Question about Thermador Kitchen Ranges
Thermador SGSCV36GS reinstall
I have to remove (and reinstall) my Thermador SCSCV36GS for placement of a new countertop. It works fine now. Hate to remove it for the counter install. Any advise?
3 Suggested Answers
  • 135 Answers
SOURCE: Removing and reinstalling
There should be removabe clamps attatched to the bottom of the cooktop which tighten with a screw to the bottom of your countertop. Loosen the screws to the countertop, then remove the screws that attach the brackets to the cooktop. The cooktop should then be able to be pulled out.
Posted on Apr 07, 2008
  • 8 Answers
SOURCE: need to disconnect dishwasher from countertop-now woo but having granite countertop placed
JUST TOP SCREWS SHOULD BE FINE
Posted on Dec 05, 2012
Our new range is too high for countertop and we cant raise it
??>> ooppss... didn't measure before purchasing huh...ouch......
Does the range have adjustable feet.. or even removable feet..??
other than this...??? ... raising countertops can get very $$$$$.. I would hate to see would it would costs to raise mine..(custom Wild Hickory and Corian)
sorry...
Aug 08, 2017 | Kitchen Ranges
How to change the switch on a thermador UCV36
Thermador Appliances ' Customer Support, Service, Repair ...
www.thermador.com/support
ThermadorThermador customer support is your appliance resource for FAQs, use & care videos, product registration, warranty information, service, repair and more.
Thermador Appliances ' Frequently Asked Questions ' Use ...
www.thermador.com/faq/categories.php?categoryid=63
ThermadorWe recommend that a Thermador authorized servicer change the seal ... refrigeration appliances, especially when the cooling function is switching on or off.
How do you install the up/down switch in a Thermador ...
www.shopyourway.com > Manage My Life > Questions
Get shopping advice from experts, friends and the community! I have a Thermadordowndraft vent model number RDDS30VRS that I need to replace switch part ...
Vent snorkel stuck in up position, fan works fine - Applian
Dec 21, 2015 | Thermador Kitchen Ranges
Thermidor GG30 cooktop front large burner will not light, does not spark. Three other burners work fine. Need instructions how to disassemble and repair. I am handy but no experience with this item. ...
Here is the part to order.
Close the valve in the gas line connected to the Thermador oven. Unplug the cooktop's electrical cord from the wall outlet.
Remove the screws under the front edge of the Thermador cooktop below the cabinet to release the cooktop from the countertop.
Put on work gloves then raise the cooktop at an angle. Recruit a friend to hold up the appliance while you work on the igniter underneath. The igniter is a pronged strip of black metal in a housing wired with two plugs connected to powericon1.png sockets underneath the Thermador cooktop.
Disconnect the two wired plugs on the end of the igniter from the sockets.
Take out the two screws in the metal plate that hold the igniter in position under the Thermador cooktop. Pull the igniter out of the mounting bracket in the cooktop.
Hold the new igniter by the housing and insert the part into the mounting bracket. Secure it with the two screws.
Connecticon1.png the two wired plugs to the sockets. One plug is larger than the other, which makes it simple to connect them correctly.
Lower the Thermador cooktop into position on the countertop and reattach it with the screws through the underside of the front edge.
Plug inicon1.png the cooktop's power cord and open the valve in the gas line.
Feb 09, 2013 | Kitchen Ranges
Need to reinstall Kenmore Downdraft Blower
If I can get the model # I can help you more with the removal and reinstall.
May 28, 2010 | Kenmore 59940 Kitchen Hood
We have a Thermador Mod SGCS365RW 5-burner that was new in 2001 and installed for Propane. It has worked fine until yesterday - the top center burner does not get gas to the burner. The igniter works fine....
Hi, if the other 4 burners are working fine, the problem must be in the valve stem. There is a linkage inside the valve body which may have stripped itself. If this is the case you would need to replace the valve.
Feb 04, 2010 | Thermador SGS36GS Gas Cooktop
Mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Dec 19, 2008 | Dishwashers
Obsolete Thermador
Hi Iniro
It is true that thermador has permanently discontinued some of its models - alternative supplier have not beeen identified
Regards
Sep 09, 2008 | Thermador SGS36GS Gas Cooktop
Apr 07, 2008 | Jenn-Air 30 in. CVE3401 Electric Cooktop
Obsolete Thermador
I am looking for Thermador part # 414-564 and Bosch part # AP2831995. Anyone ???
Sep 09, 2007 | Thermador 37 in. SGSX365 Gas Cooktop
Kitchen Ranges Logo
20 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
butch welch
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
