Question about Compaq Mini Cq10-525dx Netbook Laptop 10.1"
Restore my computer to factory settings
I am having all sorts of error messages and program issues with my computer and want to restore it to factory settings. My computer runs extremely slow so i don't know if it has a virus or not. How do I restore my computer?
    President:
  • 1,447 Answers
Please install new windows
Posted on Jul 19, 2014
Restore computer to factory settings
no need to perform factory reset. Follow the steps given below in article and you can remove virus quickly.
Click below.
Windows techbook
Feb 08, 2014 | Compaq Mini Cq10-525dx Netbook Laptop...
Everytime I start my pc up it reads files are compressed
Is it affecting your computer from running>???
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured
Right click on the error message select properties you will see all details about the error
or click start type in event viewer pressENTER
this should give you some sort of understanding of the error and
you might be able work your way through the problem
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
You could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue
You might use the system restore to restore your system to an earlier time click start all programs
If it is a hardware issue the system restore might not work
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer.
Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System.
Configuration utility Installation restore points that occur before you install a program or a serviceyou can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps:
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Nov 22, 2013 | Systemax Computers & Internet
Skype fatal error
What sort of error ? are you able to start your computer ?
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue and
if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
If you want to know what this is the error code is related to
extend the events there you will see errors in red you will no what exactly what the error was and at what time it occurred
or click start type in event viewer press ENTER
or
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
If the problem is hardware related the system restore might not work .?
Sep 25, 2013 | Skype IM
Internal error 000000b
What are you doing when this error happens ???...
As the computer is booting repeatadly press the F8 key as the computer is booting
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice
select the safe mode option
then run your antivirus if still cant get rid of the virus restart again
Use the up and down arrow keys to move the highlight to your choice.
select safe mode with networking download anti malware and microsoft security essentials
http://www.microsoft.com/en-us/download/virus-malware.aspx?q=virus
anti virus and malware
http://windows.microsoft.com/en-US/windows/products/security-essentials
If this fails you might have to go back into safe mode.
You might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System
Configuration utility Installation restore points that occur before you install a program or a service. You can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
Sep 07, 2013 | Computers & Internet
Gateway desktop critical error code
Which operating system ???
Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
if this hails to fix the problem
Restoring your Windows 7 Gateway computer to its original factory settings is a great way to get rid of pesky viruses you can't seem to remove from your computer, or simply to remove old programs and files from your computer and start with a clean slate.
Your Windows 7 Gateway computer will likely run faster as a result of deleting old and unnecessary files.
It's also a good idea to restore your Windows 7 Gateway computer to its original factory settings if you plan on selling it, or passing it along to a family member or friend.
Recover From Windows 7 Home Screen
Click the "Start" icon in the lower-left corner of your Windows 7 home screen.
Click "All Programs" in the Start menu, then click "Gateway".
Click "Gateway Recovery Management" to open the Gateway Recovery Management program.
Click the "Restore" header, then click "Restore System To Factory Default".
Click "Yes" in the "Confirm Restoration" dialog box, then click "Yes".
Click "OK" in the dialog box warning you that all of the personal data on your computer will be deleted. Your computer will automatically restart.
When your computer restarts the restoration process will begin. The process could take anywhere between 30 and 90 minutes.
Click "OK" when a dialog appears telling you that the computer has been restored to its original factory settings and that you need to reboot your Gateway Windows 7 computer.
Your computer will reboot.
After the computer restarts you will need to configure Windows 7 with your personal preferences.
Recover at Startup
Turn on or restart your computer and hold down "Alt" while clicking "F10" during startup until you are redirected to the Gateway Recovery Management program.
Click "Restore System From Factory Default".
Click "Next" to begin the restoration process.
Jul 02, 2013 | Computers & Internet
Gateway laptop error
Recover at Startup
or if still no joy
http://www.almuseo.com/download-repair?Windows 7 0xc0000185for Windows 7 0xc0000185 and associated problems.
Windows 7 0xc0000185 error message codes are almost always caused because of missing system files inside your Microsoft Windows operating-system.
When you've got Windows 7 0xc0000185 error message then we suggest that you perform an error scan.
This article provides related information that explains the best way to repair your Windows Windows 7 0xc0000185 error codes either by hand and automatically. Additionally, this guide can help you to fix most regularly occurring error code messages connected with Windows 7 0xc0000185 error code which you might possibly get.
