Question about Matrix MXT5 Treadmill
Calibrating a matrix treadmill
Cailbration
How do I calibrate a Trimline 4650.1 treadmill?
WARNING: DURING THE ENTIRE CALIBRATION PROCESS, STAND ON THE PLASTIC SIDE RAILS ONLY!
DO NOT STAND ON TREADMILL WALKING BELT!
CALIBRATION
1. Turn off treadmill.
2. Simultaneously press PROGRAM, ENTER, and START/STOP for about 3 seconds.
3. Maximum speed will be shown in the TIME/PACE display followed by an "E" for English units or an "N" for metric
units. Press START/STOP to change from English units to metric units.
4. Press ENTER.
5. Press START/STOP. Incline and speed will calibrate simultaneously.
6. When successfully completed, TIME/PACE display will show CAL PASS.
7. Press POWER. Your treadmill is ready for use
Jan 02, 2017 | Exercise & Fitness
My matrix t3x treadmill is not calibrating,it's says calibration fail?what could be the problem .its an AC motor treadmill
Hi There, No "rumble" sounds from the motor? All seems normal but won't calibrate? Is there a speed sensor mounted to the rear of that AC motor? Little black box looking thing that watches an encoder wheel to measure speeds? If so, Matrix had a sensor mounted here for a few years on AC driven treads, with 3 wires coming from it and plugs into that lower board. If the large "slots" in that encoder wheel get dust in them, the controller will loose speed feedback pulses required for regulation. If that is all clean, you may not believe this, but there was a period of maybe 8 months where inside that little black box, one of those 3 wires were not soldered correctly and is loose, touching a nearby wire inside, or open all together, causing that controller to miss feedback pulses. That sensor must be viable to calibrate that machine. If you power off, then pull that speed sensor from the main lower board, power back up, the lower unit will default to no-feedback(open-loop mode) mode and may run very near normal speeds. Power down and re-install that wire and does the tread work normally when not calibrating? Lastly, if the unit has had a lot of use, that lower board could have degraded capacitors on it that decay over time and become a bit lazy, not allowing enough drive current for the motor to calibrate at high speeds, and failing the cal routine? Is that lower maybe marked ASM-ACD3x or similar?You can email me at jatinahATrocketmailDOTcom for more help if needed. Good Luck!
Dec 12, 2016 | Matrix Exercise & Fitness
Fuel injector calibration
Injector calibration simply cannot be done without expensive and complicated test equipment. Fuel flow and spray patterns MUST be tested and adjusted using this equipment. Trying to do it without it is folly. Look in your local phone book to see who is in the business.
Jan 27, 2014 | Goodyear 1986 Nissan D21 Accessory Drive...
Stuck in elevated
RUN the software calibration for diagnostic, troubleshooting and fix it.
However try to lube the motor , rack, and pinion, adjust the POT, and fix it. see the diagrams
God bless you
Oct 16, 2012 | Matrix T3x Treadmill Deck Treadbed Parts
Life of running belt in matrix treadmill
all depende how frequently you LUBE the deck belt, may you have a worn Deck. see the instr. manual and see the video.
God bless you
Aug 05, 2012 | Matrix MXT5 Treadmill
My Matrix T3X treadmill display doesn't work
tight the ribbon cable keypad, clean it +tight the wires connector from display board vs lower board and clean it.
2) adjust the reed switch, clean it and tight the wires connector.
see the diagram.
God bless you
Jul 19, 2012 | Matrix T3Xi Treadmill
I have a vision T9500 treadmill. My husband was recalibrating and it got stuck in the highest position and is displaying E5 in the window. Any ideas how to get it down?
hi,
Try AUTO-CALIBRATION first. For that do the following.
With the safety key in place, turn the treadmill ON . Press and hold SELECT. Now you can perform auto-calibration by pressing START.
(The treadmill will run through minimum and maximum speed and elevation. This will take 3 to 5 minutes. Let the treadmill perform this complete function. "END" will appear when auto-calibration is complete. When auto-calibration is complete, it will take about 30 seconds for the treadmill to reboot and return to the start-up screen)
If it doesn't help then the motor control module is faulty. You have to replace or repair the motor control module.
OK
Aug 27, 2011 | Dmm Vision Fitness T9500 Treadmill
Hi, i have an Error signal " 2 - 9 F " the treadmill stops and cant run anymore. thanks a lot!
I have a Matrix Treadmill t4. An error of "E1 and E3" occurs when it is started? Can you tell me the solution?
Mar 15, 2011 | Matrix T3Xi Treadmill
Matrix MXT5 Treadmill Logo
Top Matrix Exercise & Fitness Experts
David Payne
David Payne
Sportsmith LLC
Sportsmith LLC
greg kinsley
Are you a Matrix Exercise and Fitnes Expert? Answer questions, earn points and help others
