Question about Saeco Coffee Makers & Espresso Machines
Seaco incanto classico circuit loading
My machine lights say to load circuit, but no water flows form steam wand and the pump does not activate
4 Suggested Answers
EsWorld
  • 1618 Answers
SOURCE: Hot water come out from steam wand when pumping Saeco Classico
Gasket on steam valve is worn. Replace gasket and or steam valve.
Posted on Mar 09, 2009
  • 24 Answers
SOURCE: Connect Saeco Incanto Classico machine directly to water source
In our shop we come off the treated water supply with a water pressure regulator (adjusted to a very low pressure)and use a barbed fitting to connect to the hose inside the machine. You should be able to do something similar by removing the water tank seat on the body of the machibne and using the existing hole to connect your water. If you need something more specific contact purpleturtlecoffee@yahoo.com
Posted on Jun 04, 2009
EsWorld
  • 1618 Answers
SOURCE: i have saeco incanto deluxe coffee machine,ventilate msg appears
Check the end of the steam nozzle, make sure it is not blocked. If not then with the knob open for hot water cycle push in on the knob if that works then the tap rod assemble or the steam valve needs to be replaced.
Posted on Feb 21, 2010
Saeco S class Incanto Classic was working, but now no steam at all. The pump sounds like it is trying to pump, but cuts out after a coupl of seconds, hot water light comes on, red water light flashes, and...
Check the end of the steam wand and parnello, if both are clear, then descale machine, that might unblock the tubes feeding the booster boiler and the steam wand if it doesn't then you will have to do it manually.
Mar 06, 2010 | Saeco Incanto Classic Espresso Machine
I have saeco incanto deluxe coffee machine,ventilate msg appears
Feb 20, 2010 | Saeco INCANTO DELUXE Espresso Machine
I have a Saeco Incanto Classic and the ventilate message will not disappear, even after sending 4 full watertanks through the steam nozzle. The solution posted above does not work.
Having read the other reviews here, I was prepared for the cryptic "VENTILATE" message. (The manual refers to this procedure as "Loading the circuit", which doesn't help to clarify things.) Of course this refers to what Americans would call "priming" the machine. As mentioned in another review, there is a plastic hand pump supplied for priming, but that is only needed in the event that the electric pump fails to self-prime. All I had to do (following the quick-start instructions) was to select the Hot Water function; the internal pump quickly primed itself. i hope this helps Lee Davidian
Jan 17, 2010 | Saeco Incanto Classic Espresso Machine
Cannot get the machine to work for first time. Power works, water in but no water flowing into machine. Cannot get the circuit loading to work??
Press hot water button and open the knob for about 10 secs, this will prime the machine. Check the emd of the steam wand to make sure it is not blocked.
Nov 28, 2009 | Saeco Incanto Classic Espresso Machine
Mar 05, 2009 | Saeco Classico Espresso Machine
Prime it
1. Open the steam knob all the way.
2. Turn on the pump (coffee Button)
3. Turn on the power to the machine.
The machine will start to pump hot water out from the steam wand. When you get a steady flow, your machine has been primed.
For Descaler, Cleaners and Parts for your saeco machine visit
www.CeriniCoffee.com
May 28, 2008 | Saeco Classico Espresso Machine
Saeco Incanto Classic Espresso Machine Saeco Coffee Machine Type SUP 021YDR Display shows Ventilate when I follow instructions and turn the Hot Water and the water knob the water is not coming through....
Do you get coffee? If it is just no water/steam, could be a blockge in the steam wand, or blockage in water lines. First test easy one - the steam wand. If the steam wand is o.k- then check for blockages in water lines/components ( pump, boiler, steam boiler). If you do not feel confortable with testing all the untis where water flows, contact Saeco USA Inc. to locate a Service Center near you at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Apr 12, 2008 | Saeco Incanto Classic Espresso Machine
Brand new Incanto Classic bought online, not working after 1 month
First, machine should be under warrantee- check with 1800myjuicer.com
Sounds also like you have blockage in the steam wand- every time you froth milk, you should let some water come out- to prevent clogging. Try first inserting a pin into steam want ( machine turned off) to see if that alleviates the problem. Also contact
Saeco USA Inc.at 800-933-7876 (toll-free), ask for customer support, or contact SAECO via e-mail at : outlet@saeco-usa.com
Mar 17, 2008 | Saeco Incanto Classic Espresso Machine
Problem with steam wand on my espresso machine
Did you try to prime the wand by running water through it for 4 seconds? After you do that it should work fine.
Aug 28, 2007 | Saeco Classico Espresso Machine
Coffee Makers & Espresso Machines Logo
19 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
83bj60
Level 1 Expert
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