Jun 03, 2013 | Computers & Internet
Error message "restore failed 0x00000070"
Step 1:
Use an external memory device such as a DVD, flash drive or external hard drive to back up the data you need to save from your eMachines computer. Any data that isn't saved to an external source will be erased when the computer is restored to factory settings. Remove any discs that are in the optical drive and unplug the computer's peripheral devices, such as an Ethernet cable or scanner. Do not disconnect the keyboard, mouse or monitor. Click the Windows "Start" menu and choose "All Programs." Navigate to "eMachines" and choose "eMachines Recovery Management." Click the "Restore" tab. Click "Password Settings" if you have not already set a recovery password. Type a new password in the text box and click "OK." Click "Restore System to Factory Default." Type the recovery password and click "OK." Click "Next" to wipe the eMachines computer's hard drive and begin the recovery process. Select "Finish" and wait for the eMachines computer to restart. Use the series of installation prompts that appear on the screen to create a new user account for your operating system, set the system date and time, and set up your Internet settings.
Mar 10, 2013 | Computers & Internet
I have Lenovo laptop y410 & When i open mt laptop then showing c/wins/system32/wtsapi32 there is some problem ...and i couldn't access normally if u suggest something for me that will be good!!!!!!
Hi Adhikary_pin,
If you can't run the system normally and produces error c/wins/system32/wtsapi32 it is due to corrupted operating system file. There are several ways on how to to resolve this issue, either you restore the computer using Windows system restore or put back the default factory setting on it. Here are some steps on how to use the Windows system restore.
1. Turn off the computer.
2. Reboot the computer then start tapping the F8 key.
3. Now once you're in the"Windows Advanced Boot Options Menu" select the "Safemode Option".
4. Computer will then begin to start in safemode.
5. Now click [Start] point to [All programs] go to [Accessories Folder] then [System tools] and click "System Restore".
6. On the "Welcome system restore" page, click the "Restore my computer to an earlier time" option then click next.
7. On the "Select a Restore Point page", click the most recent system restore point in the On this list, click a restore point list, and then click Next.
--> A System Restore message may appear that lists configuration changes that System Restore will make. Click OK.
8. On the Confirm Restore Point Selection page, click Next and it will restarts the computer.
--> if after these process and you're still encountering the same issue, I recommend to perform One Key Recovery to bring back the factory setting of the computer.
For the One Key Recovery procedure, kindly visit my link below. You will find helpful tips and guidelines on it.
http://www.fixya.com/support/r8582118-restore_lenovo_computer_factory_settings
Hope it helps,
Thank you for using FixYa.
Oct 03, 2010 | Lenovo 3000 Y410 Laptop
My pc is infected, and I need to reboot it to its factory settings.
Restore your Laptop to Factory Settings is an EASY utility BUILT into Windows -- it CLEANS EVERYTHING...computer and hardware. But, it is HANDY. jQuery(document).ready(function(){ jQuery('.intro .thumbnail a:first').attr('href','http://i.ehow.com/images/a06/6v/d1/reboot-laptop-back-factory-settings-800X800.jpg'); }); Rebooting your laptop back to its factory settings restores your computer and its hardware to its original settings when it was purchased. This is helpful when troubleshooting major hardware and system performance issues. It can also be used to fix virus related issues. Restoring your computer to its factory settings is similar to performing a clean install of your operating system. Windows uses a utility program called System Restore that allows you to restore your computers settings to a specific date.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions
  1. Step 1 Turn on your computer, and then click on the "Start" menu icon in the bottom left-hand corner of the screen. Select "All Programs," and then click on the "Accessories" drop-down menu.
  2. Step 2 Scroll down to "System Tools," and then select the "System Restore" program and wait for it to open.
  3. Step 3 Select the "Restore My Computer to an Earlier Time" option, and then click on the "Next" button to continue. A window with a calendar will appear.
  4. Step 4 Click on the back arrow in the calendar's window. Click on the back-arrow until you have reached the date you either purchased or installed Windows on your Notebook. Select the appropriate date, and then click on the "Next" button to continue. Your computer will automatically restart.
Aug 13, 2010 | Fujitsu LifeBook E8020 Notebook
Error message
Hi there
It has something to do with your antivirus i think, If you used the System Restore function of your computer, it is very likely to have installed an obsolete antivirus program. Almost all computers now come with an antivirus program some sort installed, and the Restore disks (or built-in System Restore) will reinstall it automatically.
Open the Windows Control Panel, check your list of installed programs, and see which antivirus program you have. Uninstall all but one of the antivirus program's.
Good luck and thanks for using Fixya!!
Feb 13, 2009 | Microsoft Windows XP Professional With...
Compaq Mini Cq10-525dx Netbook Laptop 10.1" Logo
78 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
