Question about Jensen XA4150 Car Audio Amplifier
Lost one channel
I have had this amp for 5 years...its been flawless. However recently I lost one channel. I verified it wasnt a speaker by switching speakers wires on the amp to the good channel. I checked the 2 fuses on the amp...they are good. Do you have a wiring diagram before I tear into this..Im guessing one of the power amps ( internally) has had it. I am electronics savvy and have repaired things like before. I just like some insight from someone else, if youve already attempted this repair and if the parts are available.
Also I paid $300 for the amp and the 10 inch dual sub box...should I just call it done and get another amp at this point. Its been in my car and running for 225,000 miles...and its had A LOT of heat cycles.
  • Titan1969 Oct 27, 2007
    ok Ill crack it open and see whats up.thanks
    ok. Ill crack it open let you know what I find.
  • 631 Answers
Have you tried switching the signal cables?
Try moving all of the controls and switches. A dirty contact can cause similar problems.
If these don't help, you probably have a broken connection in the amp. Generally, when semiconductors fail, you have excessive current draw and the amp goes into protection or blows the fuse.
Posted on Oct 26, 2007
One speaker has lost all bass it is definitely an amp problem because I have switched leads etc. is this an easy fix or will I need to buy a new one
If you have switched speakers to make sure it's not just a blown woofer, then I'd suggest just replaceing the amp. It's odd for an amp to output treble but not bass on an output channel, and the tech time to figure this out could be more expensive than a new Phonic amp
May 10, 2014 | Phonic Audio Players & Recorders
Lost sound in left channel?
I presume you are playing a stereo cd. Plug some other device, like headphones in to see if the computer is putting out stereo. Use the same plug as the speaker system is plugged into.
I presume you have swapped the speakers to test them.
If the speakers work, and the headphones work, it's the amp.
Nov 26, 2013 | Klipsch Promedia 2.1 Thx Computer Speaker...
I have an old Philips Amplifier which I bought 18 years ago. The Amp actually can handle 5 speakers but I only connect 2 speakers (L & R). When I play certain DVD, although the background music sounds...
If you identified the specific products involved we (and you) might be able to look at the documentation and verify the obvious answer. Voice is generally concentrated on the center channel, so, yes, a speaker there would be a good idea.
If you don't have a multi-channel rig you shouldn't feed multichannel audio to it. Maybe use the unidentified DVD player's analog output and make sure it's set to mix the channels down to stereo.
Jul 01, 2011 | Philips Audio Players & Recorders
Speakercraft MZC-66 lost 4 channels
The fact that you are gettng noise out suggests that the problem is in the "front-end" of the amp. It sounds like the pre-amp section is smoked. What you are hearing is a little distortion that is getting through the pre-amp stage. This can be as simple as replacing a few cheap ICs. I don't know your exact model specifics, but this should be a straightforward repair. Where are you located?
Dan
Jul 21, 2010 | SpeakerCraft MZC-66 Amplifier
I have lost the left side channel of my JL300/4 amp
USE THE PROCESS OF ELIMINATION. SWITCH THE RCA INPUTS AROUND AND IF THE PROBLEM STAYS IN THE SAME CHANNEL, THEN THE AMPLFIER OR SPEAKER IS AT FAULT. IF THE PROBLEM SWITCHES TO THE OTHER SPEAKER, THEN THE PROBLEM IS THE RCA CABLE OR RADIO ITSELF. YOU CAN VERIFY YOUR FINDINGS BY STARTING WITH THE SPEAKERS FIRST. SWAP THE SPEAKERS AROUND AND IF THE PROBLEM STAYS ON THE SAME SPEAKER, THEN THE SPEAKER IS AT FAULT. IF THE PROBLEMS SWITCHES TO THE OTHER SPEAKER, THEN THE AMPLIFIER OR INPUTS ARE TO BLAME. BY FOLLOWING THESE TWO METHODS, YOU WILL BE ABLE TO DETERMINE EXACTLY WHICH COMPONENTS ARE AT FAULT. REMEMBER, YOU HAVE AN INPUT, AN AMPLIFIER AND A SPEAKER. THIS PROCESS OF ELIMINATION WILL HELP YOU IN THE FUTURE WITH MANY TYPES OF PROBLEMS. LET ME KNOW IF YOU REQUIRE FURTHER ASSISTANCE. I AM LISTED IN THE REPAIR LISTINGS ON THIS WEBSITE......V
PS: MAKE SURE THAT THE GAINS AND BOOST CONTROLS ARE SET TO THE SAME LEVEL FOR BOTH CHANNELS BEING TESTED. ALSO MAKE SURE THAT THE BALANCE CONTROL ON THE RADIO IS STILL SET TO THE MIDDLE. DON'T WANT THESE CURVEBALLS INTERFERING WITH YOUR TROUBLESHOOTING......V
Dec 01, 2009 | Jl Audio 300/4 Car Audio Amplifier
Hi there i have a starview 5 box recently purchased earlier this year . unfortunately it seems to have lost connection on all channels apart from freeview channels , i have tried rescanning it but to no...
You need to put the codes in to get the scrambled channels depending who your provider is.
Telewest ,ntl ,cw ,chorus
Repost your provider and i will give you the codes.
Nov 14, 2009 | Belkin F1DK102P 2-port KVM Switch
I have an ONKYO TX-SV717Pro amp. recently I lost
It could be that you lost the power supply to the surround amp IC or the Ic is defective. It should be mounted on a circuit board attached to the heatsink. Look for poor solder connections first. I don't recall the specifics of this model, but the surround amp IC should be easily located.
Update this with your progress and I'll try to locate the service manual in the meantime.
Dan
Oct 22, 2009 | Onkyo M-282 2-Channel Amplifier
I have a Pyle Pro 2000 (have had for over 2 years). This past weekend I lost my right speaker (could hear extremely faint in background). Have it mounted in a metal dolly (the type used in school rooms)...
it could be something else. it could be the speaker itself. you should try to switch the speakers and be sure that the problem follows the amp channel in question.
if it was the mono/stereo switch some contact cleaner could clear that up.
ofcourse, the bad news is that these amps fail from time to time and the cost to repair far outweighs the cost to replace with something new.
Sep 18, 2009 | Audio Players & Recorders
I own a classic Sansui intergrated amplifier (AU-717). It has a short in one channel. At low volume, the sound shorts out. I've had this unit for about 20 years now. Otherwise, it's a great product!
Hi mellemcee
Cool amp mate, and becoming collectable now to. Sansui amps from the era where the best in the world of HiFi. iT may have lost bias control to the offending channel, it may have dirty source switches, tape monitor switch, or even speaker switching. The speaker protection relay may also have a dirty contact, will usually burst back into life with a quick rotation of the vol control. Can you pin the problem down a little more with the info i have given you, try all the controls to see if it impacts on operations, you will need to fix those problems first. Low bias would make that channel sound distorted at low levels also. Is this what is happening to you??
regards
Graeme
Apr 18, 2008 | Audio Players & Recorders
Stiletto 100 Lost Left Channel
Mine lost the left channel then the next day lost all the channels. I cAN'T FIND A FIX EITHER
Feb 27, 2008 | Sirius STILETTO 100 MP3 Player
Jensen XA4150 Car Audio Amplifier Logo
80 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
