Question about Apple iPad 32 GB WiFi Tablet PC
Not enough space avail on iPad - Apple iPad 32 GB WiFi Tablet PC
My Apple iPad 2 won't update. It's running iOS 9.
It may be too full. Check how much free space you have. Try to have approximately 3GB free. Delete things that are easy to replace like apps, or music you can download again.
Oct 04, 2015 | Apple iPad 2
Why do I get you tube error loading messages when trying to access you tube videos on my I pad
Most likely your iPad is full... of pictures, videos, music, etc. Visit the Settings app, tap General, then Usage. In the STORAGE section at the top, you'll see how much of the storage is available on your iPad and how much is used. If the available number is small, you need to remove stuff until you have enough to handle incoming video streams (YouTube, for example).
The STORAGE section also identifies the apps that are using your space - if Music, Photos & Camera, or other apps seem to take a large portion of the space, either remove some of the data associated with those apps (pictures, movies, music) or remove apps themselves (apps you don't use don't need to be taking space on your iPad).
Portable devices aren't meant for large permanent storage. You should save things you intend to keep forever on your desktop device or in the cloud.
Oct 18, 2014 | Apple iPad 2
How do I obtain more storage in my Apple IPad?
Hi Anonymous,
This might help you, just follow these:
1. Go to your iPad's home screen by clicking on the home button. Click on Settings to access your settings.
2. Go to General in Settings and click on Usage. This will allow you to manage your storage, as you'll see a list of what's stored on your iPad. Look at how much storage you have available. This will inform you how much you need to get rid of, but not too much because you still have plenty of space.
3. Click on Manage Storage to start managing your storage. See what apps you have and how much space they take up. If any apps take up a lot of space, and you don't need them any more, you know you need to delete them.
4. Delete unwanted apps. To delete an app: •Tap on the relevant app in the list. You will see the button Delete App. You will also see the app's size and its Documents and Data usage (including data cached for quick access).
•Tap on the Delete App button, and the app will be deleted. •Note that the apps that come pre-installed (such as the Music and Videos apps) cannot be deleted.
•Take care not to delete any apps you need, especially for work. Instead, make room for them by determining which apps you no longer use or want (such as games, PDFs or other items you've finished with).
Aug 11, 2014 | Apple iPad Tablets & eReaders
Can i install wordpess on Apple iPad
There is an app available to manage your Wordpress site from your iPad but there is no way to install a Wordpress site on your iPad. Although since Wordpress 4.0 was released the app isn't necessary as it specifically optimizes the management of a Wordpress site on mobile devices.
Jul 13, 2014 | Apple iPad Air 9.7" 16 GB Wi-Fi Space Gray...
Told not enough storage. Bought another 10 gig but still told not enough storage in my ipad 2
Try turning off the iPad or table then turn it back on of that doesn't work you'll have to bring it to a computer technician.
Dec 17, 2013 | Apple iPad 2 Wifi 16GB
When I try download apps to my ipad I put a password in and then nothing happens
Open Settings, tap General, then Usage. Check available storage. If it's less than 500 mb, consider removing stuff. The list at the top of this window identifies the culprits. If Music is big, consider deleting music (in the Music app) from the iPad... it'll remain available on your desktop iTunes (or on iCloud if you use iTunes Match). If you have huge apps that you don't play, get rid of them... (GTA, RealRacing, etc. are gigantic). If you keep videos or video podcasts on your iPad, stop it... just sync the ones you need.
Make iTunes your friend. Plug you iPad into your desktop device (if you're using one) and go through everything to see what you're syncing. Uncheck anything you don't use. You'll get space back.
Nov 26, 2013 | Apple iPad 2
Apple iPad 32 GB WiFi Tablet PC Logo
15 people viewed this question
Top Apple Tablets & eReaders Experts
Virgil Wolter
Level 1 Expert
Aaron Galvan
Level 1 Expert
john smith
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
