Whirlpool sm 8280869
How long should the heavy agitate cycle take? I do not feel my clothes are getting clean.
Jimster
  • 240 Answers
SOURCE: My whirlpool top loader won't agitate.
Ok, sorry it took so long to write.  You listed the washer as a Calypso, but it didnt look righ, so did some investigative work for you.  What your describing I believe, is that the agitator top half (or the auger as well them) is sitting still and the bottom half if moving.  During the wash cycle, the top half is just sitting still.  If this is wrong, please let me know.  If this is right, you have a sort of simple fix.  Remove the top cap of the auger, pry gently between the cap and the agitator, the plastic cap will come off.  When you remove the cap, you will see another cap (sometimes you do, sometimes you dont) it will be white or dirty clear in color if its there.  You can put your finger on the lips and lift it straight off.  Then you will see a cap with a bolt in the center.  Remove this bolt (7/16" with long extension).  the agitator dogs (Sears part #387091) 387091.jpg.  You should see these under that last cap tha had the bolt in it.  Remove the auger (just slide it up and off), remove the dog holding cap.  Remove the dogs, but be sure you remember the way they go back in.  Next is the tricky part.  Take the cap upside-down, and place it back in the auger.  Quickly turn it back over, making sure the ag dogs dont fall out of position (you will be hating me the first couple time, just keep at it), then, with a long pair of needle nose, place the bolt you removed back in the hole.  Take your extension with socket, hold the bolt firmly, and slide the auger back on to the top of the agitator.  Make sure the locks and stuff fit right between the two.  Tighten the bolt (just snug, DO NOT OVERTIGHTEN, you will split the cap).  If all goes well and right, you should be able to roll the auger one way and not the other.  If you need any further help, or need someone to yell at when the dogs keep falling out, give me a shout, and we'll help you along.  Good Luck!!!!!     Jim
Posted on Oct 24, 2007
Thanks! Removed the fabric softener dispenser, then the plastic cap with the raised plastic strip, inside the post by reaching in and twisting until the o-ring seal becomes free, then removed the bolt using a 7/16" socket with a long extension. Walked in the washer supply store with the whole module that holds the dogs and the man at the counter saw it in my hand, reached under the counter, laid the 4 plastic dogs on the counter without me saying a word and said "that all you need?" think they sell a lot of them? part number fsp-80040. repaired in 40 min.s including the 5 mile trip to the parts store!
Donna K.
Posted on Jun 19, 2008
SOURCE: won't spin or agitate
coupling.between motor and gearcase.
Posted on Nov 14, 2008
jumptrout51
  • 3361 Answers
SOURCE: whirlpool model SM 8525079 fills with water but
If you have motor sounds after water fill,but no agitation or spin it could be a broken direct drive coupling. If it will not pump out water,there could be something stuck in the drain pump.
Posted on Jan 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: won't drain or run spin cycle
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
The agitator on my Whirlpool (8280869) is rubbing/grinding. It seems the ratchet system is not catching on the center post when the agitator starts to spin. Can this be fixed?
On whirlpool/kenmore direct drive machines, the part you are referring to is the 'agitator dogs.' They are paisley shaped plastic pieces with teeth on the outer edge... Usually a 7/16 nut or a square plastic drive(1 inch socket adapter fits it perfectly) holds down the top half of the agitator. The pivot end of the 'dogs' must be inserted into their slot and should all face the same direction...
Apr 27, 2016 | Whirlpool Washing Machines
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
How do i replace the agitator in my old heavy duty whirlpool washing machone?
Hello.
The Whirlpool Ultimate Care II washing machine is atop-loading clothes washer. The washer has several cycles to choose from,including cycles for washing normal clothes, permanent press items, delicateand items marked "Hand Wash." To do its job, thewashing machine relies on an agitator, located in the center of the wash tub.The agitator rotates during the wash cycle, moving the clothes around the washtub so that they are cleaned equally. If the agitator is broken, it will notsufficiently agitate the clothes and must be replaced. ·1 Unplug the washing machine from the wall outlet or turn off the power supplyin your service panel. · 2 Open thewashing machine lid and remove any clothes remaining inside. · 3 Remove thefabric softener cup by squeezing the bottom lip of the cup and lifting itstraight off. · 4 Pry theagitator cap off of the top of the agitator with a flat-head screwdriver. · 5 Remove thebolt at the bottom of the agitator, using the socket wrench with extension, andthen remove the agitator from the washing machine. Tip the agitator to removethe bolt and washer. · 6 Install thenew agitator onto the drive shaft. · 7 Secure thenew agitator with the bolt that you originally removed. · 8 Press theagitator cap and fabric softener cup back into position on top of the newagitator. · 9 Restore powerto the washing machine to complete the repair.
Thanks.
Sep 07, 2011 | Whirlpool Washing Machines
I have a TEKA LS1000I with no manual! Ive been trying different combinations for about a month but I have no idea if its actually cleaning clothes of just making them wet! Does anybody know where I can...
Sr/ Mam Washing machines agitate clothes in water and using an additive to the water like laundry detergent will defiantly clean your cloths, on the wash cycle if you look into the cleaning area and the clothes have moved around inside your machine is probably agitating, if the water is drained and there is no soap residue on your clothes than your clothes are as clean as your detergent can get them and your machine is working properly. they will be damp and heavy when you remove them this is where the close dryer comes into affect, use some bounce fabric softener this works well for this proses
May 01, 2010 | Washing Machines
Washing cycle on a 40degree op. takes more than
Don't forget that the reason you bought a front loading washer is for the efficiency of the washing. In other words, front loaders use less water and get clothes cleaner without all the harsh beating that the older agitator units do.
If you're using any of the pre-programmed wash cycles, you might want to tgry another cycle to see how it does for getting your clothes clean with a shorter cycle.
If you check your owners manual, it should provide the cycle times for the various wash and water temp settings. The colder the water you use, the longer the wash cycle typically is, since it takes more agitation and time to get clothes clean, especially with front loading machines. Hope this helps.
Jul 28, 2009 | Whirlpool WFW9200S Front Load Washer
Agitator
if its a 2 piece agitator.. the gears in top of agitator is stripped out.. change gears be like new....spin top countor clockwise if it dont grap.. gears bad
Sep 28, 2007 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool calypso
Have you checked the agitator? There may be sharp edges on the agitator blades. OR the towels may be getting stuck under the agitator and tub bottom. The agitator is supposed to suck the clothing down in the center and forcibly throw the clothing outwards against the tub. The cycle then repeats.
Sep 09, 2007 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
65 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
