Question about Vitamix Blenders
Replace ball bearing
How to assemble th bearing and blade assembly on a vita mix 5000
  • Vitamix Master
  • 1,631 Answers
Need special tool:
check here:
Amazon com vitamix wrench assembly Home Kitchen
Posted on Mar 16, 2015
asktate
  • 15 Answers
SOURCE: need repair/service manuals for vita mix blenders
Here you go:
"http://www.payloadz.com/go/sip?id=889319"
Posted on Jun 11, 2009
  • 351 Answers
SOURCE: Replacement parts
This site should have what you need ..
http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=4287&secid=53&linkon=category&linkid=91
Posted on May 09, 2010
SOURCE: I need to replace the
abtec has Back to Basics appliance parts including parts for Back to Basics coffee ... PARTS AND ACCESSORIES FOR BACK TO BASICS BLENDERS AND SMOOTHIE MAKERS ...
www.abtecparts.com/
Has blade assembly
Posted on Jun 06, 2011
  • 244 Answers
SOURCE: How do I fix or
Make sure the blade assembly is put together in the correct order. The blade needs to go through the gasket so that the order is pitcher glass, gasket, and metal blade base. Then the final plastic cap threaded onto the pitcher. If the gasket is not between the pitcher and the metal blade assembly, you will have leaks.
Also, check the gasket to be sure it's not cracked and that it doesn't have residue on it.
I hope this helps. If it does, please come back and rate my suggestion!
Posted on Jun 16, 2011
ZJLimited
  • 17970 Answers
SOURCE: looking for instruction manuel Vita-Mix 5000
I suggest try in www.vitamix.com/index. Here the Vitamix Brochure (pdf)
Hope this helps.
Posted on Jul 11, 2011
I have a vitamix 5000 unit. Blade assy makes noice ; is loose. Where can I buy the set of bearings for the blade assembly?
You will need to source them from a bearing supply company as Vitamix only supply the bearings as a complete unit with the blade assembled. Once you have the bearings out take the sample with you to the bearing supply company for correct identification.
Jun 27, 2017 | Vitamix Blenders
Where can I buy a clutch for a vita mix 5000
Shop for buy a clutch for a vitamix... on Google
Amazon.com: Vitamix Drive Socket Kit: Electric Countertop ...
www.amazon.com/Vitamix-891.../B0028Y4CVE
Amazon.com, Inc.
Rating: 4.7 - ‎249 reviews
Shop Vitamix at the Amazon Small Appliance Parts & Accessories store. ... blender on the fritz, PLEASE do yourself a favor and check the old drive socket before buying a whole new blender. .... This fitted perfectly into my vitamix super 5000.
Vita-Mix Parts: OEM Replacement Parts ' Parts Town
Dec 03, 2015 | Vitamix Vita Mix 891 - 1-Drive Socket Kit...
When i turn it onto high speed it willl fuse istanlty. (Even with somthing easy to blend like a smoothie) .Any ideas what could be wrong?
I would suspect a motor fault, most likely an insulation problem in the armature or the fields. Contact Vitamix for your local authorised service agent. Unless it has been assembled incorrectly it should not be one of the internal wires as they are supposed to be secured and correctly routed during assembly.
Mar 31, 2015 | Vitamix 5000 Work Top Blender
Part of the blade assembly or drive socket assembly?...
check here:
Jan 30, 2014 | Vitamix Blenders
Loosened blades on a vitamix 3600 stainless steel container
If what you can't see in your device, namely the motor assembly, it may be that the assembly is one of those not designed to be taken apart and that it is wearing out. If so, that could be the cause of the looseness you are experiencing. It may be unrepairable or more costly to fix than to replace. Twenty plus years is a good run for almost any mechanical device.
Jan 02, 2014 | Vitamix Vita-mix Super 3600 Stainless...
Vitamix TNC 60 oz container leaks when in use. how to replace seal and or bearings?
If it is not the HUGE blade retaining ring under the beaker a bit loose then you will be buying new parts to repair it. The only other possibilities are beaker cracked and leaking (new beaker) or bearings & seals worn (new blade & bearing assembly)
Oct 21, 2013 | Vitamix 5000 Work Top Blender
High pitched noise with use
The problem was the seal was worn, allowing liquid to seep past into the top blade shaft bearing washing out the grease and ruining the bearing. The "noise" you heard was the bearing running without any lubrication. Both bearings and the seal needed to be replaced but I have not found a source for purchasing these. Vita-Mix Company does not sell parts, they sell units (outrageously priced units)!
Sep 03, 2012 | Vitamix 5000 Work Top Blender
The blade in my Super 5000 wet container turns very stiffly.Should I take it off and lubricate it? There also seems to be water visible under the bottom of the container.
Stiff or stuck blade problems can be fixed by replacing the two bearings and seal inside the blade assembly. Care must be taken in installing the new bearings as not to damage them. Ideally they should be pressed in, on a press, but they can carefully be tapped in using a sockets to match inner and outer races so your not tapping on the balls.
Mar 20, 2011 | Vitamix 5000 Work Top Blender
Vita-Mix 5000 blender shuts off under heavy blending loads.
first check the blades on the container thay should turn easy by hand if not thats your problem , you will need blades . blades turn easy ? you will need to replace the motor . the temp /overload has changed and is tripping to easy . this is common with people that use there vitamix for tough chores a lot . a lesser blender would just burn up a motor in a puff of smoke .a vitamix dies this way . in the end its the same you will need a motor
Mar 22, 2009 | Vitamix Super 5000 Work Top Blender
Blade turns with difficulty
Check the blade assembly it may be worn out.
Mar 27, 2007 | Vitamix 5000 Work Top Blender
Blenders Logo
298 people viewed this question
Top Vitamix Blenders Experts
Holly...
Holly...
deton8 von Splosion
Are you a Vitamix Blender Expert? Answer questions, earn points and help others
