged vent problem.
Dec 22, 2009 | Maytag MEDC400V Dryer
Maytag Dryer Wet Inside
callieco
Ngfam1 at your service
The water perhaps came in through the outside vent! check the vent cover outside that it is still on and in place! And not stuck open if it is a swinging door type!
If its off or open it may have been wind swept rain coming in the vent pipe !
If still no start!
Try unplugging the dryer for 10 minutes and then to plug it in and attempt to restart it!
Let me know if this helps!
If you need service here is ,
A&E factory service which is nation wide and open for appointments 24/7
They due most warranty work too!
Bless You,
ngafam1
Please leave me a good rating here at fixya.com before you sign off!
Sep 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag MLG23PD Gas Commercial Dryer
605 5 quarters to start 712 12 minutes per quarter if yu want 1 quarter to start dryer change to 601. if yu want dry time to be 8 minutes change to 708 press whites and colors to select value and then press permanent press to go to next code.
Apr 19, 2008 | Maytag MLG23PD Gas Commercial Dryer
Dryers Logo
11 people viewed this question
Top Dryers Experts
