Question about Kitchen Ranges
Bosch wae244b lock symbol - Kitchen Ranges
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
I have a Bosch HBN 1315.1 B. The child lock light is on and the oven won't work, but this model does not have a child lock button to press it off. How do I turn off the child lock?
Try one of these two recommendations. If there is a key symbol, press and hold for 4 seconds.
If no key symbol, cut the power to the unit and the child lock will stop working. (You are probably going to have to reset the clock, etc. )
Apr 01, 2015 | Bosch Kitchen Ranges
Have bosch classixx6 1200 express which has frozen displays a flashing key and 36 will not budge, desperate Molly
Simply press and hold the Start button for 4 seconds and the childproof lock will turn off - the key symbol will disappear from the display.
If you want to activate the lock then press and hold the Start button until the key symbol appears on the display.
Oct 22, 2009 | Bosch Washing Machines
When I select a cycle the -0- is displayed and the lock symbol.
YOU PROBABLY HAVE THE CHILD LOCK ACTIVATED GENERALLY HOLDING THE LOCK BUTTON IF THERE IS ONE OR THE START BUTTON FOR 5 SECS OR MORE WILL TURN IT OFF ALLOWING NORMAL USE
Sep 16, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Key symbol showing machine will not start
Generic problem for all Bosch Washing Machines Key symbol showing machine will not start
Sep 11, 2009 | Bosch Washing Machines
Won't start, key symbol in display panel
Power on, press the start button for 5 or 6 seconds, the sign will go off. Try the door gently. Means the machine is locked, for children. I think if you do it again it locks.
Pl rate me 'very helpful' for the free help, thanks
May 16, 2009 | Audiovox Bosch 718 World Cellular Phone
Bosch Classixx 6 1200 express front load washer - the 'screen' has a lock symbol on it, preventing operation: not sure whta this means or how to resolve, please.
The 'start' button appears to contain a lock - possibly a child lock. Hold the button in for a few seconds to clear the lock
Mar 25, 2009 | Bosch Washing Machines
Kitchen Ranges Logo
10 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
