Question about Sony XR-CA300 Cassette Player
Need wiring diagram for speakers and power supply
I need the radio wiring color diagram for my delco radio, 1998 corvette
1998 Chevrolet Corvette Car Stereo Radio Wiring Diagram
Radio Constant 12V+ Wire: Orange
Radio Switched 12V+ Wire: Yellow
Radio Ground Wire: Black
Radio Illumination Wire: Gray
Radio Dimmer Wire: Brown
Radio Power Antenna Trigger Wire: Pink
Radio Amplifier Turn On Trigger Wire: N/A
Front Speakers Size: 4? Speakers
Front Speakers Location: Kick Panels
Left Front Speaker Wire (+): Tan
Left Front Speaker Wire (-): Gray
Right Front Speaker Wire (+): Light Green
Right Front Speaker Wire (-): Dark Green
Rear Speakers Size: 6?
Rear Speakers Location: Rear Sides
Left Rear Speaker Wire (+): Brown
Left Rear Speaker Wire (-): Yellow
Right Rear Speaker Wire (+): Dark Blue
Right Rear Speaker Wire (-): Light Blue
Dec 22, 2016 | Cars & Trucks
Boss diagram
the 2 power lines to supply batery and black to ground blue to speaker
Jun 07, 2014 | Computers & Internet
I need a radio wire diagram for a 1988 Mitsubishi colt GLX re!
What unit was fitted to the vehicle. I have an 1988 RD colt that had the factory AM/FM radio. This had a 6 pin connector and it works out easier to use the power and earth of the original connector and install new speaker wiring for the following reason. The AM/FM radio didn't need specific polarity for the speakers so it used 4 positive wires to the speakers the negative terminal of the speaker was then earthed to the body. This set up is not suitable for modern head units and will damage the integrated circuits. Therefore you will have to run new wiring to the speakers. You will also need to run a new constant power supply as the colt didn't come with this. Hope this helps
Feb 27, 2013 | Cars & Trucks
I need a factory speaker and radio wiring diagram for a 2009 dodge 2500 quad cab truck
This is what my books show.
2009 Dodge Ram 2500 Car Radio Install Instructions
Car Radio Battery Constant 12v+ Wire: Gray/Red
Car Radio Accessory Switched 12v+ Wire: The radio harness does not provide a switched power source. Run a wire to the fusebox for switched power.
Car Radio Ground Wire: Black/Dark Green
Car Radio Illumination Wire: Orange/Dark Blue
Car Stereo Amp Trigger Wire: Dark Green/Red
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Jun 12, 2012 | Cars & Trucks
Need wireing display for a sony car stereo model no. CDX_S2000 . I need to know what wire does what and what colour .
Usually the red is the power supply. The yellow is the memory so it has to have power all the time. Blue is for the accessory (power antenna, amplifier, etc..) Black is ground. Speakers usually use the same two colors per speaker.
As an example: Green with a black tracer and black with a green tracer go to the same speaker.
It may be quicker for you to use a speaker, hook it up to the two alike wires and go through fade and balance to see where the speakers should go.
Or you can re-post and try for the diagram.
Feb 28, 2010 | Sony Car Audio & Video
Stereo wire diagram
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: Red/Blue
Car Stereo Dimmer Wire: Red/Yellow
Car Stereo Antenna Trigger: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
Mar 25, 2009 | 1995 Nissan Sentra
Audio wiring diagram for an irish corolla verso
2005 Toyota Corolla Car Stereo Wiring Diagram
Radio Constant 12V+ Wire: Blue/White
Radio Switched 12V+ Wire: Gray
Radio Ground Wire: Brown
Radio Illumination Wire: Green
Power Antenna Wire: Black
Front Speaker Size: n/a
Front Speaker Location: n/a
Left Front Speaker Wire (+): Pink
Left Front Speaker Wire (-): Purple
Right Front Speaker Wire (-): Blue
Rear Speaker Size: n/a
Rear Speaker Location: n/a
Left Rear Speaker Wire (+): Black
Right Rear Speaker Wire (+): Red
Right Rear Speaker Wire (-): White
pls rate
Dec 10, 2008 | 2005 Toyota Corolla
Wiring diagram
Yellow - +12V Constant Power
Red - +12V Switched (accessory) Power
Blue - Power Antenna
Blue/White - Amp Turn-on
White - Left Front Positive Speaker Wire (LF+)
White/Black - (LF-)
Gray - Right Front Positive Speaker Wire (RF+)
Gray/Black - (RF-)
Green - Right Rear Positive Speaker Wire (RR+)
Green/Black - (RR-)
Purple - Left Rear Positive Speaker Wire (LR+)
Purple/Black - (LR-)
Aug 07, 2008 | Pioneer DEH-P2000 CD Player
Need a wiring diagram because the harness i boughtfor my cd player is wired slightly wrong
yellow wire - continous power
red wire - power ( when switch is on)
black wire - ground
blue wire - remote ( has power when switch is on) ( must be connected)
blue/light blue - rear right speakers
yellow/brown - rear left speakers
white/white striped - front left speakers
grey/pink - front right speakers
orange wire- dimmer lights ( not important)
these are the wires coming from car follow this diagram and you should be fine
Jul 22, 2008 | 2000 Oldsmobile Alero
Wiring diagram and manual needed for wd810
The manual can be found here: http://www.rmeco.net/images/IB/durabrand/WD810.pdf Also, here are some standard wire colors: Yellow - +12V Constant Power Red - +12V Switched (accessory) Power Blue - Power Antenna Blue/White - Amp Turn-on White - Left Front Positive Speaker Wire (LF+) White/Black - (LF-) Gray - Right Front Positive Speaker Wire (RF+) Gray/Black - (RF-) Green - Right Rear Positive Speaker Wire (RR+) Green/Black - (RR-) Purple - Left Rear Positive Speaker Wire (LR+) Purple/Black - (LR-)
Sep 02, 2007 | Durabrand WD810
Sony XR-CA300 Cassette Player Logo
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
