Canon ir3320i. Just had this machine installed 3 days ago. Had the toner replaced as I was told machine from factory usually have minimum toner in them. Today, after about 80 copies, there's a blank line along the copies. I need to know if it's a toner problem or is it something else and how to solve this. P/s, I already tried shaking the toner up a bit and replacing the paper and the problem remains.Thanks
    New Friend:
  • 44 Answers
Most new printers come with alignment paper. Were the printer heads aligned after instillation? Aligning the heads will use quite a bit of ink, so have some handy to replace if needed.
Posted on Feb 09, 2014
  • Hameed Riyaludeen
    Hameed Riyaludeen Feb 10, 2014
    thanks Jack Owens. but this happened today: had the technician come in for a check. after fiddling with a lot of the outer stuff and getting the same results, he went and opened up the toner container. and there was a broken piece. this broken piece was on one side hence why the blank printing on one side. the two tiny pieces on each side holds two small rods that sift the toner so that it doesn't form a lump and stay in one place. temporarily, he removed them completely and currently I need to set a higher density to get a decent photocopy. but for minor photocopying i'm relying on my mx527. until he replaces the missing pieces. hope this info will be helpful for others.
4 Suggested Answers
SOURCE: canon LBP 3000 tells me it needs a new toner cartridge
My IT guru at the place I work found an AMAZINGLY SIMPLE SOLUTION. Remove the paper, then remove and replace the toner cartridge. Now put the paper back in, and you are ready to go. Our IT man rocks!
Posted on Aug 02, 2009
canontech
  • 1219 Answers
SOURCE: paper jam in canon Imageclass D861 copy machine
Where inside in fixing unit, drum unit,...
It is problem if its fixing unit jam.Best take it to service
Posted on Jan 12, 2010
SOURCE: REPLACED MAGENTA TONER STILL SAYING REPLACE
reset part life. turn on printer, Open front door, Press and hold cancel, press reprint. Now scroll through menu of toners h=high yeild and s=standard. press ok and ok again to accept. close door.
Posted on Apr 16, 2010
Contiously blinking display canon iR3320i
Since you did not specify what the "blinking display" was, such as an icon or actual code. I suggest you go the Canon Support Web Site at:
http://www.usa.canon.com/cusa/support/office/b_w_imagerunner_copiers/imagerunner_2200_2220i_2220n_2800_3300_3300i_3300e_3300en_3320i_3320n/imagerunner_3320i
Nov 04, 2014 | Canon Office Equipment & Supplies
Dear Sir, We have canon xerox machine and our deler ask high cost for spares Ex. OPC - 6000, Tonar - 2350 also he told if you fefile your tonar it damege your machine due to this magnetic rod ,OPC can...
Please let me know the model of your machine. In general, if you are having print quality issues, such as lines dots or black patches, these are usually due to toner cartridge. Genuine Replacement of Toner cartridge is advisable.
However, you may get your toner cartridge re-filled, if its parts are working properly. Cartridge parts like OPC, PCR and magnetic roller can be replaced. Re-filling the toner is always cheaper and costs around 1/4th of the new toner price. So, check for the price of new toner and compare.
I have refilled/ refurbished toners myself and had no issues. Properly re-filled/ refurbished cartridge would NOT cause any damage to the printer. So, you may get your toner refilled by some good professional and it would work fine.
Hope it helps. Let me know if any clarifications are required!
CreativeTECH
Nov 10, 2010 | Xerox Office Equipment & Supplies
Ir3570 Takes Half Hour to start printing 3 pages - help!!!
Sounds like you have the wrong driver installed, go to canon website and download a new driver for the machine
Jul 06, 2010 | Canon ImageRUNNER 3570 Copier/Printer
The alarm light is blinking and the toner was changed 3 days ago. Minimal printing since then
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 14, 2009 | Brother HL 1440 Laser Printer
I need to know whether the below canon's can scan and what the range of the DPI is that they can scan at; IRC3100 IR3320i IRC2570 Cheers
iR C3100 600 dpi if equipped with network print/scan kit.
iR3320i 200 dpi, 300 dpi, 400 dpi, 600dpi yes, can scan
iR C2570 600dpi yes, can scan
Nov 06, 2009 | Canon PC-920 Black and White Copier
What does the display read when toner is out, or toner cartridge is out
If this message appears and you can not make any copy, replace the toner
Original Toner CANON C-EXV3 Black Canon iR2200, iR2800, iR3300, iR3320i.
Oct 30, 2009 | Canon imageRUNNER 2200
After replacing toner-printer won't reset
The machine should ask you if you've replaced the relevant toner cartridge, you must answer ;yes'. Turn off the machine and then on again and remove the toner cartridge. Then re-install it and answer the question correctly.
May 29, 2009 | Canon imageRUNNER C3200 Copier
Canon IC 6530 After installing new toner cart, machine is still saying toner is low
maybe the cartridge you are using is a refurb. and the sensor is not working or the chip is bad.
Mar 30, 2009 | Canon MF-6530RF Factory Reconditioned...
Error code E000732-0001 on canon imageRunner 3200n
this is a reader board error ... 1st check all connectors on the machine unplug and replug did this just happen or could there be a connector missing, this code usually comes from the connecter that looks like a small parrellel connector on rear going from scanner to right rear side
Dec 24, 2008 | Canon imageRUNNER C3200 Copier
k24674
jasbo
jasbo
