Question about 500 pulley. power steering pump. . crankcase ventilation power
Torque on a crankcase bolt for a 13 hp lifan engine
John deere model FC420
Specifications
Engine HD45
Engine Model Number(Kawasaki FC420V
Horsepower (10.5 kW (14 hp)
Displacement (423 cc (25.8 cu.in.)
Crankcase Capacity w/o oil filter (1.3 L (1.4 qt.)
Crankcase Capacity with oil filter (1.6 L (1.7 qt.)
Spark Plug-Gap (0.64 mm (0.025 in.)
Spark Plug-Torque (20 N·m (15 lb-ft.)
Cylinders (One
Stroke/Cycle (Four
Lubrication (Full-Pressure
Oil Filter (Standard Single Element
Air Cleaner (Dual Stage
Engine HD75
Engine Model Numbe(Kawasaki FC540V
Horsepower (12.7 kW (17 hp)
Displacement (535 cc (32.6 cu.in.)
Crankcase Capacity w/o oil filter (1.6 L (1.7 qt.)
Crankcase Capacity with oil filter (1.9 L (2.0 qt.)
Cylinders (One
Stroke/Cycle (Four
Fuel System
Fuel (See Fuel in the Service Miscellaneous section
Fuel Filter (Single Stage, 60 Micron
Fuel Pump (Vacuum Operated-Diaphragm
Fuel Delivery (Gravity Feed to Fuel Pump)
Fuel Tank Capacity (19 L (5.0 gal.)
Drive Train Mower Deck (36-inch)
Blades (2
Blade Bolt Torque (81 N·m (60 lb-ft.)
Cutting Heights (25-114 mm (1-41/2 in.)
Weight (86.7 Kg (191 lb)
Overall Width (chute up) (927 mm (36.5 in.)
Mower Deck (48-inch)
Blades (3
Blade Bolt Torque (68 N·m (50 lb-ft.)
Cutting Heights (25-127 mm (1-5 in.)
Weight (83.6 Kg (184 lb)
Overall Width (chute up) (1308 mm (51.5 in
ower Deck (54-inch)
Blades (3
Cutting Heights (25-127mm (1-5 in.)
Weight (86.7 Kg (187 lb)
Overall Width (chute up) (1460 mm (57.5 in.)
Recommended Lubricants
Engine Oil (John Deere PLUS-4
Grease (John Deere MOLY HIGH Temperature EP
Transmission Oil (HY-GARD-J20C (TURF-GARD-SAE10W-30 (PLUS-4-SAE10W-30 (TORQ-GARD SUPREME-SAE30
(Specifications and design subject to change without notice.)
Sep 28, 2016 | John Deere Garden
Workshop manual for a 1994 nissan serena
Cylinder head bolt torque sequence
The Rod Bearing Cap Torque
The Main Bearing Cap Torque 38 Foot pounds (Final torque)
Step 1: Torque 10-12 Ft/LbsStep 2: Torque 17-21 Ft/Lbs
Note :
Torque sequence ------------------------
' 11 '
front ' 13 9 3 1 6 8 '
of ' '
engine ' 14 7 5 2 4 10 '
' 12 15 '
Step 1: Torque all bolts in sequence 22 Ft/Lbs
Step 2: Torque all bolts in sequence 47 Ft/Lbs
Step 3: Loosen all bolts in reverse sequence
Step 4: Retorque all bolts in sequence 22 Ft/Lbs
Step 5: Retorque all bolts in sequence 43-51 Ft/Lbs
Step 6: Retorque bolts 11 thru 15 in sequence an
additional 4-6 Ft/Lbs
** CAUTION ** This engine uses 2 different length head
bolts. "#1" Is the long bolt, while remaining bolts
are short. **Do not confuse location of these bolts**
recheck final torque in sequence
Dec 06, 2012 | Cars & Trucks
I need torque settings for the engine ie head bolts v6 engine 1
i am replacing the heads on a GMC 350 cu in engine. what is the final torque of the head bolts?
Jul 15, 2010 | 1985 Chevrolet Camaro
Ifailed to get on tdc before removing old timing belt how do I get back in time so Icanreplacebelt.
