Question about Apex Digital APEX Remote Control RM-1225 p/n:RM1225
What is the play button the Apex RM1225 remote
I have an apex uk1a remote need remote code for apex pd 510 portable dvd/cd mp3 player
Code, if applicable, will be in the remote. If your Apex remote is compatible with your Apex player, you should be able to control it directly just by pressing DVD and the power button.
Aug 20, 2016 | Apex Digital Televison & Video
Manual
Eventually you will purchase a replacement remote or maybe a universal remote that will operate your Apex player
Jun 30, 2013 | Apex Digital AD 1115
Apex k12b c2
If only one button do not work, it might be set right by cleaning it. But to clean it, you must open the remote control If you check the link given below, you can get the procedure about how to clean , repair and check a remote control http://electronicshelponline.blogspot.com/ Pull up older posts there.
May 25, 2013 | Apex Digital APEX K12B-C2 Remote Control
My apex tv is locked and we can't unlock it
Apex TVs have parental locks that allow you to block certain programs based on
their rating. When this feature is no longer needed and you want your TV to display all programming no matter its rating, you must unlock your TV. Unlocking your Apex TV is done completely from your remote control and does not require any tools. The process takes less than 5 minutes.
• Press the "Menu" button on the remote control and use the arrow buttons to scroll down to the "Parental Guide" option, then press the "Enter" button.
Type in the default parental code "6688" if you have not set your own code. If you have set your own code, type it in. If you set your own code and forgot it, override it by using "6688."
Use the arrow keys to switch the parental lock to "OFF." This allows all programs to be viewed no matter the rating. Press the "Exit" button on the remote and start watching all your channels.
Dec 31, 2012 | Televison & Video
Apex DVD/Tv combo GT2015DV won't play dvd's
Something is wrong..crbr799 your DVD-TV has a TV-DVD button on the right front to switch from TV to DVD play...OPEN button on left side ,place DVD in tray, close & press PLAY...
I something simulator that needs the remote control for the SPECIAL functions....by the way the ORIGINAL r\c is $135 to $155, a replacement ($35) will turn the TV\DVD on ( which you can do without the r\c) and NOT function with anything else.
P.S. they will try to sell you universal r\c that work with the CABLE boxes, the ones that you pay a monthly fee!!
Aug 11, 2011 | Apex Digital Televison & Video
I have a Apex AD-1200 DVD and all dvd's play in b&w instead of color
on the remote there is a button with P/N ,, this button is the one that changes it back,,
Jun 23, 2011 | Apex Digital AD-1200 DVD Player
I have dish network and an apex 1225 dvd player. i do not have a remote for the dvd player. i do however have a dish network platinum remote control. i am in need of the code to link this remote control to...
Try the steps below these processes are called a power scans, there is a different type for any equipment needed. This should take 5-6 minutes per item to program.
For DVD/VCR's:
1.) Press and hold the correct VCR/DVD button (about six seconds) until all mode button backlights come on, then release.
2.) Press 222 pound (#) then record three times.
3.) With the desired equipment on, press and hold the VCR/DVD button until all mode button backlights illuminate (about 3 seconds), then release.
4.) Press and release the Power button.
5.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
6.) Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
For TV's:
POWER SCAN
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
For any other equipment:
Power Scan AUX
1.) With the desired equipment on, press and hold the correct AUX button until all mode button backlights illuminate (about 3 seconds), then release.
2.) press 0 for a TV, press 1 for a VCR/DVD, press 2 for any other device, then press *.
Press and release the large red Power button.
3.) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off.
With any of these methods verify the code works by trying several different functions for that equipment.
Daniel Busa
DISH Network
Customer Service
Mar 20, 2011 | Apex Digital AD-1225 DVD Player
Wont Play DVD
any remote should work but i suggest a name brand like sony logitech or phillips because you dont want to have to replace this for a while and namebrands offer more functions than generics.
As for the dvd not playing dvds it appears the parental lock may be enabled preventing movies from starting after previews .
after you obtain the new remote and have programmed it scroll through the tvs set up menu to see if parental lock function is on if not drop me a line so we can narrow things down also try to push enter button on new remote if the play button doesnt start movie.
Jan 16, 2008 | Apex Digital GT1417DV 14 in. TV/DVD Combo
Can't play DVDs
TRY PUSHING the ENTER BUTTON on remote TO START MOVIES THAT DONT ALLOW MOVIe to start when play button is pressed.
Sep 12, 2007 | Apex Digital GT1417DV 14 in. TV/DVD Combo
Apex Digital APEX Remote Control RM-1225 p/n:RM1225 Logo
19 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
