Question about General Electric WHDVH660H Front Load Washer
GE front load not filling, door locks ok
After electrical surge (power line fell into house and common was lost) washer made burnt electronics smell and will not fill with water or move drum. Checked lint filter - it was clean. Water supply to washer is good. Any ideas?
    Prodigy:
    An expert who has answered 500 questions.
  • General Elec... Expert
  • 517 Answers
Need to check the program board
Posted on Feb 08, 2014
4 Suggested Answers
jumptrout51
  • 3361 Answers
SOURCE: ge washer
Pull up sharply on the agitator to remove it from the shaft. Check the agitator mounting cup underneath it is probably stripped out. It is a replaceable part.
If the agitator is difficult to pull up,use a old strong leather belt under the agitator and pull it off using the belt.
Posted on Nov 08, 2009
  • 11 Answers
SOURCE: I have a GE whdsr209 washer. Stuck on filling with water.
Ok, take a deep breath and blow....
No, really...
Ok, to understand how to fix the problem you have to understand a little bit about the control part of the machine.
Ok so here we go...
First thing is the first stage which is filling the machine with water.
So how does the machine know how much water to fill, well the answer is pressure.
If you remove the front panel of the machine and look on the side of the tub, you will see a tube attached to a plastic hull.
Air gets trapped inside the hull and as the water fills the tub the pressure inside the hull increases. The tube attached to the hull routes the pressure building inside the hull to the fill pressure switch. The more water filling the tub the more pressure generated and supplied to the switch.
If the line becomes clogged with buildup or developes a leak, the whole process will not work, thus the switch will not become engaged stopping the flow of water into the machine.
How do you check for opperation of the line and switch,
well remove hose from hull and as the tub is filling with water, blow into the tube creating pressure and thus activating the pressure switch..
You will hear the switch click and the machine should stop the fill process and start washing.
Rarely but possible, the pressure switch is faulty.
Mostly, it is a clogged line, disconnected line, or line that has been damanged by rodents or pets..
Hope this helps
Good luck...
Posted on Jul 28, 2010
SOURCE: I have a GE model #WBVH5100HWW front loading
Crecco610@gmail.com
Posted on Apr 28, 2012
GE GFWS3500LOWW not starting on any cycle
GE Washing Machine GFWS3500L0WW Troubleshooting ...
www.repairclinic.com/...-/GE-Washing-Machine-GFWS3500L0WW-Tr...
GE Washing Machine GFWS3500L0WW ... Washer fills slowly · Washer leaking water · Washer won't start · Washer won't spin or agitate · Washer overflowing ...
Repair Help - Model Help Repairwww.searspartsdirect.com/ge/washer/model-gfws3500l0ww-repair.htmlRepair Symptoms for GE Washer Model #gfws3500l0ww. Shop Parts ... Slow or noagitation or spinning ... Not working at all ... Clean Washer cycle won't work.GE front load washer door latch Repairwww.appliance-repair-it.com/front-load-washer.htmlIf your GE front load washer has a door latch problem such as the door will not lock or... You should always use HE detergent on any front load washer. ... manually unlocking the door and pouring cold water into the tub then start a new cycle.GE Front Load Washer Service modewww.appliance-repair-it.com/GE-front-load-washer.html
Jan 28, 2016 | GE Washing Machines
House fuse blew last night
Plastic lead inside front of soap dispenser unlocks door.
Remove front panel, undo top panel & lift up, check wax motor (red / brown unit above / top of door), usually burnt out taking control board with it. If you are going to repair fit 5 amp fuse in line with wax motor or fit later model door lock mechanism.
Dec 08, 2013 | Maytag Neptune MAH5500B Front Load Washer
Lid Locks- Fills for 2 seconds and stops
see this causes and fix it. God bless you
Door or Lid Latch Assembly If the washer lid won't lock the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer door won't lock the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Main Control Board If the washer door won't unlock the problem might be the main control board. This is not common. Normally the problem is with the lock mechanism.
Oct 11, 2012 | Maytag Bravos MTW6600T Top Load Washer
I has a Crosley Washing Machine Top Loader. Fill light comes on lid locks then NOthing!
seethis causes and fix it. God bless you
User Control and Display Board If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
Timer If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this time
Line Fuse If the washer won't start the line fuse might have blown.
Thermal Fuse If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Line Fuse and Holder If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
Main Control Board If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
Door or Lid Latch Assembly If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Incoming Power Problem If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the hom
Power Cord If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Oct 02, 2012 | Crosley CCW5294W Top Load Washer
I have a GE washing machine model # WCSR2090DAWW and today I went to put a load of clothes washing. It filled the tub up with water like normal and then went into soak mode. The problem starts when it...
Possible that some item of clothing is jamming up the drive to the tub. The burning smell are the motor windings reacting to the excess of electricity flowing thru them before they burn out.
Apr 02, 2017 | GE Appliances 3.5 cu. ft. King Size...
GE Adora door locked after power surge and can't get it to unlock and come on
You probably need to replace the door lock mechanism. Try unplugging it and then plug it back in. If that doesn't work, you probably need a repairman, or someone with more electronic feature knowledge.
Dec 24, 2009 | GE WSXH208A Front Load Washer
GE front load washer, wbvh5200j1ww. no power.
the door can be manually unlocked by removing the bottom front panel, reach up and there is a pull tab on the lock mechanism. it is a crime that they do not post this online or in the manual, and let folks ruin their clothes.
power problem was a part called the "FILTER" it is where there power cord plugs into, something along the lines of part number 201. cost is $85 plus tax. service man has not seen one of these ever go before.
Dec 07, 2009 | General Electric WBVH5200J Front Load...
Front loading ge washing machine only 2 months old. door locks,
take water lines off of water valve at rear of unit and clean dirt out of screens.
Jun 19, 2009 | GE WSXH208A Front Load Washer
Kenmore front load washer 3.5 cubic feet
Power line are shorten/put clamp meter on line of the power cord monitor during staet button it go high amphere motor or line have problem, testmotor clamp one line of motor start having high amphere the motor have problem , test capacitor if open replace it /check motor smell smell burning if none test coontinuity if ok capacitor is problem.
Mar 17, 2007 | Kenmore 44832 Front Load Washer
General Electric WHDVH660H Front Load Washer Logo
66 people viewed this question
Top General Electric Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a General Electric Washing Machine Expert? Answer questions, earn points and help others
