Question about Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Need a replacement belt for 310-3133 - Bissell 1697-7 Powersteamer Pro Deluxe Vacuum
Beater? bar doesn't spin
That means that the belt is broken, stretched or worn. You need to change the belt. You can get replacements here:
Replacement Vacuum Belts
Dec 08, 2009 | Vacuums
The belt broke
You need to replace it with a new one. Here is a link for the instructions on how to change the belt and a link for the belt you need:
DC07 Belt Changing Instructions
Replacement belts for DC07
Nov 15, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Not picking up. suction okay on tools. I think belt is broken but how to get to it and change it?
Yes, you probably need to replace the belt. Below I have listed a link to the owners manual which has instructions on how to change the belt and a link to the replacement belt you need. Hope it helps you!
Eureka Capture Owner's Guide
Eureka Capture Replacement Belt
Nov 01, 2009 | Eureka Capture Upright Vacuum Vacuum
Seems like the belt may be getting old and not picking up as much as it used to.
Belts need to be replaced periodically. If the belt is worn it will not pick up the way it should. You can get DC07 replacement belts here:
Replacement belts for DC07 w/ clutch system
Replacement belts for DC07 w/out clutch system
Oct 30, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Self propulsion doesn't work on my upright. Vacuum works fine otherwise
You will need to look @ your owners manual to see where the self propell belt is located i am sure yours is broke and need to replace,- it will not be hard to replace-Lance
Oct 21, 2009 | Hoover Vacuums
Hoover U6439: Belt keeps slipping off
The belt is stretched and you simply just need to replace it. You can get the belts you need for this model here:
http://www.vacbelts.com/hoover-self-propelled-windtunnel-belt.htm
Sep 28, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Replace the belt
Once the bottom plate has been removed, the motor shaft is silver, but hard to see. hook the new belt on it first. then start rolling on the top of the large black pulley to install.
Jan 26, 2009 | Hoover Ultra U6430-900 WindTunnel Bagged...
Need to replace vacuum belt
how do i change belt on morphy richards ultralight cyclone cleaner?
Jan 04, 2009 | Vacuums
Hoover mach 4 burning smell
There are two reason you could be smelling a burning smell-
1. The belt is too stretched out and needs to be replaced. This causes it to slip when the vacuum is on and will create that type smell. You can avoid stretching and having to replace the belt to often by releasing the belt after each vacuum.
2. There may be hair or other debris stuck around the rod that the belt is attached to. Can be avoided by checking after vacuuming.
Hope this helps
Nov 12, 2008 | Hoover Vacuums
Bissell 1697-7 Powersteamer Pro Deluxe Vacuum Logo
22 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
