Question about Sportline 965 Pedometer/heart Rate Watch
Pedometor won go past 10,000 steps and stops
Why does it stop after that and wont count anymore
How do I go about fixing a reving issue on my bike? It doesnt like to rev past about 10,000 rpms. I was thinking maybe the carbs need to be rejetted. The bike will rev to redline in neutral.
Hi, Ani and the usual suspects are:
1. Severely drained or faulty battery.
2. Faulty regulator/rectifier or high output coil.
3. Faulty power valve, solenoid or installation.
4. Clogged air filter or exhaust.
5. Cracked or incorrect float level.
6. Float needle is not seating.
7. Faulty reed valve.
For more information about your question and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
02 GSXR 750 won rev past 8k
2002 750 wont rev past 8000
Wont rev past 10000 RPM
http://www.suzukigsxr.cz/docs/Suzuki_GSX-R_750_96-99.pdf
May 21, 2016 | Power Motorcycles
Can anyone tell me how to step by step take apart Panasonic DVD-S25 to get to the motor to get the ho7 to popping up the dvd will play thru then stop spinning which wont read dics anymore
hi there it could b a fault in the cpu ..if it is its not worth fixing...have a look on e/bay u can buy them for $10 to $20 dollars working good luck.........
Sep 18, 2015 | Panasonic Televison & Video
Reset ecu on Nissan hardbody 2006 model.stoped it at home,now wont start.maybe for second or two.Nats light not working on dash. keys still opening doors,enjin turning,does not start.enjin check light
Give this a try.....Timing is not as critical with this method...no stop watch needed. Just count in your head...one-one thousand, two-one thounsand, etc, or usestop watch. The most critical step is step #3....wait 10 sec, instead of 7.
1. Ignition "ON", count to 3.
2. Depress/Release pedal 5 times...hard and fast.
3. Count to 10 (not 7!) and fully depress pedal
4. Count to 12 (SES should be blinking), release pedal
5. Count to 10, depress pedal
6. Count to 10, release pedal.
7. Turn off ignition, then 81377951893%26mt_id%3D570%26mpre%3Dhttp%253A%252F%252Fwww.ebay.com%252Fitm%252Flike%252F181377951893%26mid%3D446528%26sdc_id%3D%7Bsdc_id%7D&DealName=12v%20Electric%20Push%20To%20Start%20Engine%20Ignition%20Button%20With%20Red%20Led%20Light%20Up&MerchantID=446528&HasLink=yes&category=0&AR=-1&NG=1&GR=1&ND=1&PN=1&RR=-1&ST=&MN=msnFeed&FPT=SDCF&NDS=1&NMS=1&NDP=1&MRS=&PD=0&brnId=2455&lnkId=8070676&Issdt=150102050536&IsFtr=0&IsSmart=0&dlprc=19.99&SKU=181377951893">start engine. Done!
Jan 02, 2015 | Nissan Cars & Trucks
Why does my pedometer goes into sleep mode ewhen I stop and wont go back on when I start walking again. What do I havwe to do to get it started again?
This pedometer is programmed to go to sleep for a couple of reasons.
  1. To save battery life.
  2. To not inadvertently add steps to jostles or shakes. This pedometer has been programmed to only start counting steps at your 10th step from the sleep mode. This is to help with the accracy of the device.
May 08, 2014 | Ozeri 4x3motion Digital Pocket 3D...
Won't read any kind of disc it spins and stopped like 3 times and doesn't move anymore
Sounds like you later lens has been damaged or is dirty. There is a cleaning kit at Walmart. If that doesn't work, google a local repair shop.
Feb 16, 2013 | Video Game Consoles & Games
Car slowed down and stopped now won't start
see if the timing belt\chain is broke,normally when it brokes the car slow down and stops and dont start anymore.
Nov 13, 2012 | 2004 Volvo S40
Konica Minolta bizhub 163 Display M2. and not functioning Photocopy. Please sugest me ?
Code M2 means your photocopier machine require maintenance.In maintenance some old parts of your machine will be replaced with the new one and all this will be performed by technical services representative.
Dec 29, 2010 | Sharp AR-5320 Black and White Copier
D8o's shutter count up to end.. where i can fix it in the phils
Hi lixia_pogs, if you are speaking about the 10,000 number the camera count, on obtaining 10,000 it will flip over then again starts at 1. Your camera will continue to work as it always has. Hope this is what you were looking for
May 28, 2010 | Nikon D80 Digital Camera with 18-135mm...
LAPTOP DVD DRIVE WONT PLAY DVDS ANYMORE
Drive is on its way. Typical behaviour. Try air dusting lens but unlikely to fix it. Very easy diy repair and cheap. EBay the new disc drive or refurbished. Then go to youtube. Nearly all laptop drives are the same to replace no matTerry brand. You could even get a faster drive.
Mar 05, 2017 | Televison & Video
Sportline 965 Pedometer/heart Rate Watch Logo
Top Sportline Exercise & Fitness Experts
Ansel Alberto
Ansel Alberto
Are you a Sportline Exercise and Fitnes Expert? Answer questions, earn points and help others
