Question about Acer Computers & Internet
How to access WinRe partition - Acer Computers & Internet
    Prodigy:
    An expert who has answered 500 questions.
  • Acer Expert
  • 510 Answers
If you need to recover the unit then simply go to all programs and under Acer you will see Acer e-recovery management, or from cold boot press Alt + F10 keys together about once a second until you see "windows is loading files" follow instructions (be aware this will destroy all data).
Posted on Feb 11, 2014
Hard drives
If your C: partition is the almost filled red bar, yes you almost out of disk space.
Jan 27, 2014 | Computers & Internet
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
Can not open windows....how to recover...? n i dont know how to solve this problem.... (vista - Dell Precision T3400)
  1. Boot from the Vista install disk
  2. Choose your language settings and click "Next"
  3. On the bottom of the screen click the link "Repair Your Computer"
  4. Select the Vista installation to repair and click "Next" and it will launch WinRE
    • The "Load Drivers" button will open a mini Windows Explorer, which can be used to search for drivers in case they are needed to access disk drives or other components. This mini Explorer is also very handy to perform file copy/move operations and change file-attributes.
The following options are available in WinRE: Startup Repair - It will repair the boot manager files and restore critical files required for booting Windows Vista.
This should solve basic bootup problems.
Or you could also do a Complete Repair which replaces your current Vista installation.
Jan 17, 2011 | Computers & Internet
Hi i forgot my users password an i cant reestart the laptop its a dell laptop windows7 home premium can u help me restart the computer
There are 3 options for your problem:
1. You can boot to WinRE(Windows Recovery Console), run the command prompt. Go to the WINDOWS directory. Rename magnify.exe to magnify.old. Rename cmd.exe to magnify.exe. Restart your computer and boot normally. On the log in screen, click on Ease of Access. Select the option for magnifier. It will open command prompt instead of magnifier. Type the command: control userpasswords2. It will give you the option to reset the password.
2. Run in safe mode. Log in using the profile Administrator. Go to control panel then user accounts. You can change the password of your profile.
3. Dell systems have the built-in factory image restore. It can be found in the WinRE. To go to WinRE, turn system off, power on computer, after pressing the power button, tap on F8 till it gives you a screen that says Advanced Boot Options. Select Repair your Computer. Click on a few things for the language. Then you will have a window that says Windows Recovery Console. Click on Dell Factory Image Restore. Then there you go! it will restore the system back to its factory settings.
Hope this helps!
Sep 08, 2010 | Computers & Internet
Boot mgr is missing
Boot Manager is missing If the boot partition no longer can be found, then Vista will display the following error: BOOTMGR is missing. Press Ctrl+Alt+Del to restart
The Windows Boot Configuration Data file is missing required information
More Info MS KB 919529 More Info MS KB 927391 Check points for fixing missing boot-manager: Check that your boot device is configured properly Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". Boot Manager is compressed If by accident having compressed the entire boot partition, then Vista will display the following error: BOOTMGR is compressed. Press Ctrl+Alt+Del to restart OR maybe try this first. Check points for fixing compressed boot-manager: Boot into Windows Recovery Environment (WinRE) and perform a "Startup Repair". If the above doesn't solve the problem then boot into WinRE again, but when selecting the Vista-installation, then press "Load Drivers" (Instead of "Next") and use the mini Windows Explorer to right-click the boot-drive and deselect "Compress this Drive" and choose Apply to sub-folders and files. If that also fails then boot into WinRE again, and go to the "Command Prompt" and execute these commands: compact /U C:\bootmgr compact /U C:\ntldr If you for some strange reason have lost your Vista DVD, then you can also use a Windows 2000 / XP install CD and enter the recovery console instead and execute the following commands: attrib -c c:\bootmgr attrib -c c:\ntldr
Try start up in Safe Mode press F8. Choose Safe Mode, when at the choice window, to select either Safe Mode Desktop, OR System Restore, chooses system restore and choose a time before you had the "Problem" and follow instructions. This should get you back.
Feb 21, 2010 | Acer Aspire 8920-6048 Notebook
MBR record
boot from an original XP cd, 1st option select "r" for repair. Select OS... Normally "1", then type in your administrator password, normally blank. when the command prompt is ready, type in "fixmbr" follow prompts and then type "exit" to restart.
See if that helps
Apr 22, 2009 | Computers & Internet
I have just purchased a HP 2133 mini-note. On first installation, installation failed and now it just loops and wont do anything. How can I facilitate first installtion bearing in mind there are no disks...
The majority of these PCs have a recovery partition on the internal hard drive, here is the instructions for using it.
Recovering information using Windows Recovery Environment (WinRE)
Windows Recovery Environment (WinRE) can perform a recovery from either an optional external hard
drive or from recovery discs.
CAUTION: Using Windows Recovery Environment (WinRE) will completely erase hard drive contents
and reformat the hard drive. All files you have created and any software installed on the computer will
be permanently removed. When reformatting is complete, the recovery process will restore the operating
system, as well as the drivers, software, and utilities from the backup used for recovery.
To initiate recovery using WinRE, follow these steps:
NOTE: This process will take several minutes.
1. If possible, back up all personal files.
2. Restart the computer, and then press f8 before the Windows operating system loads.
3. Select Repair your computer.
NOTE: The "Repair your computer" option is displayed only if the WinRE partition is intact. If the
option is not displayed, refer to “Recovering information using a Windows Vista operating system
DVD (purchased separately).”
4. Follow the on-screen instructions.
5. Click Next.
6. Select your user name, type your password (if applicable), and then click OK.
7. If you are using recovery discs, insert the last disc of the recovery disc backup set.
NOTE: Inserting the last disc of the backup set confirms the presence of a valid backup. If you
insert any other disc, the backup will not be recognized.
– or –
If you are using an optional external hard drive, connect it to the computer.
8. Click Windows Complete PC Restore.
9. Follow the on-screen instructions.
this is getting long , so ill will post more steps in comment.....
Nov 20, 2008 | HP Computers & Internet
Compressed boot manager
Windows Vista includes a new Boot Manager (BootMgr) that replaces the old NT Loader (Ntldr).
This can usually be solved by checking the boot devices, and if no problems found then use Windows Recovery Environment (WinRE) and perform a "Startup Repair".
This can usually be solved by using Windows Recovery Environment (WinRE) and perform a "Startup Repair". If that fails then use WinRE to enter the "Command Prompt" and execute these commands:
  • compact /U C:\bootmgr
  • compact /U C:\ntldr
Aug 28, 2008 | Computers & Internet
Windows will not start, even in Safe Mode. Repair wizard said I have a corrupt registry. Can I recover without losing my data?
YOU CAN DO one thing that when you install any windows and format earlier windows and and do not format your data
Jun 26, 2008 | Toshiba Computers & Internet
Computers & Internet Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
