Question about Pool & Spa
Spa has 20amp fuse that blows whenever I either restart spa or turn on jet pump. I disconnected pump and it ran fine until I restarted the spa and fuse blew again.
It has new vertical low flow heater and circulation pump.
    Champion:
  • 305 Answers
Something is drawing a load when it shouldnt be. remove all circ pumps, booster pumps, and disconnect heater element. turn on hot tub and see if it trips. then do the same, re connecting the element, and pumps, one at a time. when it does trip, thats where the problem lies. bad pump or element
Posted on Feb 13, 2014
  • Kev McCauley
    Kev McCauley Jun 24, 2014
    check the total head, (water resistance if a high head si exists it will cause the pump to draw over 20 amps on start up
4 Suggested Answers
PartsCenter
  • 125 Answers
SOURCE: Spa water drains to pool
Here is a link to the Aqualink website so you can download a trouble shooting guide.
Posted on Feb 26, 2009
PartsCenter
  • 125 Answers
SOURCE: We just moved into our home and there is no manual
Here is a link for the Manual and trouble shooting guide. Aqualink
Posted on Mar 04, 2009
  • 19 Answers
SOURCE: pool and spa heater will not turn on, low pressure on display
1) check the fuse on the transformer. You will get "low pressure" if the fuse is blown.
1a) remove front panel with flat head screw driver turning both big screws 1/4 turn clockwise
1b) look up under the 1 remaining front piece for 2 screws (one on each side). remove them and the 1 small panel slides down
1c) transform is directly in the center of this compartment
1d) red wire on transform has a black fuse case - twist open and check fuse (with an ohm meter it should read a dead short if it is working).
1e) if not working - replace with standard 250v 2a bus fuse.
2) it really is low pressure
2a) backwash pool or at least make sure pressure in filter take is not too high (high filter tank pressure == low water pressure in heater)
2b) if you have a bypass valve make sure it is not in bypass mode so most all pressure from the pump is going tothe heater
2c) right next to the transformer is the pressure switch. It has a small copper tube attached to the back and 2 wires in the front. Put an ohm meter across the two leads on this device. With the filter off it should be open, with the filter on it should be closed (short). If not either the copper tubing is clogged, the switch is faulty, or there is not enough water going through the heater. The amount of water that goes into the heater is adjustable and the water pressure switch is also adjustable. The owners manual explains how to adjust both but neither should need adjustment unless you have a special configuration (explained in the manual).
Posted on Sep 20, 2010
How do I find out what is causing the electric to trip when I turn the water jets on , in my hot tub
what ever pump turns the jets on is probably locked up disconnect the wires to that pump and try it again if it doesnt blow the fuse then you need a new pump
Sep 09, 2014 | Pool & Spa
Blows 20amp fuse
Bad motor, shorted wires to ground, or ???
Feb 08, 2014 | Emerson Pool & Spa
My new flo-master xp2 spa pump will not engage the low speed. The hi speed (jets) works fine but the low speed doesn't engage. I just hear a clicking and nothing comes on.
if you had ice in it and it was powererd up.. you may have burned out the start capacitor or even the start windings..why was it iced up while working on it..it should have been freewheeled by hand before startup..I just got a tub in here.. had to wait 6 days for it to thaw out..(sign of good insulation) we just ran it for the first time yesterday..got some seals to replace and some switches to repair..
Jan 08, 2014 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
My hot blows the fuse just as soon as I turn it on, I unhock the heater and it still blows the fuse. How long is the motor gauntee for Flo Msater XP2-551521
1 year.
If you disconnect the jet pump plug from the control box can you turn on the service and not blow it again? That would be the easiest way to confirm a motor failure is your problem.
John
Oct 17, 2010 | Aqua Flo Aquaflo Flo Master Xp2 Spa Pump...
Jacuzzi Laser II: Problem with the Heater/filter setting. The jets come on when it's on this setting. When I turn it to Filter setting it's fine..when I turn it off the jets come back on What gives?
The jets will run while in the filtration / heating mode. If the spa is in the middle of the filtration cycle, the jets will stay on until the cycle time runs out. So, if the spa jets are on during this time, they are on for the full duration, 2-6 hours every 12. You can cycle the jet button to high, but when you try to turn them off, they will just go back on low.
Jan 23, 2010 | Jacuzzi Cyget In Ground Pool Pumps
Pool & Spa Logo
158 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