This is the complete procedure from the service manual on how to replace the timing belt start to finish, start over to assure u get it right, if u mess up the engine will be damaged
Removal for 1.6L engines : ONLY 2006 to 2009 CARS
Engine removal is not required for this procedure.
1.Remove the engine cover.
2.Remove the RH front wheel.
3.Remove the 2 bolts and RH side cover.
4.Temporarily loosen the water pump pulley bolts.
5.Remove the alternator drive belt
6.Remove the air conditioner compressor drive belt
7.Remove the power steering pump drive belt
8.Remove the 4 bolts and water pump pulley.
9.Remove the 4 bolts and
timing belt2_bing.gif upper cover
10.Turn the crankshaft pulley, and align its groove with timing mark "T" of the timing belt cover. Check that the timing mark of camshaft sprocket is aligned with the timing mark of cylinder head cover. (No.1 cylinder compression TDC position)
11.Remove the crankshaft pulley bolt and crankshaft pulley
12.Remove the crankshaft flange
13.Remove the 4 bolts and timing belt lower cover
14.Remove the timing belt tensioner and timing belt.
15.Remove the bolt and timing belt idler
16.Remove the crankshaft sprocket
17.Remove the cylinder head cover.
(1)Remove the wire harness bracket
(2)Remove the ignition coil.
(3)Remove the PCV (Positive Crankcase Ventilation) hose and the breather hose from the cylinder head cover
(4)Remove the engine cover bracket
(5)Loosen the cylinder head cover bolts and then remove the cover and gasket.
18.Remove the camshaft sprocket.
Hold the portion of the camshaft with a hexagonal wrench, and remove the bolt with a wrench and remove the camshaft sprocket.
INSTALLATION:
1.Install the camshaft sprocket and tighten the bolt to the specified torque.
(1)Temporarily install the camshaft sprocket bolt
(2)Hold the portion of the camshaft with a hexagonal wrench, and tighten the bolt with a wrench
Tightening torque :78.5 ~ 98.1N.m (8.0 ~ 10.0kgf.m, 57.9 ~ 72.3lb-ft)
2.Install the cylinder head cover.
(1)Install the cylinder head cover and bolts
Tightening torque :7.8 ~ 9.8N.m (0.8 ~ 1.0kgf.m, 5.8 ~ 7.2lb-ft)
(2)Install the engine cover bracket
(3)Install the PCV(Positive Crankcase Ventilation) hose and breather hose to the cylinder head cover.
(4)Install the ignition coil.
3.Install the crankshaft sprocket
4.Align the timing marks of the camshaft sprocket and crankshaft sprocket with the No.1 piston placed at top dead center and its compression stroke.
5.Install the idler pulley and tighten the bolt to the specified torque.
Tightening torque :42.2 ~ 53.9N.m (4.3 ~ 5.5kgf.m, 31.1 ~ 39.8lb-ft)
6.Temporarily install the timing belt tensioner
7.Install the belt so as not give slack at each center of shaft. Use the following order when installing timing belt.
Crankshaft sprocket →idler pulley →camshaft sprocket →timing belt tensioner
8.Adjust the timing belt tension.
(1)Loosen the tensioner pulley mounting bolt and apply tension to the timing belt.
(2)After checking the alignment between each sprocket and each timing belt tooth, tighten the mounting bolt and one by one.
Tightening torque :19.6 ~ 26.5N.m (2.0 ~ 2.7kgf.m, 14.5 ~ 19.5lb-ft)
(3)Then recheck the belt tension.
Verify that when the tensioner and the tension side of the timing belt are pushed in horizontally with a moderate force [approx. 49N (11lb)], the timing belt cog end is aprox. 1/2 of the tensioner mounting bolt head radius (across flats) away from the bolt head center.
4)Timing belt tension measuring procedure
(by a sonic tension guage)
Rotate crankshaft in clockwise direction to set 1st piston on top dead center (TDC) and rotate crankshaft in counterclockwise to 90° then measure the belt tension in the middle of tension side span (in arrow direction of above illustration) by free vibration method.
9.Turn the crankshaft two turns in the operating direction (clockwise) and realign crankshaft sprocket and camshaft sprocket timing mark.
