Question about Frigidaire Gallery GLEFM397DS Electric Kitchen Range
How do i find a code to see whats wrong with my frigidaire stove Model# FEFL63FSB
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Kelvinator stove with F1 code coming up
If it is not opening, Safety Feature is causing it to not open. Better, contact Authorized Service Center.
Mar 29, 2014 | Kelvinator Refrigerators
We have a Frigidaire electronic ignition range about a decade old. The stove works fine. But lately we've noticed if we're using any stove elements the oven won't ignite and heat up. Conve
Sounds like the pressure regulator on the stove is going bad. The pressure regulator is located in the back. Your gas supply line should connect directly to it.
Dec 23, 2012 | Kitchen Ranges
Request Onwers Manual/Troubleshooting Guide: [FEF366CCE]. PROBLEM: Oven locked in code [F9] & [F1] w/ the the [Door Locked] LED flashing w/ beep. Stop top functional, oven inop.
Here is the Owners Manual for your model:
http://manuals.frigidaire.com/prodinfo_pdf/Springfield/316257123en.pdf
Here are all of the error codes and solutions for Frigidaire ranges: http://www.appliancepartspros.com/repairtips/repairtips_appliance+fault+codes.aspx#Frigidaire Range / Stove / Oven Fault Codes#ixzz1Dxy4q2ze
Feb 14, 2011 | Frigidaire FEF366 Electric Kitchen Range
I have a Frigidaire over the stove microwave that pops/arcs
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Dec 15, 2009 | Frigidaire GLMV169D Microwave Oven
GAS STOVE - MODEL GLGF377 - FRIGIDAIRE - OVEN SMALL EXPLOSION
find the broken part and replace it. it really is that simple!!!!
now seriously, you need to explain what is wrong.
let us know what kind of problem you are having... ie. the oven glow bar glows but doesnt let gas in to heat.
if this is your problem then replace the glow-bar ignitor and that should fix it.
give us more info and we can help you out.
Jan 22, 2009 | Frigidaire GLGF376 Gas Kitchen Range
Need directions for fridaigre self cleaning oven
i cannot find the model number on my frigidaire self cleaning stove.i need to know how the self cleaning works.i bought the stove used
Nov 26, 2008 | Frigidaire FEF352 Electric Kitchen Range
Frigidaire stove door looked
temp was too high or the sensor smoked. this happens, self clean wreaks havoc with the electronics on this stuff. need your model to tell you what the error code means
May 10, 2008 | Frigidaire FES367 Electric Kitchen Range
Frigidaire Gallery GLEFM397DS Electric Kitchen Range Logo
27 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
