Question about Stihl Br550 Br500 Backpack Blower Fan Wheel 42827003400
Br500 wont start - Stihl Br550 Br500 Backpack Blower Fan Wheel 42827003400
Fuel filter inside the tank and inline
bad start stop switch
bad carbiration
bad spark plug {burned}
bad ht cable
bad magnito coil
take your pick and rull them out one by one
Posted on Dec 04, 2014
How to replace the primer bulb
Gain access to carb and right by the bulb you will see about 4 screws holding down a metal plate that holds down the primer bulb. Remove the screws and plate and replace damaged primer in same spot, and screw plate back on.
Nov 26, 2015 | Stihl Br550 Br500 Backpack Blower Fan...
Timming
take out the spark plug and try turning it over
sounds like too much oil inside it
can cause compression issues
drain clean the oil
you can tell lots with no plug in
could be anything in the transmission to the trimming head
perhaps the clutch is seized up
Apr 22, 2014 | Stihl Br500 Br550 Br600 Flywheel...
Gas cap leaks
the seal is missing youve dropped it in a garden somewhere
you need a new one
try ebay
but i will tell you stihl is VERY good at service parts
and very helpfull
http://www.ebay.co.uk/itm/PETROL-FUEL-TANK-CAP-FITS-STIHL-BR500-BR550-BR600-BLOWER-/141346840553?pt=UK_Home_Garden_GardenPowerTools_CA&hash=item20e8ed9fe9
Feb 19, 2014 | Stihl Br500 Br550 Br600 Back Pack Blower...
Fuel leak from carb when sitting
the return tube is blocked
the tank sends fuel to the carb
spare fuel is returned
also the cap usually has a bleader on it
perhaps its blocked up and needs the internal diaphram and filter block renued
if the carb leeks this also needs attention
Feb 01, 2014 | Stihl Br500 Br550 Br600 Back Pack Blower...
Backpack blower
the return spring is shiered up
you need to replace the rip cord cassette or change out the spring
i would ask around the local service guys if they have a spare return spring also the two 'pawls' could be badly worn and need replaced
Jan 28, 2014 | Stihl Br500 Br550 & Br600 Blower Air...
How do i check to see if my flywheel is aligned
there is a key way built into the flywheel... it keys into the crank... no other way... but aligned with what ??? if you do not physically see a key way then did it shear off ???
Dec 09, 2013 | Stihl Br500 Br550 Br600 Flywheel...
Br550 shuts off after about 20 min. run time, Won't re-start.
fuel tank vent
bad inline fuel filter
leefs inside the tank flush it out
bad plug replace it
bad air filter replace it
bad pickup ignition coil
oil level too high or low take it all out and measure what you put back by the user manual from the stihl site {use google to find it}
Nov 19, 2013 | Stihl Br500 Br550 Br600 Back Pack Blower...
Need to reset to factory default
If there is, hold it down for about 3 seconds while powering on the unit. Hope it helps.
Dec 21, 2009 | Aironet BR500
I do not know default IP of Air BR500
try
192.168.1.1
192.168.0.1
192.168.15.1
May 05, 2009 | Aironet BR500
Stihl Br550 Br500 Backpack Blower Fan Wheel 42827003400 Logo
110 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