10.Install the timing belt lower cover with 5bolts
11.Install the flange and crankshaft pulley, and then tighten crankshaft pulley bolt. Make sure that crankshaft sprocket pin fits the small hole in the pulley.
Tightening torque :137.3 ~ 147.1N.m (14.0 ~ 15.0kgf.m, 101.3 ~ 108.5lb-ft)
12.Install the timing belt upper cover with 4 bolts.
13.Install the water pump pulley and 4 bolts.
14.Install the power steering pump drive belt
15.Install the air conditioner compressor drive belt
16.Install the alternator drive belt
17.Install the RH side cover with 2 bolts
18.Install the RH front wheel.
Tightening torque :88.3 ~ 98.1N.m (9.0 ~ 10.0kgf.m, 65.1 ~ 72.3lb-ft)
19.Install the engine cover with bolts.
Tightening torque :3.9 ~ 5.9N.m (0.4 ~ 0.6kgf.m, 2.9 ~ 4.3lb-ft)
May 20, 2010 | 2006 Kia Sorento
Need to know the head bolts torch specs on 98 toyota v6
heres the torque specs and the way to tighten the head bolts for your 1998 toyota sienna, hope this helps,
12 point bolts step 1- 40 ft lbs
step 2- additional 90 degrees
May 12, 2010 | 1998 Toyota Sienna
What are the torque measurements for the rocker arms and intake manafold?
2.2L Engine & 2.4L Engines
These engines are not equipped with rocker arms. The camshafts directly actuate the valves.
3.1L Engine & 3.4L Engines
When install or connect the check the following:
- Pushrods and the rocker arms. Torque the bolts to 24 ft. lbs. (32 Nm). - Rocker arm cover using a new gasket. Torque the rocker cover bolts to 89 inch lbs. (10 Nm).
- Heater bypass pipe. Torque the screw at the water pump to 106 inch lbs. (12 Nm), the bolt at the cylinder head corner to 18 ft. lbs. (25 Nm) and the nut to 18 ft. lbs. (25 Nm).
About the INTAKE MANIFOLD...
Intake manifold nuts and bolts and tighten to 89 inch lbs. (10 Nm)
- Pushrods and rocker arms. Torque the bolts to 89 inch lbs. (10 Nm) plus an additional 30 degree turn. - Lower intake manifold. Apply sealant to the threads of the bolts and torque the bolts to 115 inch lbs. (13 Nm).
Exploded view of the upper and lower intake-3.1L & 3.4L engines
Fig. Lower intake manifold tightening sequence-3.1L & 3.4L engines
Hope help.
May 04, 2010 | 2000 Pontiac Grand Am GT
Head tourqe specs for 403 olds and bolt tightening
Fig. : Cylinder head torque sequence, 260, 307, 350 403 Oldsmobile built engines
On the V8, tighten the bolts, in the sequence illustrated, to 100 ft. lbs. When all bolts have been tightened to this figure, begin the tightening sequence again, and torque all bolts to 130 ft. lbs.
On V6's, tighten all head bolts in sequence to the following torques:
* All except bolts 5, 6, 11, 12, 13 and 14 - 100 ft. lbs.(19-135.5 Nm)
* Bolts 5, 6, 11, 12, 13, and 14 - 41 ft. lbs. (19-55.5 Nm)
* All bolts except 5, 6, 11, 12, 13, and 14 - 142 ft. lbs. (19-192.5 Nm)
* Bolts 5, 6, 11, 12, 13, and 14 - 59 ft. lbs. (19-80 Nm)
Hope this help (remember comment and rated this).
Mar 29, 2010 | 1984 Oldsmobile Cutlass
Torque settings for crankcase suzuki bandit 600gsf
Crankcase bolt (M8)
(initial):13 N-m (1.3 kgf-m, 9.5 lb-ft)
(Final):23 N-m (2.3 kg-fm, 16.5 lb-ft)
Please leave positive feedback if you feel I have helped.
Thank you
Aug 29, 2009 | 2003 Suzuki GSF 600 S Bandit
500 pulley. power steering pump. . crankcase ventilation power Logo
60 people viewed this question
Top Fiat Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Fiat Vehicle Part and Accessory Expert? Answer questions, earn points and help others
